Just finished a 5 day trip to Reno with a return thru Lake Tahoe, then back Home (Sacramento). Miles: 137, 91 mpg, with 10.6 left on charge. EV use = 51% HV use =49% METHOD: Drive in EV downhill or flats. IF: you have to drive uphill: use HV. For those of you that may wonder why one would want to have still a good charge after arriving at home??? To lower your elec bill! And lessen your charge time. Incidentally, I did not use this method the entire trip, but only the last 20 miles, so you can do better. Has anybody?
From Sac to Reno then through Tahoe and back home is a heck of a lot more miles. You listed a one way downhill trip. You should include total mileage and FE from the trip up the hill as well. Otherwise it looks a bit disingenuous.
True, the climb to Reno is longer, but as I said I did not really start trying this method until I was about 20 miles from home. I prolly could have done better on overall mileage if I had. My intent of this post is certainly not to look disingenuous. Incidently, Niether side of the Sierra are totally uphill or downhill.
Unless you are paying more for electricity than gas per mile (in which case why get a plug-in?), this sounds like an unsound financial decision. Not 'perfect'.
What is the point of having energy stored in the battery if you don't use it? If you are just using techniques to have the gasoline engine charge the battery (through regeneration), why not just get the straight hybrid? The only rationale I can think of is to take advantage of the larger regenerative capacity if there are long up/downhills, but in that case one would never bother to actually charge the car.
You missed the point entirely, the real object in conservation is to burn less gas and produce cleaner air. So it matters little whether you are driving extended city trips, suburbia or long trips, with this method you always maintain a charge. Whether it be 2 miles or 10 miles is your choice. One is driving in HV only when needed. Naturally the longer trip, the easier done. Of course this cannot be done on a extended flat terrain. As far as never charging the car thru the wall plug, that would be ideal, but not attainable. Incidently what is a straight hybrid? Gen I, II, III : before PIP could also charge while driving.
Nope! I need HV to go uphill, that is predetermined. I use EV downhill and charge at the same time. I save the EV for the flat portions, that is I use some of the EV to maintain speed. Next hill, same cycle. When I get home, I still have 10 miles charge left. And it only requires ONE hour or less to wall plug charge. So I have saved on HV.....EV......and House Current.
I guess I indeed am still missing the point Using HV to go up hills and EV going down is just using the ICE to charge the batteries, via the indirect way of using the ICE to gain potential energy climbing the hill, and recovering the potential energy on the way down the hill via regeneration into the battery. If I am missing some fundamental point, I apologize. I really am not trying to be obtuse.
Yes the fundamental point, is like a bank accout, you always keep a predetermined amount in your account for when you will need it. Same with the Pip, if you push the EV useage in the beginning, you will have to run HV anyway. Unless of course, you travel 12-14 miles to work and then charge at work, you have a perfect situation. Except for energy use and that is your watt meter and the Bosses. But everybody does go on trips from time to time....You were not being obtuse, I welcome different ideas. TY
That is true, I only looked at the return from Lake Tahoe, but also I only started using this method the last 20 miles, down 50 to Folsom Rd. and home. Next trip.
If you used HV at any time when you could have used EV, you are wasting gas. If you have so few opportunities to use EV that you end up with the same as you started with, you are probably wasting a Pip, and could have done it all with a regular Prius. There is no way to save both gas and electricity by switching between them (hypermiling will, of course, save on all energy). If gas is more expensive per mile, you want to arrive home with the last of your battery energy.
Your goal is good, your logic is flawed. Given you live in Sacramento where electricity is cleaner than gas, to burn less gas and produce cleaner air, you should alway arrive home with the battery at minimal SOC, i.e. in HV mode with 0 EV miles remaining. Your technique may improve your overall MPG on the middle section of the trip, but the last 12-15 miles you should switch to EV mode, and use zero gas and hence the overall MPG would be higher. But the reported data is insufficient to support any conclusion. Without knowledge of the gain from elevation, the energy reported via MPG is out of balance. This is actually not quite true. The describe technique could be beneficial in reducing gas and still allowing more efficient use of the electricity. If one must use gas, you can save on both gas an electricity by switching/blending, if it helps keep the gas engine in its ideal BSFC points and keeps the current demand in the EV motors lower. Both the ICE and the EV have non-linear losses so more power demanded by either one alone reduces their efficiency. Its also a function of road-load not just speed so its hard to know where the optimal trade would be in a PiP. But if one must use gas on the trip, then the technique may have validity. But it will never be more efficient to return home with EV miles. The EV mode is more efficient and so the goal should always be maximize the use of that fuel.
Right, but I am presuming that Toyota knows. So HV mode should balance gas and electricity energy in those situations when some gas is needed. A driver should thus be selecting HV or EV modes depending on the one thing they know, that Toyota doesn't, namely the character of this particular trip.
Agreed that Toyota knows a lot more than all of us combined. Not clear what you mean by the driver selecting the mode for the trip, but the operator can still do more than just selecting one mode for the whole trip . The car cannot predict the future,and the driver can. The driver switching to EV as they go down a hill or head to a stop can get the car to shut down the ICE before the reactionary control systems can do it. The driver can anticipate where they will be better able to use EV (e.g. sections with lots of stop/starts), and where there will be larger hills (and save some added EV buffer for those).
oh well - so much, for the 'perfect method' In reality, you need to count every day, month after month, year after year . . . . hills . . . . . cold . . . hot . . . etc to get 'the perfect method'. That way, results count for everything, every condition, based on season after season of variability. There are folks on the boards who've accurately logged their process for years and years of driving ... 100's of thousand of miles. Now THAT's accuracy. I've been keeping a log of our EV range now for over 16,000 miles, so I can safely say what my real world results are. The next variable I'll starte to notice - i suppose - will be traction pack degradation. It's just a matter of time. .
Because I didn't say the driver should be selecting a single mode for the whole trip. I said they should select which mode to be in (at the moment), based on their knowledge of the character of the trip. It possible in the near future that Toyota will create a car which takes advantage of all information sources, and require (or severely recommend) that the driver input the destinations (until next charge). The car can then know routes, elevation changes, up-to-the-minute traffic, all to a higher accuracy than the driver knows. The car would thus be able to make most efficiency decisions better than the driver. This, to me, is the only reasonable reason to have an integrated navigation system, and it currently isn't done to any extent.
I'm currently doing research in this area. I'm aware of some patents in this space from Patent US20020188387 - STRATEGY TO USE AN ON-BOARD NAVIGATION SYSTEM FOR ELECTRIC AND HYBRID ... - Google Patents Patent US20050228553 - Hybrid Electric Vehicle Energy Management System - Google Patents Patent US7958958 - Inputs for optimizing performance in hybrid vehicles - Google Patents and GM has a number of patents in the space, e.g. Patent US7539562 - Hybrid vehicle powertrain control method and apparatus - Google Patents And some EU patens from MB (for trucks if I recall) and VW/Porche but I don't think I've seen any from Toyota. Do you have any references to some? The closest to this being in use is for fleet trucks.. and its more route planning/optmization than load-following or hybrid control work.
I find that if I get on the freeway and switch to HV mode, it will still use my EV charge until depleted. I cannot find any way to "save" the EV range.
not quite sure what that means - are you trying to say that the lowest elevation is different on 1 side then it is on the other? Because ultimately - after you make a round trip, from 1 side to the other and back - you have necessarily covered all of the variables, regarding altitude changes. ... There you go - give that man a cigar. ;-) Sent from my SGH-I717R using Tapatalk 2
