Map LED light and Cabin LED light blinking problem
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NguyenCB7, Jul 23, 2016.
  1. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Any have problems with blinking LED map lights and Cabin light? Only the passgener map side blinks hahaha... I hear about resistors or what not but these are for exterior lights like turn signals. Anyone have this problem and does anyone have a fix? Thank you in advance.
  2. krmcg
    2,592
    2,388
    Whittier, CA
    I have no issues with my LED upgrades
  3. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Maybe is the bulbs I have, Which do you use? I have the rxtra brights ones from Amazon.
  4. krmcg
    2,592
    2,388
    Whittier, CA
    I went with Amazon too. The ones pictured in the thread.
  5. voerman
    voerman Junior Member
    NC
    Four Touring
    You most likely have a bad bulb. Flashing is a common failure mode for LEDs.
    Lou
    krmcg likes this.
  6. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    You have a bad ground connection somewhere in the loop, I thought the overhead was the easiest to not get a good connection, but any of the bulbs might be problematic, also, might be one bad bulb, 10$ for 8, get another set and try again, oem is viable, some knock off might take tries...
    NguyenCB7 likes this.
  7. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    If you put in two of the same bulb try swapping them. If the flashing stays with the same bulb then it is probably bad.
  8. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Thank you for all the answer, Yea it was the bulb. siwtched it with another one of the same, does not blink. Sucks that I have two of them that are faulty.
    krmcg likes this.
