1. Offline
    n3ok318 New Member
    May 16, 2004
    Kirkland, WA
    Hi, I was wondering how fast Prius could go.
    What is the official max speed and how fast have you guys gone so far?
  2. Offline
    DicksieLee New Member
    Mar 29, 2004
    37
    Hilton Head, SC
    Good Question! I do not know the official maximum speed but I have hit 77 mph on I95. However, that was early on. Now, due in large part to the feedback provided by the fuel consumption screen, I have become a kinder, gentler and slower driver. That is perhaps the most powerful fuel-conserving feature of my 2K4 Prius. Witness that my average tank mpg has steadily risen with each fillup from 41 mpg with my first to 52.6 mpg with my most recent.
    Oops! That was beginning to sound like a sermon. Sorry.
  3. Offline
    victor New Member
    May 18, 2004
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    In Europe, the Prius is limited to 170Kmh which is about 106MPH. During the test drive I went to 150Kmh about 95Mph without noticing it.
  4. Offline
    • Moderator
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    4,986
    718
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    US Prius are limited to the same - and this is for powertrain reasons. At this speed, MG1 and/or the ICE are at their maximum speeds. If anyone here has a copy of Wayne Brown's Prius HSD simulator, it would show which is at maximum speed at which MPH.
    -Rick
  5. Offline
    bookrats New Member
    Mar 12, 2004
    2,843
    Seattle, WA
    With or without the optional JATO unit attached to the back? :flame:
  6. Offline
    mdacmeis New Member
    Mar 30, 2004
    133
    Michigan
    This may be correct, however there is another possible reason for the 106 mph speed limit - tire ratings. 106 matches the speed rated certification for the tires used.
  7. Offline
    MarinJohn New Member
    Feb 6, 2004
    3,947
    300
    On a recent trip I wanted to see if the digital readout on the speedo went to three digits so I got my '04 up to 103mph, driving with one hand while taking pictures of the display with the other. Pictures did not come out, but I can verify we have a three place digital readout!
  8. Offline
    Whitey New Member
    Jun 3, 2004
    33
    All you have to do is flip to km/h to see if 3 digits can be displayed.
  9. Offline
    Wolfman New Member
    Nov 28, 2003
    1,205
    Paradise, TX
    Speaking of pressing the display button, it was rather fun to be able to legally drive at 100 in Canada, 100kph that is. :mrgreen:
  10. Offline
    Frank Hudon New Member
    Jan 11, 2004
    4,146
    the 2k1 Prius will do 152K for sure. Lucky no radar traps on that road that day.
  11. Offline
    Sun__Tzu New Member
    May 4, 2004
    314
    Bethesda, MD
    Hahaha. That seems like a comically dangerous thing to have done. I wonder how you would've explained it to a police officer if he happened to see you pulling that stunt? : )
    "What? Oh, I was taking a picture of the spedometer."
    "Huh? Well, I wanted to see if it would show a 3rd digit."
    "Yeah! It sure did! 103mpg easy!"
    "What? Its a 35mpg zone?"
    "And yeah, that's an open beer, an unregistered firearm and a box of illegal fireworks in my back seat. What's your point?"
    Kinda seems like something Kramer would've tried on Seinfeld : )
  12. Offline
    Jan 11, 2004
    4,146
    Prius Classic 152 KPH MG2 5500 RPM ICE 4500 RPM MG1 1900 RPM
  13. Offline
    • Moderator
    Dec 8, 2003
    4,986
    718
    Your Vehicle Year:
    Actually, S rated tires, which our cars have are rated to 112mph, which is where you'd find the speed limiter in most cars.
    According to the NCF guide, the top speed is actually rated at 103mph.
    In the case of our car, it really is the maximum speed of the powertrain. You'll need to recall that the Prius has only one fixed driveline ratio, and that only torque can be directed through the planetary gears of the PSD. The speed of each component in the PSD is directly relative to each other. In the case of the Prius, we'd reach maximum speed for one of three reasons:
    1. Speed limiter for tires - while I'm not discounting this theory completely, it's a bit conservative for S rated tires.
    2. The ICE and MG1 have both reached their maximum speeds - 5000, and 10000 rpm respectively - simultaneously. This could be possible, but I don't have the brain-power to compute this scenario.
    3. MG2 has reached it's maximum speed of 6000 rpm (trying to confirm this number). This is most likely true after looking at below.
    Other info for people who wnat to do the math for gear ratios and max speeds:
    Planetary gear teeth count (same on '03):
    Ring Gear: 78
    Pinion Gear: 23 (there are 4, but that doesn't matter for conversion)
    Sun Gear: 30
    Chain Drive:
    Links: 72 ('03 had 74)
    Drive Sprocket Teeth: 36 ('03 had 39)
    Driven Sprocket Teeth: 35 ('03 had 36)
    Counter Gear Teeth ('03 has same count):
    Drive Gear: 30
    Driven Gear: 44
    Final Gear Teeth ('03 has same count):
    Drive Gear (on counter's driven shaft): 26
    Driven Gear: 75
    Final Gear ratio (per specs): 4.113 ('03 was 3.905)
    I believe the difference in gear ratio comes from the change in teeth count at the chain drive between MG2 annd the counter gears.
    But now, back to the point. Knowing that our P185/65-15 tires revolve at about 849 revs per mile or about 849 rpm at 60mph, we can then derive how many MPH is possible at 6000rpm with MG2, which is about 103mph.
    Using (((MG2 RPM / Final Drive) * 60 minutes) / Tire revs per mile) = Max MPH
    (((6000 / 4.113) * 60) / 849) = 103.09 mph - just shy of 166 Km/h
    Now if some could exceed that by just a bit, we may be looking at some "tolerance" for MG2's max RPM, or a possible different revs per mile figure for the 16" wheels (and a recalibrated spedo to match).
    Ok - looks like I've got way too much time on my hands... LOL - hope this helps iron it out.
    -Rick
  14. Offline
    Ray Moore New Member
    Mar 28, 2004
    827
    Texas Hill Country
    Your Vehicle Year:
    I've done 95 in mine and was pulled over doing 81. I didn't get a ticket. I really think he just wanted to check out the car. I enjoyed telling my 13 year old stepson about that one as he jokes about us being flipped off by passing snails when I drive for mileage. He's just used to his mother's driving. At 95 the car seems very smooth with plenty more to give and oddly quiet for that speed in any vehicle.
  15. Offline
    n3ok318 New Member
    May 16, 2004
    Kirkland, WA
    I guess it's not 85MPH. Someone told me that Prius can only go up to 85MPH. I guess 106MPH is the most out of 1.5L. It's pretty decent.
  16. Offline
    jimvitz New Member
    Dec 4, 2003
    89
    Oak Park, IL
    I definitely think "Mythbusters" should re-do their JATO show with a Prius just to see! :wink:
  17. Offline
    8AA New Member
    Feb 29, 2004
    497
    Maryland
    Your Vehicle Year:
    According to this model, the 2004 could theoretically go 129 MPH:
    Planetary Gear System of Prius
    However, this would assume that MG1 has a maximum speed of 7500 RPM, which does seem high. I tend to agree with Rick, that MG1 is limited to 6000 RPM, and therefore the 2004 is powertrain limited to 103 MPH.
  18. Offline
    victor New Member
    May 18, 2004
    414
    Translated from the German Technical docs.
    "The MG1 and MG2 are located in the hybrid transaxle and both are light, high efficiency AC syncron motors with permanent magnets. There is no special maintenance required.
    MG2 is permanently connected to the front wheels and therefore drives the wheels directly. During regenerative breaking, MG2 is used as a generator to provide power to recharge the HV battery. MG2 also provided the drive in reverse by reversing its direction.
    MG1 loads the HV battery and, driven by the petrol motor, provides power for MG2. MG1 is also the starter motor for the petrol motor.
    Service data MG1
    Voltage 500V AC
    Max output power 37.8kW @ 9500 rpm
    Max torque 45Nm @ 0 - 6000 rpm
    Max rpm 10,000 rpm
    Function Power generation
    Starter motor
    Service data MG2
    Voltage 500V AC
    Max output power 50kW @ 1200 - 1540 rpm
    Max torque 400Nm @ 0 - 1200 rpm
    Function Power to wheels
    Generator for regenerative breaks "
  19. Offline
    • Moderator
    Dec 8, 2003
    4,986
    718
    Your Vehicle Year:
    I think vapor_pearl meant that MG2's max is 6000 rpm.
    I too have only found a solid number for MG1 being 10000 rpm - and the US docs didn't specify torque figures for it either. While it can power the car in the hypotetical heuretical mode (overdrive), it's not documented that it does so.
    Now the debate goes on that the max speed is much less if the battery is discharged, however :) (see other threads)
  20. Offline
    8AA New Member
    Feb 29, 2004
    497
    Maryland
    Your Vehicle Year:
    Sorry, I did mean the motor that is directly connected to the front wheels. Maybe now that I have been embarassed here, :oops: I will remember that MG2 is connected to the ring gear and MG1 is connected to the sun gear.
Share This Page
