1. Offline
    Brett. Junior Member
    Start a Conversation
    Mar 15, 2012
    137
    Your Vehicle Year:
    Every bump, slow or fast from left or right side of the car there is an obvious metallic clunk or rattling sound.
    Anybody with a Gen 3 have problems with premature suspension failures? My car is OEM stock, no mods, no added weight, etc.
  2. Offline
    rrg Member
    May 18, 2010
    335
    78
    East coast - NJ
    Your Vehicle Year:
    Food for thought, when I added my middle 4 bolt brace I noticed it was easy to unscrew/remove the 4 bolts.
    Check all visible bolts to see they are snug and tight under the car.
    my2cents.
  3. Offline
    nwprius Member
    Feb 26, 2004
    186
    Roy, Washington and Nanaimo, Canada
    Your Vehicle Year:
    Had that sound until I discovered the back seat backs not secured. Had to slam them hard to lock. Do not have the sound anymore.
  4. Offline
    50324prius Junior Member
    Apr 9, 2012
    37
    iowa
    Your Vehicle Year:
    Have that same thing from the front of my car. I can hear it better with the windows open. The car is going in next week to dealer. Will keep you posted.
  5. Offline
    Mar 15, 2012
    137
    Your Vehicle Year:
    Thanks gang, I'm not sure if my noise is front / rear or both but when I rolled through the taco bell drive through last night at less than 1 mph, the clunking still happened I figured I better find out fast what is loose before it gets worse. I'll check the rear seats also because I often do put them down for cargo space. I work 12 hrs the next 2 days so I won't have time to look but if I figure anything out on my break I'll post.
  6. Offline
    frodoz737 Mechanic
    Aug 26, 2010
    850
    184
    TX
    Your Vehicle Year:
    Have the Dealer check the Calipers and brake hardware. Drive over lane "DOTS" and/or known repeatable terrain. Request a Mechanic ride along to save time and frustration.
  7. Offline
    spiderman wretched
    Jul 5, 2009
    6,751
    1,175
    Alaska
    Your Vehicle Year:
    Had a 97 camry with klunks in the front... had a shop completely replace the struts and tighten everything else. Made no difference. Checked the brakes, nothing. Traded the car in for the Prius. lol
  8. Offline
    zebelkhan Member in good standing
    Mar 14, 2012
    120
    Morgan Hill, CA
    Your Vehicle Year:
    When going over bumps and window open i can hear a metallic sound similar to the rattling noise from a loose backing plate. I plan to have it checked out at 10k service coming up soon.
  9. Offline
    jjPrius Junior Member
    Feb 6, 2011
    47
    Southern California
    Your Vehicle Year:
    My bet is on the front brake pads / shims rattling in the bracket. There is a TSB for the Front Brake Rattle that your dealer may perform that will (hopefully) quiet the noise. When I did the 40k service on my 2011, I disassembled and cleaned the pads and hardware all around and reassembled with dedicated Toyota "Rubber Grease" for the rubber-bushed sliding pins and Toyota "Disc Brake Grease" for the shims and ears on the pads. The brakes have been silent since. I was experiencing a metallic rattle while driving over reflectors from the front and a "pop" noise when applying the brakes while in reverse from the rear.
    Jeff
    zebelkhan likes this.
  10. Offline
    Mar 14, 2012
    120
    Morgan Hill, CA
    Your Vehicle Year:
    That makes sense. Thanks for the info.
  11. Offline
    Apr 9, 2012
    37
    iowa
    Your Vehicle Year:
    Three days of checking out the noise and it is returned with the same noise. I do not know if they even drove it with the windows open or not.
    Same noise, still no clue as to what is causing it. I am going to take it to another dealer and have them drive it.
  12. Offline
    Mar 15, 2012
    137
    Your Vehicle Year:
    I can't find the sound either, but it's a pretty good clunk, so I'll check the brake shims to be sure thanks for the tip
  13. Offline
    Fore Don't look back!
    Feb 1, 2011
    255
    43
    Virginia
    Your Vehicle Year:
    Took mine in for the 15,000 mile service and also to have them check the same situation when going over small bumps or highway dividers. Took the mechanic for a ride and he said he could hear it, also told him there's a TSB on it. Apparently there’s no solution for this problem because they told me everything checked out, breaks, calipers etc., he said he tighten up everything he could find. I don't hear it as much on the right side tho, but still hear it on every bump on the left side. No big deal I didn't buy this car for luxury or comfort, just the best mileage I can get from point A to point B and back again.
  14. Offline
    Mar 15, 2012
    137
    Your Vehicle Year:
    /\/\ that's what I was thinking when I first noticed it, I kinda laughed and thought to myself, all my other cars were much louder than this so a little unsolved mystery rattling is still acceptable as long as it isn't a safety concern. The whole interior rattles too lol.
  15. Offline
    wick1ert Senior Member
    Dec 3, 2009
    1,293
    173
    Delawhere
    Your Vehicle Year:
    I had a knocking sound, and according to my dealer it's the spoiler mounting wearing inside the hatch. I originally thought it was outside the car, then towards the hatch. Supposedly they adjusted something, but the knock is still there. I was 2 days past warranty when they finally figure out what it was, so I'm waiting to see if Toyota will cover it since I had the car in 2 weeks before that for the issue and they couldn't find it.
    Did you check where the hatch closes and those stoppers come together? Try putting a cloth in there and see if it helps. Otherwise, you may want to also check your spoiler and make sure it's tight, too.
  16. Offline
    Feb 1, 2011
    255
    43
    Virginia
    Your Vehicle Year:
    This is not a knocking sound it’s more like a loose rattle that only happens when you quickly go over a large crack in the road, highway divider or railroad crossings. It’s definitely coming from the front wheels, and it’s obviously in the front braking system that they can’t replicate sitting standstill in a shop. Something is allowing the calipers, pads or whatever to shift while going over a bump or highway divider.
  17. Offline
    2010CTPrius New Member
    Aug 23, 2012
    Your Vehicle Year:
    I just took my CPO, 2010 prius into the dealer yesterday for an oil change with 18,000 miles on it. I have experienced the same noise and called in advance with the Toyota Brake Fix TSBs. They researched them and had a pile of paper ready for my appointment. They took the car out and actually recreated the noise many times but, ultimately, after checking the brakes, told me that the issue is the rear suspension. They claim that Toyota has told them on quick, abrupt bumps the suspension has some kind of air release and makes this noise. It is normal operation according to Toyota of America. I find it kind of odd but in a way it makes sense because the noise doesn't happen on large bumps, just small, manhole coverish bumps. Anyways, I was impressed they did their homework. At the end of the day I took out the 100,000 mile Platinum warranty when I bought the car and it is good until 2016 so if something goes bad I'll just have it replaced F.O.C.
    Have them check your rear suspension. I think that is your culprit.
  18. Offline
    tach18k Member
    Feb 21, 2012
    268
    SoCal Beach Area
    Your Vehicle Year:
    Loose wheel covers, mine clatter when I drive over the reflectors in the street
  19. Offline
    El Dobro A Member
    Jul 12, 2011
    2,125
    510
    Your Vehicle Year:
    The caliper brackets have a green coating on them. If you remove a caliper, you can see a shiny spot where the caliper wore through the green and hits the bracket. That's your clacking. I put some grease on the spot to see and the noise stopped until the caliper started hitting again.
  20. Offline
    SimiPrius Member
    May 8, 2010
    224
    52
    Simi Valley,Ca
    Your Vehicle Year:
    Interesting....I have a 2012 PIP and have noticed the same thing. I typically drive with the windows down in the early morning. When you go over a slight iregularity in the road, there is a loose rattle coming from the front wheels. When I hit 5K I am going to take it in and have them look at it.
Share This Page
