Mountain Bike Inside my prius?
Discussion in 'Gen 3 Prius Main Forum' started by blur510, Aug 18, 2011.
  1. blur510
    blur510 New Member
    San Diego
    Does anyone know if I can fit a medium 29er mountain bike inside my prius? I am thinking of picking one up (buying used on craigslist) Thanks hopefully someone can help.
  2. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    Was able to fit my mountain bike in my 2nd ten when I bought it. You should have no problem. It WAS a tight fit - make sure to put the rear wheel in first. Manipulate the handlebars / front tires just right and you should be able to JUUUUST put the hatch down gently. Then press down to lock.
    Click. Good to go. :0)
  3. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    *accidentally double posted sorry* <:0)
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    A 26" fit without a problem. Worse case you take front wheel off, I think it will fit just fine. I always have some bungee in my cars for a worse-case like you need to keep the trunk up, though (but you won't for this).
  5. unc69
    unc69 New Member
    North Carolina
    As mentioned, taking the front wheel off might make it easier. Also, with an allen wrench you can loosen one bolt and turn the handlebars 90 degrees so they line up with the bike frame - and usually that same allen wrench will allow you to lower the seat. Those two adjustments take less than a minute and will allow you to put a bike in a smaller confined space. I make sure the side of the bike with the chain, and derailuers, is on the side that's up so grease/oil does not get on the car and while the bike is on it's side it does not bend or affect any of that gearing.
  6. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    Shouldn't be an issue. I was able to fit my full size 60cm road bike in without issue. Check youtube and you'll find some videos of people putting in all sorts of bikes in their Prius. I would just recommend laying down a blanket first.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Yes, a mountain bike can easily fit inside since the handle is short. I got my wife an Electra Townie and it would not fit unless I take out the front wheel. The handle is long for being a comfort / cruiser bike.
    So I bought Saris Guardian 2 rack to carry both in the back. It works well with the Prius. I can still lift up the hatch with the rack installed (of course without the bikes mounted).
  8. BlizzP10
    BlizzP10 New Member
    61
    Pennsylvania
    Nothing like TOTALLY obscuring the view out the rear window!!!
  9. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    True but I only use it to go to nearby parks.
  10. blur510
    blur510 New Member
    San Diego
    thanks for all the replies!!
  11. Scotty Danger
    Scotty Danger Junior Member
    86
    Scottsdale
    Yep, I do it all the time - see attached pic. I do have to take the front wheel off though.
    I love that I can also sneak my surfboard in. I usually go riding mid afternoon and then hop in the ocean until sunset.
    I love spending my hard earned money on fun things likes mountain bikes and surfboards instead of throwing away money on oil and never-ending maintenance. What a concept :D
  12. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    That is awesome in plan and execution.
    Quick bike story about how it's best to fit your bike inside the car if at all possible:
    One of my co-workers became blind over the years but he and his wife don't let it stop their enjoyment of the outdoors. They continue to hike, cross-country ski, and bike together. (As an aside, his day job is performance optimization of other folks database queries. He uses voice software, a few other self-made software tools, and an awesome memory. I don't know if I could do it that way.)
    Anyway, they use a tandem bicycle which they mount atop their Chevy. Her jobs are to drive the car and the bike. His jobs are to load / unload the bike and provide propulsion on the bike. (Ala the ICE on the Prius.) One day they came home from a ride and stopped in the driveway. When he got out of the car, they were distracted by something, a process breakdown ensued, and she attempted to park the car in the garage with the bike still on top. There was significant (but repairable) damage to the bike, bike rack, car roof, and garage.
  13. eltee
    eltee New Member
    Evergreen, CO
    I picked up a trek 'gary fischer' 29'er special and it *JUST* barely fit in my gen3 with the rear seats down on the drive home. (i do recommend if you are thinking of going internal vs external getting a drop sheet or two from a hardware store so you don't dirt/oil/grease up the bed.
    More recently I've managed to actually fit two 29'ers in, on top of each other with an extra drop cloth between to prevent scrapes etc, but in that case both had to have the front wheels dropped first.
    If you are considering getting a bike and are thinking of internal vs external transport I would reccomend going the extra mile (or $100ish) and getting one with a disc brake, that makes dropping the front tire a 5 second affair vs 5 minute, and never have to worry about getting the brake mis-aligned over time doing it.
