Mazda Demio SkyActiv tops Japan's "Eco Cars" survey, Toyota Prius #2
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cyclopathic, Sep 6, 2011.
  1. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    I don't know anything about a 12:1 engine, perhaps cyclopathic can send a link so we can learn more. Ford was going to make a 13:1 version for regular gasoline and that suposedly had 3% less fuel economy and 5% less peak torque than the same size 14:1 running premium. I would guess the drop from 13:1 to 12:1 would be even smaller percentage change since both are regular gasoline. The sky-g on intake can switch between otto and Atkinson cycles so a 14:1 engine running regular might just have to give up its otto cycle in valve timing. This would be a less than optimal engine design though.
    Given the testing methods, I doubt it will get us to 56% improvement in epa highway mpg. This should come in around 40mpg highway like the cruze and focus it is competing against. Maybe 14:1 compression would add 2 mpg.
  2. Trollbait
    11,327
    The higher compression ratios are do to the use of direct injection.
    [ame=http://en.wikipedia.org/wiki/Gasoline_direct_injection]Gasoline direct injection - Wikipedia, the free encyclopedia[/ame]
    Improving Internal Combustion with Direct Injection - TechConnect Online News Blog
    Many of Toyota's V6s have recommended mid-grade. Owners probably didn't even know that. I think using it would just generate the backlash caused by premium. I suspect Mazda will go with premium. They are already have made a sporty niche for themselves, and premium for a sports car is more acceptable than in a family car. Some models already are premium fuel. Plus, it further differentiates their engines from Ford's GDI.
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    the advantage of higher grade is that engines specifically designed for premium can use higher compression and get higher thermal efficiency. If engine designed for regular, there will be no advantage from putting premium in. Also advancing timing improves efficiency, so the engines which can handle both regular and premium will do better on premium, YMMV.
  4. Trollbait
    11,327
    One of the flaws with E85 here is that the flex fuel engines have a native compression for regular gas. If they had the compression ratio for premium gas, they would be taking a lower reduction in fuel economy when burning E85. Designing them to run on E85 as baseline and then adjusting for gasoline would have been even better.
  5. austingreen
    13,533
    4,063
    Austin, TX, USA
    Designing a normally aspirated engine for e85 would leave it starved for power when running gasoline. With turbocharging and injection the engine can adjust to the blend in the tank. Ford even has a dual tank gasoline/e85 design that greatly improves high power efficiency by using more e85 to cool the engine when needed.
  6. Trollbait
    11,327
    Why so?
    If such an engine existed, wouldn't it dial back the timing down for the lower octane fuel? Is the power delta between the two fuels just to great for the engine?
    There are a couple of cars capable of running on straight gas through E100 in Brazil, but it sounds like the engine is designed for E20 or E25.
