Loss of regen brakes and traction assist.
Discussion in 'Gen 3 Prius Technical Discussion' started by Feri, Jun 6, 2014.
  1. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Just letting Gen III drivers know that using an OBDII splitter and two gauges can sometimes cause a loss of regen braking and traction assist accompanied by various yellow lights on the dash. It can be restored by switching the vehicle off, unplug the OBDII splitter and restarting the car. This has happened to me on three seperate occasions.
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    This happened to me today with just a single OBDII reader and torque app. It started with the ABS light and traction lights going on and then progressed to the hybrid system warning and low oil pressure warning. My dash was lit up like a Christmas tree! It totally freaked me out as we're going on a long trip tomorrow. The only thing that I can think of causing this is that I checked a box to turn off the OBDII to save power in the torque app. I haven't tested it out yet.
  3. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    I had a similar experience, when I used the Chinese OBDII Aadapter. After the replacement with better chip and design, all troubles dismissed.
  4. TomB985
    TomB985 Member
    137
    67
    Isanti, MN
    It makes sense to me that the OBD interface could cause some problems. The software is capable of accepting commands from a scan tool through that interface, and some of those commands could shut things down if done at the wrong time. I remember doing the same with my AutoEnginuity on my old Ford Contour. I was playing with options going down the road while my wife was driving and I commanded a badly wrong timing advance and the whole thing shut off. My wife wasn't happy with me.
    I've noticed that with my cheap OBD interface installed my reverse beep is down to one beep. I wonder if this is the same thing.
  5. Feri
    Feri Active Member
    761
    144
    That's odd if you didn't issue a command. The problem I've had and I presume others as well, have been while passively using the gauges just for data readout while driving.
  6. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    I maybe totally, wrong but isn't the ScanGauge actually "interogate" the bus sending in some code basically "give" this or that data ???
    In which case a passive spliter can screw up (sometimes badly) what goes on the bus ...
    Feri likes this.
  7. Feri
    Feri Active Member
    761
    144
    True!
  8. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I've used a Scangauge II on my 2010 Prius since I bought it in June 2009, prior to that had one on a 1997 Subaru Impreza which I gave to my daughter to use on her former Saturn Ion (thank God she sold that before the recall and had no incidents), she's using it on her 2009 Chevy Aveo and I have one on my 1996 Chevy S10. It has been the only monitor I have used and has done nothing but improve my mpg with no adverse effects. I've seen plenty of cheap and homemade units, I'm no programmer so I'll stick to what works for me.
  9. Fore
    Fore Don't look back!
    494
    107
    I've been using UltraGauage for awhile now with no problems!
