Dismiss Notice
The Prius Prime may be the best Prius ever. Find out why in PriusChat's first drive review from Japan.
Midsize Hybrid Emission Comparison
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by usbseawolf2000, Mar 4, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,915
    Fort Lee, NJ
    We now have emission data for Hyundai Sonata Hybrid as well as Kia Optima Hybrid. I figured I make a comparison with the other midsize hybrids already in the market.
    Exhaust Emission:
    Fuel Evaporative Emission:
    2 people like this.
  2. aztoyotascion
    aztoyotascion New Member
    Chandler, AZ
    What does the "hot soak" refer to?
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,478
    Southwest Colorado
    ^^ the car is parked in high ambient temperatures for the prescribed time. I think 12 or 24 hours, but I am no sure. I am sure you can guess there is also a 'cold soak.'
  4. SageBrush
    11,627
    2,478
    Southwest Colorado
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,718
    2,081
    45
    North Yorkshire, UK
    How useful is the vapour recovery units? They're not a legal requirement here in Europe (though some cars do have them) and I wonder is the amount recovered significant or minute? How does it compare to exhaust emissions etc?
  6. Flying White Dutchman
    4,374
    300
    2012 Chevy Volt
    anyone with a charge compared to the "clean"diesel from vw?
    bleutech stuff
  7. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    I have data for Jetta TDI but it is a compact. Any suggestion for a VW or Audi mid-size TDI?
  8. UsedToLoveCars
    432
    SF
    2014 Tesla Model S
    whelp, I think unburned hydrocarbons are a major smog contributor. They are very strict about vapor recovery systems in California. Part of the emissions test includes pressurizing your fuel system and checking for leaks.
    Even the fuel pumps here have vapor recovery doodads on them to keep vapors from going into the air.
  9. Flying White Dutchman
    4,374
    300
    2012 Chevy Volt
    the next is the passsat right? and thats bigger then the prius
    and VW is putting the jetta out there to be a prius basher... so come on with those numbers and see.:)
  10. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
  11. Rybold
    Rybold globally warmed member
    2,760
    320
    Southern California
  12. evpv
    evpv Active Member
    526
    166
    West Coast
    Thanks, but I was looking for the PZEV version if you have it.
  13. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    There is no PZEV version as the emission is the same SULEV. SULEV + 10 years / 150k miles emission hardware warranty would make it PZEV.
    Even Prius doesn't have AT-PZEV version of the PDF / certification.
  14. evpv
    evpv Active Member
    526
    166
    West Coast
    Hmmm, I thought there was more difference than that. Thanks for posting the data.
    "In order to qualify as a PZEV, a vehicle must meet the SULEV standard and, in addition, have zero evaporative emissions from its fuel system plus an extended (15-year/150,000-mile) warranty on its emission-control components."
  15. evpv
    evpv Active Member
    526
    166
    West Coast
    Where the heck are they hiding the emission pdf sheets on the arb.ca.gov web site???
  16. Flying White Dutchman
    4,374
    300
    2012 Chevy Volt
    the phev got wurs Co2 then the normal pruis?
    what about that
  17. SageBrush
    11,627
    2,478
    Southwest Colorado
    I took Dutchman's data and normalized the graph to the Accord emissions. The second graph includes SULEV thresholds, but unfortunately things get squished because of the high CO number.
    2 people like this.
  18. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    The file name in the link I provided in post #10 said "pz.pdf". The certification inside it said SULEV. They may not have separate PDF with PZEV certification.
  19. austingreen
    austingreen Senior Member
    11,731
    2,716
    Austin, TX, USA
    The testing procedure is antiquated and does not properley account for the way hybrid and plug in hybrid cars are run. I think you meant carbon monoxide in your post. Lev II does not give any credit for electric miles. When the ICE kicks in on the phv, I can only assume it does not do the full warm up as it does on the regular prius. This will give a short term increase in carbon monoxide. This increase is exaggerated by the testing procedure. If you add in the electric miles, the phv should always produce less CO per mile, with the number approaching the normal prius as the mileage gets large. There have been suggestions to fix the problem in Lev III, but I am not sure what if any progress has been made. The numbers on the phv are very low even with the outdated testing procedure.
  20. austingreen
    11,731
    2,716
    Austin, TX, USA
    That is exactly it. Toyota got a CARB waiver as have other car companies to have a 10year warranty on the battery. In typical CARB speak, zero in the case of evaporative emissions are not zero, but they are very low.
