Has anyone looked into what it would take to add more battery capacity to the 2012 PiP? I have the base model and I can get between 11 and 13 miles EV range depending upon whether it it slight uphill or slight downhill. If I could get 18 to 20 EV range, then I could actually do a round trip from home to work without charging at work. (Charging at work is another nightmare because there are 2 chargers but something like 30-40 EV automobiles.) Soooo, what if I could add something like 1.5KWh battery capacity to the small verically oriented storage compartment in the back of the trunk? What kind of BMS would be needed to join this capacity to the existing capacity? Or, would it be possible the Toyota BMS already would understand more capacity and would 'just' charge it and use it if it were in parallel? (I doubt this becuase it likely would need careful charge leveling and other strange stuff to make the batteries last.) Have any CalCars or others looked at a this kind of modification for the PiP? What would you think something like this might cost? FYI, right now, I'm at about 3300 miles on my PiP and of that about 2600 is EV only. So, I'm at something over 300mpg on it. But, it's difficult and takes effort to make sure I charge a lot. And, I put in a level 2 charger at home to charge more quickly so I can come and go 'quickly' and still charge sufficiently. (which brings me to my other issue: While the regen charge can charge with large currents, the level1 or level2 charging only draws 12A, which implies Toyota 'skimped' on the inverter for 120V/240V. I suspect the regen current is large because it's simply using the motor in reverse, and the motor has to be fed large currents from the battery so it can regen large currents toward the battery....)
i believe this would be a hugely popular mod for pip owners. even tho i get 17 miles ev on my commute, i think 20-30 would be a very worthwhile addition if it could be done for one or two thousand. i don't quite understand some of the technical difficulties you mention tho. why can't you just connect a non pip battery from a gen III to the pip for another mile or two?
At least for 120V, I don't think they skimped. I read that 12A is the derated amperage for a extended period continuous draw on a 15A circuit.
Enginer | Solar Powered Prius Plug-in PHEV Conversion Kit with Lithium-Ion | Hybrid can add a 4kwh range extender pack to a PIP, although i don't think anyone has actually done it yet. That would give an extra 16-20 miles of EV range.
their reputation scares me. i'm looking for something simple and foolproof. (because this fool would definately mess it up.)
Their product has been through a lot of iterations, it's now on version 6, and should now be totally plug and play. (well, install and play, anyhow.)
i'll take your word for it, but i'm only brave enough to be a first user of official toyota factory tech. HOV access in the state of GEORGE. hmmm...
The same kit works in all vehicles, just the mountig bracket is different, and the voltage of the DC-DC convertr is set to a different level. It'ss possible they don't mention PiP specifically because as I say there hasn't been one done yet, but the kit will work just fine.
Yes, 12A is the maximum load that electric codes allow on a 15A circuit and breaker. Anything between 12A and 16A requires a 20A circuit and breaker, which is very common but not universal. Beyond that, nearly all buyers would need a special new circuit added before recharging at home.
It is near impossible to hyper in a pip, you have to shift to neutral as then breaking kicks in right away if left in five and you take foot off the gas.
yes, same as non pip. some people don't understand glide vs regen and the rest of us have difficulty finding the sweet spot.
by the time engineer has some reliable units on the road, toyota will proly have the next gen available.
bisco, you don't hear from the people with trouble free systems. Mine still works fine, although it is not installed in a car at the moment.
Flan..., Why have you removed the add-on battery from your 2010 Prius? How much did it cost? What does it weigh? Did you have to modify any other hardware or software? Please post a photo of your Engineer Battery out of the car and how you install it. I would like a battery that I can use for my daily routine commute, yet remove it on long distance trips where I'd be only using HV. Thanks,
you're right about that, we only read of the prolems. what % would you estimate are trouble free from day one?
