Low-Beams & Parking lights out at same time
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by waters511, Apr 26, 2015.
  1. waters511
    waters511 Junior Member
    Memphis
    Just replaced my headlights within the past 4 months. Last night, I go to turn on headlights and nothing turns on, not even the parking lights. High beams work just fine. Checked fuses this morning - fuse for low beams is fine. Not sure why all 4 lights would fail at the same time? A fuse was all I could think of besides pure coincidence. Any help on ideas is appreciated!
    Edit: Relay clicks when switch is turned on and dash dims as normal.
    #1 waters511, Apr 26, 2015
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Do you hear the relay click when you turn the switch to the lowbeam position? If not, then you still have a bad fuse, a bad relay, or a bad combination switch.
  3. waters511
    Memphis
    Yes, it clicks when turned into the first position.
  4. xliderider
    7,848
    3,102
    Honolulu, HI
    How did you check the lowbeam fuse? Visually, or with an ohmmeter/multimeter for continuity?
    If you have a meter, check the fuse and both headlight bulbs for continuity. Then if all is good you can rule them out as the source of your problem.
    At this point, it's probably a bad fuse.
  5. waters511
    Memphis
    Don't have one - just visually checked - but I'm sure FIL has one. I'll have him check and see if anything comes up. If nothing - I'll be back :). Thanks!
