Mileage discrepancy between odometer and GPS
Discussion in 'Gen 3 Prius Technical Discussion' started by Jonny Zero, Aug 27, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Just for grins I used a GPS mileage logger app on my phone to compare to the mileage logged on the car. The app was launched well before taking off and so there was a good satellite fix.
    Trip summary on the car logged 15.9 miles, and the GPS logged 15.52 miles. Tires are stock 17" Toyo Proxes down to 4/32nds.
    What do you think of this discrepancy?
    48,988
    i think toyota wants you to run out of warranty before you actually arrive.;)
  3. Former Member 68813
    3,524
    981
    US
    2% error. Honda lost class action lawsuit on 5% error in 2007.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I think your test distance is too short to draw any conclusions. You need much more data. When you get a 100-200 mi. trip the error will have more meaning, and if you do it 3 or 4 times and get the same results you can start believing the numbers.
  5. qdllc
    qdllc Senior Member
    1,358
    396
    Not always.
    Most vehicles have speedometer error built in. Motorcycles have it because of variations in gearing and tire sizes, but it's often 5% less than actual. The "SpeedoHealer" is often installed to let you mathematically correct the error. You don't need miles to figure it out. Just a couple 1 mile runs with a GPS. GPS vs. odometer + formula = correction factor.
    Cars should be spot on if you get the OEM setup from the factory (higher trim level wheel change sizes WILL alter odometer/speedometer readings because the system is calibrated to the stock wheel/tire size intended for the vehicle), but I'd not be surprised to find they still have errors.
  6. Former Member 68813
    3,524
    981
    US
    Right, but the OP is taking about ODOmeter.
  7. qdllc
    qdllc Senior Member
    1,358
    396
    If the spedometer reading is off, so will the odometer. Both use the same sensor.
  8. Former Member 68813
    3,524
    981
    US
    Different calibration. There are laws on allowable speedometer calibration errors, but not on odometer calibration.
  9. Mendel Leisk
    38,247
    The elephant-in-the-room is the well worn 17" tires, I assume 215/45R17.
    I've often wondered if Toyota adjusted the odometer to account for the difference in OD of the 17" tires. Maybe not??
    BTW, we also have the 17's on our Canadian "Touring" model.
    This is my tire calculation spreadsheet, just using the stated sizes. I entered the 15.9 miles in bold, and the bold value to it's right is 15.9 times 0.986.
    #9 Mendel Leisk, Aug 28, 2014
  10. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    When a colleague and I exchanged our Volt and PiP for a week last year we both noticed that the PiP odometer was reporting about 1.5- 2.0% greater distance than the Volt when driven on an identical route. You are reporting a 2.0-2.5% discrepancy between your PiP and your GPS. Specifically, my Volt would report my drive from home to work as 45.5 miles and the PiP would report it as 46.3 miles.
    This would tend to exaggerate the PiP's mpg and EV efficiency results much like the Prius/PiP gasoline consumption reported by the car averages about 3% optimistic whereas my Volt reports gasoline consumption that is within 1% of that reported at the pump.
    I don't understand why Toyota can't report more accurate averages.
    #10 Jeff N, Aug 28, 2014
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Today's reading:
    CAR:15.8, GPS 15.48.
    I have read that GPS has a tendency to under report distance if the path is curvy, because it takes location samples, then draw straight lines to connect them. But then I path I took is not all that curvy...
  12. Mendel Leisk
    38,247
    Swap your tires for 195/65R15?
  13. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I would like to but more expensive that I would like, with the TPMS swap, etc. I was never crazy at the fact that the car came with 17s...
  14. Mendel Leisk
    38,247
    But do you see my point? The 215//45R17 have a significantly smaller OD, and your's are worn. I'm guessing the odometer of the US Five (and our Canadian Touring model, in the same boat) has not been adjusted for the different tire size. If that's the case, and odo is accurate with the 15" tires, it's going to overreport miles with the 17".
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I do see your point. I would not think the adjustment would be difficult and I will speculate Toyota did it on purpose, to cover SOME of the MPG loss from the heavier 17" wheel assemblies.
  16. fuzzy1
    10,045
    And Subaru too, in 2010.
  17. Mendel Leisk
    38,247
    Were running 215/45R17 in summer, and 195/65r15 (snow tires) in winter. I suspect our Garmin navigator can display distance travelled? I'll look into it, repeat with the snows, post back. It'll take a few months though, lol.
    The one downer: our mileage with the 17's is likely a bit less than calculated. If Toyota hasn't adjusted the odometer.
  18. David Beale
    5,963
    1,981
    Edmonton Alberta
    As I already posted, your distance is too short to be expected to be accurate. GPS distance traveled is from point to point as you stated. Turn a corner and you can loose distance if the "samples" cause the track to be across the corner. You don't see it on the GPS screen because it usually "snaps" the track to a road for display. Turn that off and you will see how the GPS points cause the "assumed" path to wander.
    Do a test over a much longer distance. There the errors will average out.
    As far as complaining about how "inaccurate" the odometer is, please get reasonable. The Prius IS NOT a lab instrument. 2% accuracy is pretty good for such an inexpensive device! Just the wear in the tyres and possibly tire pressure differences can cause greater error.
  19. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Wrong. Yes the same sensor but the speed includes a calculation which may, or may, not be accurate. And that accuracy may make the reading high but never low.
  20. qdllc
    qdllc Senior Member
    1,358
    396
    I'm probably thinking of a mechanical setup (even with an electronic sensor). The signal drives both so off MPH will likewise affect odometer readings. All digital could apply different calculations to the same original signal pulse.
