Losing/using oil?!?!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cdubya69, Mar 26, 2015.
  1. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    2010 Prius IV, Purchased July '13 with 133k. Now 175k. Other than drivers rear hub & brake recall, never an issue...until now. It the past 3 weeks, it has "went through" 3.5 quarts of oil. NO SIGNS of a leak (no puddles on floor and the "padding" on the pan side of the access door is dry). Doesn't smoke at all. The oil dipstick isn't rusted out.
    Any ideas?
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    How many miles are you getting per quart of oil?
  3. JC91006
    16,470
    8,383
    looking at your mileage, you are only averaging 20k miles a year. In 3 weeks time, you should have gone around 1500 miles or less. So if that's correct, 3.5 quarts is wayyyyyyyyyyyyyy out of whack
    48,969
    check your radiator for contamination.
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
  6. bisco
    48,969
    or 20w-40.
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Is there a full moon tonight ?? (Some weird replies.......)
    I think you are going to need the services of a competent shop for this one.
    That is a LOT of oil to be using with no sign of leakage or burning it.
    If you want to do a little bit more, maybe you could run it (the gas engine) for a bit while standing still to see if something leaks out while running........but not while OFF.
  8. Former Member 68813
    3,524
    981
    US
    if that's the case, oil level should have been checked at least 3-4 times in those last 1500 miles (every fueling).
  9. bisco
    48,969
    what does a non rusted out oil dipstick indicate?
  10. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    The theory behind the rusted dipstick was that while attempting to "run it down the tube and into the pan" that it wouldn't get into the pan due to the fact that it had rusted out, thus showing low/no oil. (happened to a buddy before on a different vehicle)
    The funny thing is that, once I started thinking about this last night. the last 3 or 4 times I've changed the oil in the vehicle, only about 2 to 2.5 quarts drain out of the pan. I've ALWAYS ran Mobil 0W-20.
    I'm curious as to why some of the answers were to change oil weights? Doesn't the owners manual call for 0W-20?
  11. bisco
    48,969
    heavier oil will burn less. can you give us some idea how far down the dipstick it goes when you check it each day?
  12. Den49
    Den49 Member
    498
    267
    Maryland
    Idea: Time for a new car.
  13. Easy Rider 2
    1,584
    257
    Ocala, FL
    Yes in general but that only helps when you catch the excess consumption early and it hasn't gotten too bad yet.
    "High mileage" oil of a thicker grade would be even better but the same limitations apply.
    SUDDEN big increases in oil consumption that aren't because of a leak often are caused by a stuck ring.
    If that's the case, a shot of thinner oil would actually be better.
    You need to find the CAUSE before you prescribe a fix.
  14. ETC(SS)
    6,493
    Here's what I would do:
    1. Reset the "A" or "B" trip odometer to 0000.0
    2. Ensure that the oil is topped off.
    3. Drive the car until there's a measurable amount of oil that's been lost.
    When you have a more accurate burn rate....get back with us and we'll be able to more intelligently advise your next course of action. For the G3, the "acceptable" burn rate in the manual is REALLY high. Something like 1qt/600 miles or some crazy value like that.
    If you know why, then you know why.
    Get back with us, or don't.
    Your call.
    Good Luck!
    Aaron Vitolins likes this.
  15. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    Did you mean 1qt/6000 miles?
    1qt/600 miles seems crazy *L-O-W* to me.
    I'll take your reset mileage advice & start checking it on a daily basis. Stay tuned...
  16. bisco
    48,969
    again, how many miles Did you drive in those 3 weeks?
  17. Easy Rider 2
    1,584
    257
    Ocala, FL
    We are talking about the oil loss rate.
    It really IS 600 miles.
    You have to lose a quart in less than 600 miles for them to consider the LOSS RATE to be too high.
  18. Mendel Leisk
    38,239
    One quart per 600 mile is the rate Toyota tosses out in the owners manual. And it's pathetic butt covering. They really should put that in page one of their glossy brochures, see how that goes.
  19. bisco
    48,969
    42,000 miles / 20 months = 2100 miles per month x .75 = 1575 miles. it's possible you went 1800 miles in those 3 weeks, so, you're good to go.
  20. Cdubya69
    Cdubya69 New Member
    Peoria, IL
    O.k., finally got around to changing the oil in the Mrs' car tonight. It has exactly 175,900 miles on it, so I'll keep you abreast of what I discover.
    The 1 qt. in 600 miles thing is mindboggling!!
