1. Offline
    HaveNoCents Conservative Tree Hugger
    Start a Conversation
    Dec 31, 2011
    299
    43
    Crystal Beach, Texas
    Your Vehicle Year:
    We recently got back from a 2800 mile trip. Our v now has 10,600 miles on it. We have been averaging 41mpg until the last two tankfuls. For some strange reason we got 34.5 displayed on our last tank, 32 actual, and right now after 90 miles we are showing 30.5 displayed. My wife drives the car 98% of the time, but even when I use hypermiling techniques the car is not yielding the past displayed results. We are about to take it in for the 10,000 oil change. We live in Texas so it is over 90 everyday, but we keep the temperature on 76. Our driving habits have not changed at all.
    Any Suggestions?
  2. Offline
    Rokeby Member
    Jan 21, 2008
    2,992
    682
    Ballamer, Merlin
    Your Vehicle Year:
    Did you encounter very dusty conditions on your recent trip?
    If so, your Mass Air Flow (MAF) sensor and throttle body may
    be in need of cleaning.
    Another possibility is a bug got past the air filter and is fouling
    the MAF.
    It is an easy matter to open the intake air filter and check.
  3. Offline
    rjparker Member
    Jun 6, 2008
    344
    38
    Texas Hill Country
    Your Vehicle Year:
    Make sure your tire air pressures are at least 35 front and 33 rear. Buy name brand gas such as Shell or Exxon. Really cheap gas (or some gas bought at high altitudes) may have low octane which could cost mpgs at sea level.
  4. Offline
    12,386
    1,755
    Your Vehicle Year:
    have them check your 12v to make sure it's upto snuff. also, even tho the temp is set to 76, if it's hotter outside than it has been, you're gonna get worse mpg's.
  5. Offline
    Dec 31, 2011
    299
    43
    Your Vehicle Year:
    Thanks for the responses, I will check into all suggestions. Tire pressure is sitting at 42/40 so I know we are good on that.
    I know a bad 12v can give you crazy readings, but how could that have a bad effect on actual mileage? The car did sit for two weeks, but we drove it 1800 miles after that two weeks with no decrease in mileage on the highway.
  6. Offline
    Dec 31, 2011
    299
    43
    Your Vehicle Year:
    Well here is an update. As it turns out the mileage drop had a very good reason. It seems my wife no longer shuts the car off when she is on the ferry. Basically it's like being stuck in traffic without moving an inch for approximately 50 minutes.
  7. Offline
    JimN Let the games begin!
    Nov 26, 2006
    5,143
    368
    South Jersey
    Your Vehicle Year:
    If the 12v isn't holding a charge then the car will keep trying to charge it. Guess where that electricity comes from.
    Yup. Sitting for 5 minutes usually won't make a difference. 50 minutes will drop anyone's numbers.
  8. Offline
    schinia Member
    Jul 4, 2011
    130
    22
    cape carteret,nc
    Your Vehicle Year:
    it didn't drop my numbers, with the weather in the 90s, i sit in the parking lot w/the car running for an 1 1/2 hours, while my wife has her back treatments. still get 45 mpg (calculated)
  9. Offline
    OWG Junior Member
    Mar 29, 2012
    92
    16
    Barrie, Canada
    Your Vehicle Year:
    Sat at the drive-in for about 4 hours running (no AC) and did not have a noticeable affect on my mileage.
Share This Page
