MFD Fuel Consumption Graph Not Showing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rukmal, Oct 29, 2014.
  1. Rukmal
    Rukmal New Member
    Hi I'm new to this forum!
    I bought a Prius 2nd Generation (2008) Japanese domestic)
    When I go to Consumption view it shows blank Graph for the past 5min - 30 min graph
    Please tell me how to fix this
    Thanks !
    #1 Rukmal, Oct 29, 2014
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved from the Prius v forums to the 2nd generation forums.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    You do know that display graphs are only from this drive? Next to consumption number should be how much you have driven after it was reset. If you drive and don’t reset the consumption and it still doesn’t work then it probably problem with MFD itself. Does everything else in it work?
  4. Rukmal
    Rukmal New Member
    The graph is blank always. What is the reason ?
  5. valde3
    2,002
    745
    Finland
  6. Rukmal
    Rukmal New Member
    Dear valde3
    Thanks for your respond.
    I just follow the steps and accessed the "SYSTEM CHECK MODE"
    Everything is "OK"
    Then I went to "VEHICLE SIGNAL CHECK MODE"
    BATTERY :12.6V
    IG : ON
    PKB : ON
    REV : OFF
    Any advice ?
  7. valde3
    2,002
    745
    Finland
    Do the test from that link and you should get three different voltage readings. Post them here. When you get the last one Prius is in ready and you can start driving. Does the speed screen display your speed?
  8. Rukmal
    Rukmal New Member
    I checked the speed and its showing 0km/h always. This could be the problem ?
    I'll post the 3 voltage reading. I dont have them right now.
  9. valde3
    2,002
    745
    Finland
    Yes that is the problem. But unfortunately I don’t have more information how MFD receives information on vehicle speed. Problem can be with MFD or with some component that sends speed information to it or wiring.
  10. Rukmal
    Rukmal New Member
    Oh! Dont break my hope!
    Please help to fix this problem. ;
  11. valde3
    2,002
    745
    Finland
    Go back to system check mode. If all still read ok press LAN Mon. Do they all still read OK? If there is something that reads CHEK press it. Write down (or take picture) of everything that displays. Then go back by pressing Service in upper right corner. Then do the same to all that says CHEK.
    Does your combination meter (speedometer) work normally? Do your odometer and trips work normally? Anything else in the car that doesn’t operate normally?
    Maybe there could be some speed signal interrupt switch somewhere that lets you use some function of MFD when vehicle is moving? Does Japanese version have those? Do you see any aftermarket switches anywhere in the car?
    #11 valde3, Dec 3, 2014
  12. valde3
    2,002
    745
    Finland
  13. Rukmal
    Rukmal New Member
    Please check the LAN Mon Screenshots
    Error codes
    Any Idea Please ??
  14. valde3
    2,002
    745
    Finland
    They seem to differ from US codes that I have manual for.
    In the US manual DB says:
    “Mode status error
    This code detects a dual alarm.
    Inspection for the device indicated by the sub code.”
    But your sub code is 1AC and US manual doesn’t know it.
    In US manual E0 says:
    “Registration complete indication error
    When ”Registration complete” command from the master device cannot be received. This code will be detected when signal receiving time is delayed.
    Maybe with Japanese version manual but written in English this could be solved. Or maybe somebody else could help…
  15. Fawad Sarwar
    Fawad Sarwar New Member
    Pakistan
    Check the GPS connection,
    Did you removed its factory radio , i also have this issue after i replaced the factory radio as it has many different plugs including the GPS
