Master warning light and air bag light ups
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hasnain khawaja, Sep 6, 2014.
  1. Hasnain khawaja
    Hasnain khawaja New Member
    I wash my Prius 2007 suddenly I drop some water under front passenger seats where may b some devices installed I even try to dry but Iam not sure it's fully dry but When I start my car some warning comes up which are red triangle airbag light and small car icon I don't know what is this help me to resolve it
    48,986
    hmmm, this is going to take some thinking. any way the water worked it's way back to the hybrid battery?
  3. Hasnain khawaja
    Iam not sure
    48,986
    about how much water spilled, pint, quart, gallon?
  5. bisco
    48,986
    you may have to remove the drivers seat and wet vac it, then hit it with a portable electric heater to dry it out.
  6. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Disconnect the 12v battery first. Look under the seat for the wires with the yellow connectors. These are the air bag wires. Follow them as far as you can go. Disconnect them and blow them out with an air hose. Vacuum up as much water as you can. Reconnect 12v. The air bag lights may need to be scanned and or cleared.
  7. Hasnain khawaja
    Yeah it's around gallon
  8. Hasnain khawaja
    Thanks for replay I don't find any yellow connectors and what u think it may damage something serious aur expensive repair required ?
  9. TampaPrius.com
    461
    296
    Tampa, Florida
    undo the 4, 14mm bolts holding the passenger seat in place and remove the seat. Make sure the 12v battery is disconnected first. The yellow connectors are up in the seat bottom. They will have to be disconnected to get the seat out. If your car has JBL there will be an amp on the floor there also. Vacuum as much water up as you can and park it in the sun with a fan on it.
  10. Hasnain khawaja
    Yes you got my problem that amp aur one more thing is wet do u think it's long to repair and warning messages becouse of that amp aur that hardisk ?
  11. TampaPrius.com
    461
    296
    Tampa, Florida
  12. Hasnain khawaja
    How much it will cost ?
  13. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    I wouldn't replace anything until you find the source(s) of the water infiltration. Like others have said get everything dried out first and then start checking for your leak(s). Get your codes read, and report back. Water leaks have been reported on this generation of Prius. I would be examining your 12 volt battery area along with the area under your spare tire for evidence of water.
  14. bisco
    48,986
    he accidentally dumped his wash bucket, there are no leaks. so to speak.
  15. bisco
    48,986
    i'm thinking the codes will clear after you dry things out. you may need a code clearer, or perhaps disconnect the 12v negative, if they don't go out on their own.
  16. Hasnain khawaja
    Thanks for replay I change my navigation box everything is fine but Iam getting problem with Bluetooth it's contected properly but no voice coming
  17. Hasnain khawaja
    Thanks for replay I change my navigation box everything is fine but Iam getting problem with Bluetooth it's contected properly but no voice coming .
