1. Offline
    minglee012 New Member
    Start a Conversation
    Apr 25, 2012
    so cal
    Your Vehicle Year:
    how do you reset the maintenance light on a prius c? i have tried holding trip and starting the car in odo mode but it doesnt work. i have a prius c three with smartkey and navigation. thank you for your help.
  2. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    did you follow the instructions on pg.349 of your owner's manual?
    why is yours on?
  3. Offline
    Apr 25, 2012
    so cal
    Your Vehicle Year:
    thanks for the page number, i was looking for it under a different name. i just passed 4500 miles, so its about time the light/message popped up.
  4. Offline
    SquallLHeart The Techie Guy
    Mar 10, 2012
    747
    181
    San Jose, CA
    Your Vehicle Year:
    why wouldn't it be on?
    it counts miles.... he's probably at or reaching the 5K mark on his odo.. yes.. at 4500 it'll start warning ya... and at 5000. it'll stay on.
  5. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    I was just asking to see if he had done something else that may have triggered it instead. Had to ask to be sure it was a normal sequence he was seeing for it to be on.
  6. Offline
    Mar 10, 2012
    747
    181
    San Jose, CA
    Your Vehicle Year:
    it only counts miles... there wouldn't be any other reason why it would turn on.
    yes.. it's nothing more than a mileage counter.
  7. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    on a few other cars I've owned, the maintenance minder was triggered by a variety of factors other than just miles. in all honesty, I hated that they did that. are all toyotas triggered strictly on miles alone? I know my FIT varies as well as a few BMWs.
  8. Offline
    Mar 10, 2012
    747
    181
    San Jose, CA
    Your Vehicle Year:
    just miles.
    for everything else.. there's mastercard.. lol.. j/k..
    anyway.. there's the CEL for everything else.
  9. Offline
    cwerdna Senior Member
    Sep 4, 2005
    11,675
    1,668
    SF Bay Area, CA
    Your Vehicle Year:
    That's quite a bit in such a short time.
    Maybe you're almost a version of 2 fas 4 u. He traded in his 09 Prius w/465K miles (!!!) for a '12 Prius v.
  10. Offline
    xsavior Junior Member
    Apr 13, 2012
    Vermont
    Your Vehicle Year:
    Is there actually any maintenance required at that point? The only thing I have been hearing, for the most part, is oil at 10,000 or 12 months...
    1 people like this.
  11. Offline
    vinnie97 Whatever Works
    Mar 20, 2010
    854
    67
    Somewhere out there
    Your Vehicle Year:
    Tire rotation and fluid check is all that's "required" @ 5K.
  12. Offline
    pmike New Member
    Feb 29, 2012
    34
    Central Florida
    Your Vehicle Year:
    On the 2012 Honda's there are a number of factors which indicate maintenance is due, bring us to a 9k oil change. With most sources recommend tire rotations at 5k it makes sense to have maintenance schedules based on 5k increments. We have this problem with our work vehicles, shop will do free rotate and balance every 5k but we only need oil changes every 8-9k, they refused a early wear warranty because we were only rotate and balancing them every 8-9k not 5k per their warranty docs. I would probably rather the 5k increments. The Honda iMID gets really annoying after you get the maintenance minder down to 15%. You have to clear it every time you start the car.
  13. Offline
    donny612 "Captain Jack Sparrow"
    Apr 12, 2012
    104
    Apex, NC
    Your Vehicle Year:
    Dealer set me up with a "1st service" appointment...oil change, tire rotation yadda, yadda, yadda for 5000 miles when he delivered the car.
    Back in the day we always did an early oil change on a new engine to make sure that we got all the little metal pieces left over from engine manufacture, which we hoped were trapped in the filter and changing early decreased the possibility that the metal filings would get back into the engine. After the 5K change I go back to the recommended interval.
  14. Offline
    Mar 10, 2012
    747
    181
    San Jose, CA
    Your Vehicle Year:
    fyi.. if you guys are still looking for how to reset the notification...
    look on page 349 of the owner's manual.
  15. Offline
    rlalford New Member
    Mar 14, 2012
    31
    Durham, NC
    Your Vehicle Year:
    The 5,000 mile maintenance message comes on at every startup after a certain point; simply change the display. I took mine in yesterday for first maintenance; I was told that the tires needed to be rotated (free under warranty). The first oil change isn't for another 5,000 miles. :)
  16. Offline
    Mar 10, 2012
    747
    181
    San Jose, CA
    Your Vehicle Year:
    uhh... simply changing the display.. doesn't reset the maintenance data... and it'll come up every single time you start up the car still.. that's not what you want..
    certain point? it'll say maintenance required soon.. at 4500..
    then change to maintenance required a 5000.
    just read page 349.. it'll tell you know to reset the maintenance data.. you need to do it for it to do what it's supposed to do... remind you every 5K miles to do maintenance..
  17. Offline
    Jutty04901 New Member
    May 14, 2012
    Waterville ME
    Your Vehicle Year:
    They do a tire rotation at 5000, and a few other things. I just had my 5000 mile service this morning.
  18. Offline
    Mar 10, 2012
    747
    181
    San Jose, CA
    Your Vehicle Year:
    yeah.. top off your fluids like windshield wiper stuff.. and just a general overview of the car... a health check too.. sure.. nothing fancy schmancy.. much.
  19. Offline
    sinner949 Junior Member
    Apr 9, 2012
    Riverside, CA
    Your Vehicle Year:
    Im at 25,548 miles in my c 4 since april 7th. So needless to say no more free service for me. Thanks for this thread because I really didn't want to have to pay an arm and a leg to hey it reset through the dealer.
  20. Offline
    Mr Incredible Effin' Golden
    Jun 23, 2008
    593
    261
    Neb
    Your Vehicle Year:
    While the boot screen appears when you turn on your car, press the TRIP button 3 times and hold it down on the third press. 55555, 44444, 33333, 22222, 11111 will appear and progress down to 00000. When the 00000 goes out and the screens return to normal you may let up on the TRIP button.
    At 4500 miles the reminder begins at the startup of the car. You can choose to either press DISPLAY once to get back to your normal screens, reset it entirely to make it go away (you may reset at the oil change and/or tire rotation), or ignore it/turn off your screens.
    On the C, it only goes by 5k mile intervals. That is all. No other parameters are present.
Share This Page
