1. Offline
    rjdriver Member
    Start a Conversation
    Apr 7, 2012
    142
    49
    Rhode Island
    Your Vehicle Year:
    Wrong guy........
  2. Offline
    Reedja42 2012 Prius, Gen III, Barcelona Red, (FRED)
    Jun 14, 2012
    248
    73
    Upstate New York
    Your Vehicle Year:
    If you average all of your mileage figures you come out to about 47 mpg. I say not bad for a Prius C (city) that is being driven cross country, on the highway at 75 mph, fully loaded, AC blasting, with high outdoor temperatures. Keep in mind that the vent for the traction battery is in the back of the car near the battery itself. You said the temperature on your last trip was 100 degrees. Remember that ECO mode reduces the output of the air-conditioner, so if you were barely keeping cool up front with the air blowing on you, remembering that the luggage would block cool air from getting to the back of the car even if the vent wasn't blocked directly; your traction battery was probably sweltering. This would kill its ability to provide efficient power. So unless your car keeps giving you low mileage when you get back to regular driving under normal conditions, I would say it is normal. I also strongly recommend doing anything you can to keep your traction battery from overheating at all costs, because it can be damaged by excessive heat.
  3. Offline
    roamerr Junior Member
    Jan 15, 2012
    44
    Winston-Salem, NC
    Your Vehicle Year:
    40 mpg is not bad for that ride. We tow ATV's from NC to Utah and the part through Kansas and the other middle states we normally get 8mpg or so in our pickups. It looks flat but is 500+ miles of uphill.
    The AC on Prius's takes alot of power. Hurts mpg but feels good. My Prius II takes a 5mpg hit for AC on 95+ days.
  4. Offline
    Erikon Active Member
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    The c isn't optimized for the highway like the regular Prius, higher CD. So 75 mph, 100+ degrees, AC set on 69 and fully loaded, yeh 40 MPG sounds right!
  5. Offline
    Zach G. New Member
    Jun 28, 2012
    Your Vehicle Year:
    Thanks everyone for the helpful info. I figured all the external factors (luggage, going 75, ac blasting) had an effect but wanted to know if that assumption was correct. Funny enough though, on the final 450 miles of my trip, after filling up the tank, I got near 60 mpg for a good 70 miles before it slowly dropped to 50 mpg. Same amount of luggage, hotter temps. More hills though.
  6. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Wind can also have a profound effect on your mileage, a good tailwind can add quite a few MPGs and a headwind will suck it down!
  7. Offline
    roflwaffle Member
    Feb 23, 2012
    142
    Orange County
    Your Vehicle Year:
    OKC and Albuquerque have a ~4000ft difference in elevation, so you'll loose a couple mpg due to that. My guess is that the majority of the rest is from going into significant headwinds.
  8. Offline
    M8s Retired and Lovin' It
    Sep 11, 2008
    597
    97
    Colorado & Arizona
    Your Vehicle Year:
    In addition to high speed and added weight, poor mpg on this stretch is a combination of two factors - headwind and increasing elevation. We drive from Denver through Albuquerque to Phoenix several time per year and the ever-present headwind kills good mpg. Also, at about mile marker 49 in Western NM (about 30 miles East of Gallup), you will see a "Continental Divide" sign on the side of I-40. This shows that you've been driving uphill for hours, even though the landscape looked flat and featureless.
  9. Offline
    eldersciii C3PO
    Jul 4, 2012
    32
    Sacramento
    Your Vehicle Year:
    Dont forget here guys that we just now receiving summer blended fuels all around the US. If you read in your owners manual and on the fuel cap E-10 fuel is the max allowed alcohol content allowed by Toyota. Summer blends tent to have the full 10% content. I just bought my C III on Sunday and I am getting 50mpg already with only 100 miles on it but That is not a great marker really. At 500 miles I will be changing the oil to MB1 0w20 and a new Toyota filter. And I'm going to experiment with 91oct fuel as well to see if the 14.1 compression ratio likes it better.
Share This Page
