Misfire cylinder 1
Discussion in 'Gen 2 Prius Technical Discussion' started by Clark Griswold, Mar 21, 2012.
  1. Clark Griswold
    Clark Griswold New Member
    29
    Bolingbrook, il
    Plus 3 or 4 cycles today and still looking good. I've reset the light several times before with my code reader and it's never stayed off more than 2 or 3 cycles.
  2. Clark Griswold
    29
    Bolingbrook, il
    Well, I'm still keeping my fingers crossed. CEL has stayed off for 11 days now. I wish all my vehicles would fix themselves like this. I did notice some noises coming from the garage late at night, and found a bunch of Keebler cookie wrappers laying around out there. Could it be those damn elves finally did something constructive for a change?
  3. Clark Griswold
    29
    Bolingbrook, il
    Just thought I'd update this thread. The light ended up staying off for over a month... till mid or late june, can't remember, but it was well over a month, then it came back on and has been on ever since. The car averages over 50 mpg and I never notice any roughness in the engine. Does anyone have any idea why this problem went away for several weeks and does that shed any light on the problem in general? I've always been suspect of the wiring going to the cyl 1 ignighter, but how would someone check that?
  4. Davewin
    Davewin New Member
    Vermont
    2001 Prius
    Clark, I was wondering if you ever resolved this problem. I have the exact same one! Did a lot of the things mentioned. The light also goes on and off as it pleases. Car runs fine, 50MPG.
  5. bisco
    48,945
    i wonder if it could be something as simple as a loose connection.
  6. Melchior
    Melchior Junior Member
    74
    Netherlands
    Having read this thread I would suggest the fault code is happening not because of a misfire on cyl 1 but becuase the ECU *thinks* there is a misfire on cyl 1. Perhaps that side of things should be investigated - an actual misfire is all but ruled out by now (coils swapped, injector replaced, no wear)
    How does the ECU detect a misfire on any cylinder? If we can know that, maybe we can start to figure out why it thinks there is a misfire when there isn't.
  7. Davewin
    Davewin New Member
    Vermont
    2001 Prius
    You may be right about the ECU thinking there is a misfire. If I get a chance next week I will got to the junkyard and get another ECU and see what happens.
  8. Patrick Wong
    18,198
    6,464
    The engine ECU uses the crankshaft position sensor to detect engine speed variations which are indicative of misfire, and the camshaft position sensor to identify the misfiring cylinder(s).
    Melchior likes this.
  9. Gary H.
    Gary H. New Member
    Ledyard, CT
    I have had misfire issues with cylinder #1 twice now. The first time, at about 205,000 miles I removed the coil and spark plug, cleaned and dried both of them and re-installed them. Misfire GONE. about 60,000 miles later the misfire was back. I repeated the procedure and when I was replacing the coil, I noticed that when the coil retainer bolt was fully tightened, the gasket between the coil and the valve cover was not compressed like it was on cylinder #2. In fact, there was a gap that was allowing water, grime and dirt to enter the tube and cause the misfire problem. It looks to me that the threaded post for the retainer bolt is too long on cylinder #1 and not allowing the gasket to seal. I filed the underside of the bolt hole on the coil to allow the coil to seat deeper into the tube and now the gasket compresses. I hope it seals now. Timew will tell. Is there anyplace where I can purchase new coil gaskets without having to purchase the entire coil?
  10. bradyice
    bradyice New Member
    miami
    what can i do if dont have ground injector 2
  11. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    The common denominator is the dealer removed and reinstalled the head on the short block- I am suspecting a head gasket leak on that cyl- which is why the engine runs rough at start up after sitting overnight. After running a few minutes, the coolant burns off and the engine runs OK, until the radiator gets hot and under pressure and hot coolant leak starts the miss fire again on the plug. Naturally, if it is the head gasket, the dealer who did that short block swap should have to redo the head gasket. If there is any loss of coolant or overheating, look out.
  12. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    The Toyota mechanic who did the faulty repair, would have his check docked for the hours it takes to replace the head gasket, if it was a reputable dealer who stands behind their work. No mechanic likes to have his check docked, but that is the downside for working on flat rate, not by the hour. It's possible, the owner declined to have the head rebuilt/surfaced flat ( to save money) and in that case, the dealer has an out= the head was warped and the gasket wouldn't seal.-
