make a Prius rear sleeping bed platform for two, step-by-step walk thru
Discussion in 'Gen 3 Prius Accessories and Modifications' started by keithm, Jun 3, 2012.
  1. keithm
    keithm New Member
    auburn, wa
    Enclosed is a step-by-step walk thru to build a 6 foot 4 inch flat cargo area that would facilitate a 2 person sleep area. The rear cargo area (behind the drivers seat) has a length of about 5 foot 3 inches. The desire would be to extend this length by a foot or so to allow 2x standard backpacking mats side-by-side to accommodate a flat sleep area within the Prius. The goal of the build includes:
    1. Design and fabrication of a sturdy, stable platform.
    2. Can be build with common materials and tools.
    3. The platforms can be stowed (when not in use) within the under-floor hatch, out of sight.
    4. Can be set-up without too much hassle or time.
    5. As a secondary consideration, is adoptable for the 2010 Toyota RAV4 (V6) also. The RAV4 has about the same cargo area of the Prius.
    The annotation describing each figure will occur at the bottom of the picture.
    View of prius cargo area with back seat folded down
    5 foot 2 inch (flat distance) distance from rear of cargo to folded back seat rest
    1 foot 5 inch excess distance for platform. Just need to consider design options that meet the criteria listed above.
    Camping mat at 6 foot long 20 inches wide
    another compact inflatable backpacking mat
    20 inches wide with added pillow sleeve. add clothing between mat and sleeve to make a pillow
    mat in cargo area of prius
    overhang needing support, about 1 foot
    support platform .5 inch laminate oak from Home depot
    Mark a 22 inch x 15 inch section
    quick fit, will need to mount here
    .125 inch thick by 2 inch wide Aluminum strap, from Home Depot
    Mark for trim 4 inch length's 3x total parts
    Cut with band saw, fine tooth blade
    round sharp corners
    deburr parts
    use this tool to determine mounting fastener grip length
    fasteners from Home Depot
    diameter of threaded shank at .1845
    Drill slightly larger than fastener shank at .186 inch
    set-up for drilling holes
    drill holes, 2x holes per part, .5 inch from edge of platform
    using flush manufactured head fasteners, need countersink in straps
    use this piloted countersink tool bit, 100 degree
    machined straps completed
    close-up of fastener installed
    deburr drill exit side
    mount straps on platform
    quick fit check in prius, A-ok.....
    add a 4 inch angle to the middle strap, the extended flange will fit between the rear seatback and the head rest, stabilizing the fore-aft movement of the platform
    drill
    mount like this
    Now for the front platform attachment, I'll use the passenger headrest as the attach point
    strap kit items
    100% nylon thread, 3/4 inch buckles and 3/4 inch nylon straps
    stitch the part like this, one hard attached female buckle, one threaded female buckle, one adjustable male buckle.
    melt the ends of the strap with a soldering iron
    like this gives the polished look
    hand sew the end of the female buckle to the nylon strap
    finished product, repeat 3x more times total
    length ~9 inches
    strap slots in the platform to thread in the 3/4 nylon strap, use router bit from dremal tool
    hard attach the nylon strap at ~18 inches, add male adjustable buckle
    finished product, now for mounting
    1. Remove the rear shoulder restraints, it's ok they re-attach easy, shift fwd seats all the way fwd and backrest fwd.
    2. fold rear seats down
    3. Attach the headrest buckles
    4. mount the platforms, attach the headrest buckles, adjust front strap length till level
    rear view
    about 6ft 4 inches of total usable length
    add floor and/or rear cargo mats over the joint as an option
    backpacking mats inlayed
    View from front seat
    view from outside
    with cargo cover, for some privacy
    gap between mat top and cargo cover
    inside view
    RAV4 rear with seats down
    5 ft 4 inches from rear to top of folded rear backrest
    platform installed, no modifications to platform by the way, just so happens to fit
    view of the angle added to stabilize the fore-aft movement, same as prius
    both platforms installed
    rear view
    mats in RAV4
    front side view of mats on platform
    view from passenger seat
    platform ready to go under cargo storage area of RAV4
    fits well in RAV4, no issues
    Prius storage, no issues
    My intent is to keep one platform in the Prius and one in the RAV4 for emergency usage and transfer one to the other car for a long distance road trip.
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Sweet! Thanks for the details.
    I am lazy and just used a Coleman Twin-sized air mattress. It is thick enough when blown up that you can simple put your backpacks or other gear in the rear footwells and the mattress will be supported quite well. It works in a pinch but your idea is quite nice and easy to stow.
  3. wotcher
    wotcher Member
    403
    97
    16
    LA
    very nice.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Habitent would surely complement it.
    beradical and Irakli Kobiashvili like this.
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Welcome to the Hotel California Prius!
    How much per night? Is HBO included.... :D
    priuscatprimeguy likes this.
  6. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I do plan on camping in it later this year and "borrowing" a plug from an RV. The 7" Nav unit will play dvd's if the parking break is on ;)
  7. keithm
    keithm New Member
    auburn, wa
    That would work for a planned trip. The platform in the thread is now in the cargo under stowage floor. It can be used in a pinch when needed. I also keep the mat and sleeping bag. You never know......
  8. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    How has no one complemented you on the amazing motorcycle? KLR650?
    Simbaboy likes this.
  9. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    Impressive! Great project, well documented, thanks for posting! I'd be interested in doing it but I'm only a little short-arsed Brit (5'5") and find plenty of room in either of the front seats of my 2009 Gen II, or in the back with the seats folded down!
  10. serval111
    serval111 New Member
    I would love to see the original post, but I am disappointed because the photos are all red-X'ed out. What does that mean? (I am signed in).
  11. Maarten28
    Maarten28 Active Member
    414
    223
    Netherlands
    The images are hosted on Photobucket and they changed their site some time ago. I believe you have to get a paid subscription now or they withhold your images.
  12. adamdreier
    adamdreier Junior Member
    @keithm How do you like it now? Does it hold up? Considering starting the build later this week. Thanks.
  13. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    That's a great step by step progression. Thanks for sharing.
  14. The Big Sleaze
    276
    60
    'frisco
    2020 Prius
    Two Eco
    seems like could ALMOST be "road worthy" within reasonable limits, like up to 65mph, with a few mods like a jack to keep lid open, etc.
