Modifying my future Plug-In
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PRPrius, Jan 30, 2012.
  1. PRPrius
    PRPrius Active Member
    327
    198
    I am so glad that Toyota didn't release the production model with the blue chrome "Prius" logo. I had seen several pictures that showed the "Prius" logo in an ugly blue chrome color (similar to the leaf).
  2. PRPrius
    327
    198
    All the parts have arrived, now I just need a PiP to install them on.
  3. Flying White Dutchman
    4,374
    313
    i would say get a EBH
  4. PRPrius
    327
    198
    I have to admit something, I am having second thoughts about the JDM mirror modification. I have been looking around and I just don't know if I feel comfortable with an installer doing the wiring job. I wish I could find an installer that has previously done this particular job. I don't want my brand new Prius as someone's guinea pig.
    Any suggestions? I am or was planning on having Lucious garage in San Francisco do the wiring job. I know they specialize in hybrid cars, but I know how picky I am. I think my biggest fear is any rattles that may develop due to the removal of any panels for wiring purposes. I would also fear any electrical problems that might develop down the road.
  5. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Luscious Garage is the best. They work on all the Prius city taxis. They replace inverters, batteries, transaxles, bearings, engines... Pulling a door panel and running some wire is a walk in the park to them. I trust them totally.
  6. PRPrius
    327
    198
    I finally found some time to start modifying my PiP. It has been almost 30 days since I took delivery of my PiP. The modifications that I done on the car are as follows:
    1) Shark Fin
    2) Mudguards (European Version)
    3) All-weather floor mats
    4) Rear bumper applique (I decided to go with the regular Prius applique) I didn't want the bumper applique to stand out.
    My turn signal mirror modification will have to wait until I make it to California (Lucious Garage) or find a trustworthy installer here in the Metroplex. I opted to go with the same window tint that I used on my Gen II Prius. I will be using the Hupper Optik nano ceramic film.
  7. PRPrius
    327
    198
    mud guard pics
    KLD_Prius_PI_Synergy likes this.
  8. PRPrius
    327
    198
    View of the shark fin from the rear of the car.
  9. blakemster
    blakemster Member
    130
    23
    huntington beach, ca
    Tracksdale, can you tell me more about sound deading the doors? That's probably my only gripe ... car too loud at high speed to talk on bluetooth phone (over 70mph)
    blake
  10. blakemster
    blakemster Member
    130
    23
    and what wheels are we suppose to get without screwing up the PIP? 16's or 17's?
    MANY THANKS,
    Blake
  11. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I read a lot of threads here on PC about sound deadening. One person I PMed was very helpful and told me what he thought I should order. He had just done his car and said that he thought it was comparable or quieter than his Range Rover (I have never been in a RR, but I imagine it must be pretty quiet).
    He did his doors (about 90% coverage), his rear hatch area, and the front kick panel area. He also suggested using the thin stuff (a thin, dense foam like material with a thin aluminum backing) on the metal surfaces and then "blanketing" whatever areas you can with a thicker, not-as-dense, foam material.
    What I ended up doing is just the doors, so far. And each subsequent door I did, I did much better than the last. I did the outer door skin (relatively heavy coverage) and the "inner" door skin (immediately behind the door panel).
    With the inner door skin, I've seen pictures where people have removed all the wires and tried to cover the whole area with the material. But I didnt go that far. I didnt want to remove all the wires and the plastic clips. And the moisture barrier uses like a black tar like adhesive which I didnt want to deal with. So I just put it on any exposed metal. In the beginning, I was trying to do larger areas of exposed metal. But after the first door, I started to use smaller pieces to just cover much more area. One day, I'll go back and redo the first door (the driver door).
    As for the foam blanket, I didn't use that much of it. I would like to go back and add more of that material to each door, after I do the kick panels and the rear hatch area.
    The results so far have been (1) the doors dont sound like they are exploding when they are closed.. they have a definite "thud" to them now, (2) the stereo sounds much better.. definitely increased the mid-low range, and (3) I THINK its quieter.
    The reason I only THINK its quieter is because I've only been on the freeway twice (once picking up the car and a round-trip to the airport). My daily commute is a pretty quiet drive already. I did try to measure the interior road noise using an iPhone app. I dont know how accurate the app is, but thats all I had. I measured the same section of road twice before I applied the sound deadening material. And then I measured it twice after. The numbers for the "before" were similar and the numbers for "after" were similar too. But it was something like a 2dB drop in interior road noise (the number jumps around a lot, but I would be confident in saying it was a difference about about 2dB). The section of road is pretty smooth asphalt and the speed limit is 40MPH.
    When I was driving in the rain, I did notice there seemed to be more road noise coming from that kick panel area. So its very possible, as I was told, that area will make the biggest difference. There are some areas in the rear (like the wheel wells) that I would like to do. But the rear cargo area is pretty much all battery, so I dont think that would make as much of a difference.
    I've also read that people used the foam blanket material to put UNDER their all-weather mats (front and back) and they said that made a noticeable difference as well.
    So, take my experience for what its worth.. I do plan to do more.. and like I said, I think my first couple of doors could use some more material. To give you an idea, I bought something like 37 sq feet of the thin stuff.. and I only used about 15 sq feet so far.
    The thin stuff I'm referring to is the RAAMAudio BXT II and the thicker foam blanket is the Ensolite IUO self-sticking one (Mat and Foam Products - RAAMaudio Inc.).
