Lowering Power Driver Seat
Discussion in 'Gen 3 Prius Accessories and Modifications' started by chrisj428, Aug 19, 2014.
  1. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    On my 2010 Five, I was able to ratchet the manual seat down lower than I can on my 2014 Five with the power seat.
    While 6'3" shouldn't pose a problem in the Prius, my height is from the waist up. Has anyone found a way to lower the seat brackets in order to provide more headroom?
    NR427 likes this.
  2. NR427
    NR427 Member
    142
    100
    Utah
    I had the same problem in my 2010 Camry. I ended up trading it for a prius c that fits me better!
  3. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    I don't see a way that this could realistically be done on the power seat. My recommendation (if it bothers you enough) would be to get a manual seat. I believe it may be capable of dropping further, and I can see from the construction that it would be much easier to modify if necessary.
