Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. epi117
    epi117 Junior Member
    82
    oregon
    on my third tank with my new 2011, 56.2 mpg on display. havnt made any adjustments to tire pressure etc.
  2. Much More Better
    Much More Better Active Member
    655
    162
    Best ever tank: 59.76mpg hand calcd, all city driving. I want to crack the 60mpg barrier so bad!!!!!
  3. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    486.1 miles
    9.503 gallons
    $3.399/gallon
    $32.30 total
    51.15 calculated mpg
    53.5 computer mpg on tank.
    $0.0664/mile
  4. MovnSilent
    MovnSilent New Member
    San Francisco
    Ok so ive had my Prius for about a month now every gas tank and been between 45-47mpg. I thought since it was new and after the "break in period" it would start to increase. I'm reading in this thread that some 2011 are already getting in the 50s. Car has 2k miles now. I think ill adjust my tire pressure.
  5. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    509.3 miles
    10.122 gallons
    $3.359/gallon
    $34.00 total
    50.31 calculated mpg
    52.7 computer mpg on tank.
    $0.0667/mile
  6. DrScooter
    DrScooter Junior Member
    62
    St.Louis
    Starting to get it, the Prius drive style. My (new) 2011 Prius II purchased the end of May a bit over 2,500 miles now. This last tank came in at;
    54.2 Computer MPG
    51.4 MPG at the Pump
    This was about over (about) 475 miles mixed city/highway my normal daily commute is 17 miles each way. This run is 3/4 freeway A/C whenever it's hot, and my normal errands although nice weather often see me on my Scooter for hops to the store, or my Motorcycle to waste gas and "bomb" the backroads. I don't drive to just get the best milage, although I'm looking to do "well" in the Prius, best tank so far and puts my cars "lifetime" milage per the "computer" read at about 50.5 mpg's so seems pretty groovy. Don't think I'm a 60 MPG type of driver but staying in a solid 50 is very cool, I did well with my 2007 Civic, still, that vehicle was at the pump every week and now I make 2 weeks easy before I have to hit the go juice--:cool:
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    482.5 miles
    8.886 gals
    Calculated MPG: 54.288
    Reg Gas/ 10% Ethanol / Costco
  8. DrScooter
    62
    St.Louis
    Mr Mov'n, clearly I'm no expert, seemed in the beginning my milage was around that 47 mpg and I was reading all these 60 (mpg) club members leaving me in the proverbial dust? They say tire pressure is important so yes, check that. Terrain is an unavoidable factor and being a "Frisco" kid while I can't say for sure, seems to be a black fly in your Chardonnay.
    For me I think I'm starting to get the whole "pulse n' glide" without thinking about it. Accelerating into the crest of a hill then gliding with a bit of electric boost on the back side to add some gain. I also punch up "all" electric when I get into my home neighborhood for an easy 0.5 miles (a better safer driver) and again, to electric for the "traffic jam" syndrome to treat my "road rage" and helps makes me more a mellow fellow. However, now I also "roll stop signs" (becoming a new danger on the road) :eek: all for the sake that "extra mile" braggin' right. :rockon:
    :cool: Seems as if I have crossed to a solid 50+ mpg without being a complete "Old Codger" which is not too bad for an old codger. Mind you, I maintain two motorcycles to satisfy my lust both of which are in the plus 50 club. Seems a reasonable compromise as I find I done crossed over to 50+ too. :focus:
    REMEMBER your milage may vary......... :cheer2: however, driving 500 miles then getting a fill-up with less than 10 gallons, seems a MasterCard moment.
  9. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    I started at 3130 PSI, AL80, max depth was 45', fresh water, drift dive.
    After 55 minutes had 955 PSI, just over 700 back on the boat after practicing the 10 min safety stop at 10'.
    Remember, YMMV
  10. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Rolling stop signs won't get you to 60mpg. I'm one of those guys at 60+ and I NEVER roll stop signs. I just glide up to them, stop, and then start off easy so the ICE doesn't light up. Lots of people do it around here, though, but I don't get the impression that their motive is saving gas.
    P.S. Just sold my motorcycle. Hadn't ridden it in ages, having too much fun in the Insight and the Prius.
  11. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Besides both you and your car now being broken in, I think the main component of your recent mpg gains is ideal weather; not too hot thus a lot of a/c use, not too cold so the ICE is having to run more frequently/longer to stay warm but juuuuust right.
    For me in the deep south, those conditions come in the winter.
  12. walter Lee
    1,126
    376
    Maryland
    It's pretty easy to get 50s or 60s per tank in the summer
    time if the roads are flat or slightly hilly with little or no traffic.
    With hypermiling under the special conditions (100% gas
    being one of the more very helpful factors) one can can
    sometimes push the Prius into 70s per tank.
    If you are driving continuously uphill for a long distance
    the optimum power level for a 2010 Toyota Prius ICE
    is approximately from 1240 RPM to 1500 RPM ( or from
    .80 GPH to 1.25 GPH if you have a ScangaugeII )
    which more often than not is under the ECO capsule
    label up to 3/4 of the way on the ECO bar on the
    HSI indicator. The main computer will adjust
    in real time the ICE and MG1/MG2 contributions to the
    CVT as the car goes uphill depending on the speed,
    torque/power, and HV Battery SoC. In general, speeding
    up before going uphill and then allowing the speed
    to drop before you reach the top of the hill will helps
    keep the Prius MPG higher. When there is a long
    steep enough downhill stretches, you can take your
    foot off the accelerator and and let the gravitational
    forces recharge the Prius HV batteries as it goes
    downhill. When the HV batteries are full and the
    Prius is going downhill on along stretch, a hypermiler
    might to put the Hybrid into Neutral and allow
    it to coast part of the way down the hill ( this is
    a favorite for Gen1 Insight hypermilers with a
    Manual transmission ) To get the best MPGs on a
    Prius, one must keeping the tire pressures up. The
    Prius ICE warmup MPG penalty is fairly high for urban-
    suburban-metro area driving ( but much less so
    for long superhighway trips) - if you are mainly driving
    less than 40 mph in stop and go traffic in the
    winter time then you should consider blocking
    the air intake grills on your Prius to enhance its
    ability to warm up and stay warm in cold temperature.
  13. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    It seems to me that the folks getting 60 -70 mpg tanks must really be pissing off other drivers. The very slow starts (to keep the ICE from turning on) would get you run over in my neck of the woods. And using pulse and glide is stressful (for me) and detracts from my being an alert defensive driver. I drive my Prius pretty much like I drove my truck and average 50 mpg. I'm happy with that. FWIW.
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    My take is that if you drive a Prius with absolutely no care at all for fuel economy you will get in the 40's mpg range.
    If you drive in a conservative manner you will get in the 50's mpg range.
    If you drive like you have one gallon left and you have to go 70 miles or walk the rest of the distance you will get in the 60's mpg.
    alfon
  15. PriusDSM
    PriusDSM Junior Member
    Des Moines, IA
    I think alfon is straight on. Although depending on where you live, and the length of your trips I think low 50's is a given, high 50's is conservative driving, and anything over that you piss a lot of people off, or do most of your driving at night time with very little traffic out.
  16. walter Lee
    1,126
    376
    Maryland
    Actually 60 mpg to 70 mpg is only possible if the
    daily commutes are over 50 minutes/10 miles long,
    the driving temperatures is over 65 Fahrenheit,
    and the roads are smooth, and there's not too
    much traffic on the road. The Prius can get 64 mpg
    if the cruise control is set to 53 mph and its
    just driven non-stop for for 2 hours straight.
    Drive a full hybrid less than 20 minutes each way
    to and from work and your MPGs will only be in the 40s.
    The ICE initial warmup penalty is from 15mpg to
    25 mpg which is difficult to overcome unless the
    Prius is driven over 40 minutes- 8 miles each way.
    If the roadway is very congested with aggressive
    drivers - P&G will be difficult if impossible - inorder
    to do P&G - a hypermiler has to find a route and a
    time when it is possible - searching for that route
    and time can be problematic and often is skipped
    over when people talk about P&G. In addition, hypermiling
    takes time - the less time you have to get from one
    place to another - the less hypermiling makes sense.
    Essentially, hypermiling techniques like P&G trades
    travel time for fuel efficiency. If you don't have the time
    then most hypermiling techniques like P&G are not
    going to work for you.
    One trick I use for a quick start from a dead stop, is
    I switch on EV mode and accelerate up 25 mph very
    quickly --- At 25 mph, the Prius will automatically
    switch over to the ICE, when it does as long as the ICE is
    burning less than 1.20 gph - the FE should still be okay.
    You can't do this trick too often else your SoC will
    drop like a rock and force the ICE to do a auto
    HV recharge - which causes your MPGs to drop
    by about 6 mph. but once in a while - it can be
    done if the SoC is greater than 55%
    :focus:
    As for my monthly fillup and most recent tank ....
    car = 2010 Toyota Prius III, Blue Ribbon/Dk Grey,
    tire = Yokohama Avid S33 (50 psi / 48 psi)
    special equipment = ICE air intake 100% blocked, ScangaugeII
    date= 9/29/2011,
    odeometer= 15816
    miles travelled = 727 miles
    gallons (Mobil E10 87oct) = 10.251 gallons
    cost = 3.439/gallon (cash price)
    calculated mpg = 70.12 mpg
    Temperature range = 65F to 80F
    Weather = 33% Rain/66% Sunny-Cloudy
    Daily commute = 16 miles, very hilly, congested urban like traffic 25% of the time.
    2 people like this.
  17. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    530.6 miles
    9.817 gallons
    $3.219/gallon
    $31.60 total
    54.05 calculated mpg
    55.5 computer mpg on tank.
    $0.0595/mile
  18. mtngal
    mtngal New Member
    52
    Southern California
    $3.219 a gallon?! Really jealous about that number. I just filled up and the $3.759 I paid was less than many other stations along my route home.
    Just filled up for the second time:
    393.0 miles
    7.731 gallons
    53.7 car computed mpg
    50.83 calculated mpg
    300 miles of the tank were my normal commute, 2 round trips. Weather was interesting - left home this morning at 36F and a bit of slushy snow on the windshield, left work this evening it was 69F and 39F when I got home. Windy, too (the car isn't bad in the wind at all though I definitely knew it was windy). Now I'm a very, very happy camper, it looks like I'll be able to get what I had hoped for on a regular basis.
  19. vday
    vday Member
    312
    Israel
    36F and slushy snow in Southern Cal in Oct?
  20. mtngal
    mtngal New Member
    52
    Southern California
    An early storm, we usually get our first storm a little later. I was a bit surprised to see the bit of snow on the car - while it's not all that unusual to see early snow on the higher mountains (and it looked like there was a pretty dusting higher up, judging from the area's webcams), it doesn't usually venture down as low as the house until sometime in November.
