Mouse incursion
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Monafly, Mar 29, 2015.
  1. Monafly
    Monafly New Member
    2014 Prius c
    I went on vacation (other vehicle) and when I came back found that a mouse had been packing birdseed into my <8000mi Prius C :(
    I've since caught one (inside) and started tearing the interior apart to get it all cleaned up (more than 3 qts recovered plus more that has been vacuumed up).
    My question is: Where is the air intake (or other openings) so that I can screen it over to make sure that this doesn't happen again?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    This has been discussed here before in some great detail.
    Summary:
    Mice can get into tiny spaces that you would never believe.
    It is almost impossible to find all the possible entry points.
    The only good long term solution is POISON.
    If children or pets or other wildlife are present, use a "safety" bait station with a rat-sized entry hole and solid bait chunks that won't come out......and bolt or weigh it down so it won't move.
    P.S. This can quickly become a MUCH bigger problem that just cleaning up a mess, as the little devils will start chewing on parts of the car and if they damage the wiring it can cost you THOUSANDS of dollars to fix.
  3. Monafly
    Monafly New Member
    2014 Prius c
    Well, I've now torn the interior apart to find and remove all the seed. Have now scooped up about 4 qts and vacuumed up even more. That was one industrious mouse!
    They got in thru the hole in the firewall up near the top and then got out of the plastic heater ducting thru a small foam covered flap that they chewed thru.
    Why Toyota couldn't have spent a few cents to put a screen over those holes is nearly criminal. I will certainly be fixing this as I reassemble everything after I get it all cleaned up. I think I was fortunate that they weren't in the car longer and don't appear to have chewed up any wiring or anything critical.
    Not sure yet, but it may be possible to access this hole if one removes the grill work on the hood. I would certainly recommend that anyone that lives in an area where a mouse incursion might be an issue somehow attach a screen over that hole to keep what happened to me from happening to you.
    48,984
    oh, what a mess! you should take it to the service manager for his edification.
    i'm not sure about the c, but the lift back has multiple entry points and details of closing them all is a huge undertaking.
    i would consider some type of repellent if possible, before they do chew your wiring. a new main harness is 5 grande. consider this a warning shot across the bow.
  5. Easy Rider 2
    1,584
    257
    Ocala, FL
    Closing that one hole will only encourage them to find or make another one.
    The only way to eliminate a mouse problem is to eliminate the mice.
    Please heed this advice. It comes from dealing with rodents in a rural environment for near to 50 years.
    In addition to the obvious problems, they can bring in FLEAS with them and in some cases transmit diseases to humans.
  6. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Please open a case number with Toyota.
    Screening off the access points by yourself can be accomplished in a couple of hours.
    Thanks,
    Dan
    prius mouse killer likes this.
  7. prius mouse killer
    prius mouse killer Junior Member
    23
    Oklahoma
    What if Toyota will not let you screen off the back vents without voiding your warranty?
    The peice
    Really? Not everyone having this problem is in a rural environment... and not all types of vehicles are prone to attracting mice. I have lived in town and out and have never seen a mouse problem where they can get in to a car as easy as a Toyota prius ... mice will always take the least obstructed path or the path of least resistance ... that being said ... a little resistance goes a long way... or and ounce of prevention is worth a pound of cure! Those of you that love your prius contact the nhtsa and let them know about this design flaw that affects safety as well so they will get Toyota to fix these openings with some screen to deter these pests nhtsa phone number in u.s. is 1-888-327-4236 call them before a mouse goes running across your dash while your driving!
    #7 prius mouse killer, Apr 29, 2015
  8. Easy Rider 2
    1,584
    257
    Ocala, FL
    Really yourself. You have no way of knowing that.
    ALL engine compartments are open to the outside world. Therefore all of them are prone to having rodents set up shop on the engine.
    The Electric Me likes this.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I would encourage you to go ahead and employ whatever screening methods you wish.
    Unless you were incredibly negligent in your installation to the point of "3 Stooges" incompetence, I don't see how it would ever become an issue. And I've never read a thread about anyone being denied warranty coverage because of an installed screen.
    If in the astronomically slim chance you would have some related problem, I would think Toyota would have to prove that the installation of the screen caused premature failure of whatever component, and I really cannot imagine how this would happen.
  10. prius mouse killer
    23
    Oklahoma
    The mice aren't in the engine... they are in the cabin, glove box and running across the dash!
    Dash board... because they are not in the engine... they are IN the interior of the inside of the cabin of the car...
    #10 prius mouse killer, Apr 29, 2015
  11. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Is this a Prius problem or you have seen mice inside the house as well?:)
  12. prius mouse killer
    23
    Oklahoma
    Just in the cabin of the prius ... the cabin being the drivers and passenger's seating area
  13. Easy Rider 2
    1,584
    257
    Ocala, FL
    Pause for just a second and try to THINK just a bit please.
    Mice like warm places, especially in the fall and winter.
    What I am trying to tell you is:
    If you do not eliminate the intruders, they will just find a different place to nest.
    In the air cleaner. In the tail pipe. On top of the engine. In the wheel wells.
    You are fighting a losing battle.
    But you seem convinced that you know everything so ........carry on and see where it gets you.
    Other people have been there and done that........but what do THEY know ??
  14. prius mouse killer
    23
    Oklahoma
    It's may now...
  15. Easy Rider 2
    1,584
    257
    Ocala, FL
    So what ?
    Once established, in or near structures, most species will NOT return to the fields in the spring.
    Assuming that your comment referred to the month of May.
    Your time would be better spent in explaining your thoughts rather than fancy quoting. :)
  16. prius mouse killer
    23
    Oklahoma
    Again... they are not in the engine ... and have you looked outsife lately? It's not winter... and I am just trying to get Toyota to allow us to screen off the back air vents so the mice stop coming in ... on other make/model cars those same screens have plastic cages over them on the inside , this model does not. It is again the equivalent of having a house with no front door. On a normal house mice will get in yes ... occasionally... when it's really cold and they want shelter but not daily and not very many ... but with no front door they are able to get in and out daily and in abundance... It almost seems as though they are drawn to the car! Maybe one of the guys building it had a peanut butter and jelly sandwich for lunch before assembly or maybe the previous owners used peanut oil to shine the plastic surfaces...I don't know and personally couldn't care why this car is some sort of mouse target, I just want a solution that will not void the warranty and will protect my daughter when she drives it to not have the life scared out of her by having a mouse run across the dash and causing a wreck!
  17. Easy Rider 2
    1,584
    257
    Ocala, FL
    I have given you the only solution that works 100% of the time.
    Quick, easy, effective and fairly cheap......but for some reason you are obsessed with a "fix" that won't really solve all of the problem.
    FYI, mice and rats and squirrels just love to chew plastic. A plastic screen is not a solution either.
    I quit. I wish you luck. I hope your daughter does not suffer because of your obsession.
