Major, Major Flaw....OR deliberate? Base Model Headlights
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Prius Five Guy, Jun 2, 2014.
  1. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Praying that a Toyota employee; preferably a Prius product manager stumbles across this post and makes an effort to share this with his/her immediate team.
    (Currently own a 2013 Plug-in base model w/ 15,000 miles year to date)
    Drove from LA > Las Vegas roundtrip during evening hours and was shocked how WEAK standard headlights are. I have perfect vision but was forced to activate my high beam light settings to stay in my lane and NOT DRIVE OFF THE ROAD.
    Plenty of reflectors on Interstate 91 and 15 but the wattage/range on headlights for std. prius model is grossly inadequate and a MAJOR safety issue in my opinion. BUMMED.
  2. kenmce
    kenmce High Voltage Member
    1,509
    493
    NY
    You have the halogens? Could they be aligned way too low??
  3. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    They are the same wattage and range as all the other bulbs. The reflector design is not great, but not that bad. Remember any vehicles from the 90's and before? My DeLorean at night looks like there are 2 keychain flashlights making 2 dots on the road pretty close ahead.
    You can try the higher kelvin temp bulbs. They burn faster so you will have to replace them more often, but because of their blue-ish white hue, the human eye is more receptive to the colour and makes it look brighter, even though they generally aren't.
    All of this assumes your headlights ARE aimed properly. Pull up on a flat surface 25ft away from a wall. Make sure the light only dips an inch or two at 25ft from the starting height.
    Prius Five Guy likes this.
  4. bvoyles
    bvoyles Junior Member
    22
    San Diego
    I agree with this post, most likely the alignment. I have a base model and the headlights are quite bright. Actually a couple of times vehicles have flashed their lights at me thinking my light were on high beam (maybe mine are adjusted too high).
  5. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Maybe? I'm going to call my service advisor and see what can be done. Thanks for your input!
  6. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    There is just a little thumb adjust wheel on each light that raises and lowers the beam. Do you have anything nearby with a flat area away from a building? I find a Walmart or any big-box store generally has a flat loading dock area with a nice big tall wall. They work great for aiming headlights. :)
  7. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Where exactly is this "Thumb Adjust?" I know there is an adjust for interior gauge/dash board lights.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It should have been typed in Japanese then, that is the language they speak. US Toyota employees will be Marketing, not Engineering. (There is no evidence at all that anyone at Toyota Japan reads any of this)
  9. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Doh!!!!
  10. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    It's on the back of the headlight housings.
    I've done the H11 to H9 bulb conversion, where you substitute a 65w halogen bulb for the 55w H11 bulbs. Link is in my signature below. The light output is quite good now.
    SCH-I535
  11. bisco
    48,945
    i have no problem with the headlites either. i also get flashed frequently. i hope the adjustment works out for you!(y)
  12. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    As long as you are the flashee, not the flasher, which might result in arrest! :ROFLMAO:
  13. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    Toyota should have taken the LED headlight and given them to Prius... ;)
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    They did!
    You have to by the top model Prius "Five" or PIP "Advanced" to get them... and they are awesome BTW!
    HID's make a good inexpensive and easy upgrade to the Gen III Prius. Just be sure to get a bulb designed for projector systems so you don't get ground shadows.
  15. LA2014Prius
    103
    2014 Prius Plug-in
    I meant if Toyota put LED headlight in all trims of Corolla, if they do that for Prius, that will be really nice... ;)
    LEDs use less electric... Can go another .05 mile... :)
  16. donalmilligan089
    239
    22
    virginia usa
    I have the same beef .I had my head lights measured and they are set the right height but are inadequate, especially in hilly terrain.Don
  17. GregP507
    GregP507 Senior Member
    3,002
    480
    Keeping the lenses clean is very important. Even a small amount of mud or insect debris can reduce headlight output considerably. Also, in daytime driving-light mode, the headlights are much dimmer than when the headlights are switched on.
  18. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Glad someone agrees.....
  19. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    I have no problems with my lights in hilly/mountainous Utah. In fact these are the best I have had in any car I have owned.
  20. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I assume since the Corolla now has LED low beams standard, it will eventually be integrated into other models. Or is that too much of a leap to expect?
