1. Offline
    WellesleyToyota New Member
    Start a Conversation
    Nov 2, 2011
    wellesley ma
    Your Vehicle Year:
    Anyone planning to do anything out of the ordinary on their new Prius V? Id love to get a picture thread going!
  2. Offline
    pvogel '05 Five & '12 v
    Dec 9, 2007
    87
    25
    Santa Clara, CA
    Your Vehicle Year:
    I plan to add a trailer hitch for a bike rack as soon as someone has one they indicate fits the v.
  3. Offline
    rubdr New Member
    Jun 7, 2009
    midwest US
    Your Vehicle Year:
    Bought a hitch from juiced hybrid . Fits perfectly on the v three I have. Took 1/2hr to install. Hope this helps!:)
  4. Offline
    bronwyn New Member
    Jan 2, 2012
    Portlalnd
    Your Vehicle Year:
    Which bike rack are you doing to carry. I'd like to get a yakima hold up, but can't done anything yet. (Just took delivery yesterday!)
    Anyone thought about roof racks? I'm not crazy about the clips but I'm less keen having holes drilled into my roof. The one thing I am missing about my subaru outback is the factory roof rack.
  5. Offline
    rubdr New Member
    Jun 7, 2009
    midwest US
    Your Vehicle Year:
    The hitch from juiced hybrid is a class I hitch. You could place a bike rack into it without any problems. I use a small cargo carrier and also have a small utility trailer that works fine too! Best of luck!
  6. Offline
    Dlbewley Junior Member
    Jan 7, 2012
    CA
    Your Vehicle Year:
    I have a Sportsworks / Thule rack which requires a 2" receiver. I can't seem to find one yet. Is there areason for that? Other than you shouldnt haul a giant boat with the Prius.
    Would my warranty be affected if I installed a 2" instead of 1.25"?
    I guess I may have to sell my rack and rebuy.
  7. Offline
    12,295
    1,727
    Your Vehicle Year:
    i'm thinking of modding my kingpin clusters. anyone else tried shimming the lower escalators?
  8. Offline
    russcarver Junior Member
    Mar 27, 2004
    95
    Erie, CO
    Your Vehicle Year:
    You can always buy an adapter to convert from one to the other.
    --Russ
  9. Offline
    2prius New Member
    Jan 25, 2012
    dc
    Your Vehicle Year:
    Well, I would not recommend Juiced Hybrid just yet. I put my order more than 2 weeks ago when I saw this post and saw it is "in stock" on their website. I called them after one week my order not been updated, I was then told it is under"testing" and will be ready to ship in a week. I waited another week and called, the story became this hitch is under "production" and will take at least one more week before they can ship it out. Worse thing is when I wanted to cancel it, I was told the person dealing with cancel is not available, and the person answered my call is unwilling to pass on my very simple request for refund. So after more than 2 and half weeks, the item is not there, and I may have to call my bank to get my money back. Very disappointed. So would not recommend.
  10. Offline
    priusvgator New Member
    Jan 9, 2012
    47
    Space Coast, FL
    Your Vehicle Year:
    I am also looking for a roof rack for my surf boards. Haven't found anything great yet.
    1 people like this.
  11. Offline
    Cactus Hybrid Member
    Apr 1, 2007
    131
    Paradise Valley, Arizona
    Your Vehicle Year:
    I just installed a NEW set of horns from PIAA, bought from Amazon. The package includes TWO horns..one 500HZ the other 600HZ, and two ground wires. Each horn has two male plugs and factory attached brackets.
    I don't like my stock horn at all. The new horn(s) have a nice European sound to it (like a Ferrari) and MUCH more audible! Installation took only half an hour. with no crimping or cutting of any wires!
    Here is how I did it..
    First open the hood, take off the plastic cover around the hood latch, used a 11mm wrench to take off the old horn bracket (Prius has two horns, one on each side).
    I detached the stock wire bundle that is clamped to a plate in front of the radiator (to have more slack to work with). I then remove the single female wire plug that is attached to each horn.
    I then plugged the stock wire plug from the old horns into the new horn's plug (It fits perfectly). I attached the supplied ground wire to the horn's other male plug and the other end to the previously mentioned bolt (Gound). I then finished up by attaching the new horns into the same existing hole/location as the old ones using the same 11mm bolt.
    Lastly, I zip-tied the wire bundle securely and replaced the plastic cover and honked my new horn(s). ;)
    http://www.amazon.com/gp/product/B00079V5ZI/ref=oh_o00_s00_i00_details
    david zaret, DaveShep and Osteoblast like this.
  12. Offline
    shrktank New Member
    Feb 16, 2012
    56
    Imperial,Mo
    Your Vehicle Year:
    Would you mind sharing with me how you install the rack? I would love to get one for my 2012 Prius, but I tend to lack skills.
    Does the Prius already have holes to use to mount the hitching system?
  13. Offline
    TruSound Member
    Feb 1, 2012
    246
    28
    The 818
    Your Vehicle Year:
    1st mod: the day I got it...medium grey window tint all the way around.
    2nd mod: This one is a huge improvement on the dim yellow interior lighting, I installed super bright LED's...both map, dome, cargo area and lower front door, MUCH BETTER !
    Complete plug and play set was around 50 bucks...Here's the link
    http://store.ijdmtoy.com/
    3rd mod: Like Cactus, I upgraded the wimpy OEM horns, I used the Fiamm Freeway Blasters purchased from Pep Boys, one high pitch and one low. Installation is super easy and took about 15 minutes, I used the stock mounting brackets. The improvement over stock is huge, a 40 dollar mod well worth it.
    4th mod: OEM wheel center caps, you'll need them when and if you remove the plastic Frisbee wheel covers.
    Here's the part # for a 2012 v Three.
    42603-52110... $ 60.90 out the door at my local dealer.
    Future mod...Motegi Racing 17" black wheels MR121
    Have a look...
    http://www.tirerack.com/wheels/Whee...lse&filterNew=All&filterWeight=All&sort=Brand
  14. Offline
    Keiichi Active Member
    Feb 1, 2012
    802
    72
    Goleta
    Your Vehicle Year:
    Holy crap, those are bright... Got pictures of how it looks all around with your car? I might just entertain the idea of modifying my car's lights a little.
  15. Offline
    Apr 1, 2007
    131
    Your Vehicle Year:
    thanks for the tip! I just got a set of LED's for my interior also..http://store.ijdmtoy.com/Toyota-Prius-SMD-LED-Car-Interior-Lights-p/pkg_toyota_smd_21.htm
  16. Offline
    mattheikkila New Member
    Dec 31, 2011
    84
    concord, california
    Your Vehicle Year:
    Is anyone selling a gun turret for the V yet?
  17. Offline
    12,295
    1,727
    Your Vehicle Year:
    how is the picture gallery coming along?
  18. Offline
    jas1178 Junior Member
    Jan 10, 2012
    44
    St. Petersburg, FL
    Your Vehicle Year:
  19. Offline
    Apr 1, 2007
    131
    Your Vehicle Year:
    Very easy took 20 minutes for the kit..just remove and replace. The rear cargo area was the most difficult because I couldn't figure out how to pop light housing out..
    I finally figured it out...Using a small flat-head driver, you have to pry it out from the right side as you pull out the housing.
  20. Offline
    Osteoblast New Member
    Feb 16, 2012
    52
    NC
    Your Vehicle Year:
    I thought swapping out the horn was a triumph of technology over reason until I actually pushed it and realized it sounded like a shriner clown car! Followed your lead and did the same and what a difference! I may try the semi-truck air horn this summer as I think that would be pretty funny!
    The LED upgrade was an awesome idea as well!! Did that this weekend and it is amazing how well lit the cargo area is now.
    My next project is that sissy gearshift and somehow upgrading those amber footwell lights to blue.
    Ideas?
    Thanks Cactus!
Share This Page
