modifying suspension to carry weight
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cvincent, Jul 22, 2011.
  1. cvincent
    cvincent Junior Member
    76
    arizona
    i use my 2008 touring prius for work and carry quite a bit of weight in it
    also do some dirt roads about once every cuople of weeks
    a heavier duty suspension would be great for me
    most of what i see on here talks about lowering
    any suggestions on modifying the suspension to lift the car, especially the rear end a little, etc
    and make the car be able to handle the extra weight better
    thinking of long term wear and tear on the suspension, wondering how it is going to hold up and what to replace it with, etc
    thanks
  2. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    Check out the people who are doing plug in conversions. Some of them beef up the rear springs.
    I found this reference:
    I have place order for springs. POHL SPRING WORKS, tele # 800 777 1284 or Call MIKE 509 535 3649 .. It is 2 springs for rear 500 lb for $325.
  3. cvincent
    76
    arizona
    thanks a lot, i will check this out
    anyone who has put these rear springs on please let me know about them
    thanks
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    You might need to upgrade the tires too. They all have a maximum weight limit.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Worth checking but should be OK. The rear of the car is considerably lighter than the front and the tires are sized to handle the front weight.
  6. tf4624
    tf4624 Active Member
    526
    51
    It's good stuff. It works and takes a few hours of install time raises car a few inches
  7. playcool-7
    playcool-7 New Member
    Raleigh nc
    hi., i have placed this info on chat, i have used this springs and it is making a lot diff. i am having 8 kwh plug in load, still it is workin:rockon:g good
  8. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    Good question..
    last weekend I had 200-300 pounds of laminate flooring in the back of mine.
    really didn't drag that far down, but you could tell when you took off...
