MPG trials with different parameters
Discussion in 'Gen 3 Prius Fuel Economy' started by NineScorpions, Jan 17, 2012.
  1. quickdrawgc
    quickdrawgc New Member
    I'm running everything stock Prius II
    First tank 468 miles, calculated 48.75 mpg, car was at 49
    2nd tank was 434.5 miles (didn't go all the way to empty), calculated 48.165, computer said 51.1 mpg.
    Its Florida, so our 'cold' mornings are in the 50's and 60's the last week, and 70's the rest of the time. 65-70's in the afternoon for my return commute. So I'm also not using AC more than to clear the windows.
    I'm not sure the calculated is 100% accurate, as with the fill-up the first time I didn't try to put anything in after the first click on the pump, the 2nd time i put a little more in (as the pump had clicked 5-6 times on the first 5 gallons for some reason). With my old cavalier I knew exactly how far I could go on the tank and generally put in about 12 gallons (its a 12.5ish tank) so I had a good empty to full idea and it was easy to keep track of accurate mpg.
  2. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    updated original post with tank results after tire pressure change. Now what else can I do to squeeze another mpg...lol. :rockon:
  3. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Hey Nine, good to see your MPG's goin up:). Another suggestion might be to increase tire inflation even more to or near maximum per manufacturer recommendation which is @ 51 psi. That is the pressure mine came at & I have kept it at although my DSW is 225/45/17, we both should have the same psi spec.
    Btw, my latest tank of gas was @ 46.9 mpg calculated. So, I'm getting about 4 miles consistently less than my stock setup.
    2 people like this.
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Thanks for the info. That's not too bad. It falls in line with what some of us think the GenIII suffers from upsizing.
  5. NineScorpions
    375
    64
    I am wondering how high is too high. So you are running at 51psi? Yes, my 18" DWS's are also rated at 51psi. How long have you run yours that high. Curious at what point do you wear the tires unevenly. I might consider 45 for my next trial...too late for this current tank though. I would only expect to get maybe a half mpg out of it based upon my last trial.
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I used to run 51psi in my older Kumho 17s and they seemed to wear pretty evenly but after a few years one of them developed an out of round condition or something and I can not rule out high pressure being to blame or just old age.
    I run my 15s at 50psi although they are rated at 44psi max.
  7. ETC(SS)
    6,494
    +1 on the N-78 blend.
    Don't bother with N-100. If somebody tells you there's a difference, they're either a dealer or a victim.
  8. SoCalBPrius
    563
    118
    SoCal
    You're right, not too bad & although I wish I didn't have to lose the 4 MPG, at least it's being used for better handling & good looks, always good reasons for a compromise:D.
  9. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Agreed. I'm glad it works for you. I still can't get over the loss so I swap back and forth over and over. :D
  10. SoCalBPrius
    563
    118
    SoCal
    Yes, I received it from Discount Tires Direct @ 51 psi & have since checked & kept it at that pressure. Curiously, all the wheel/tire came w/ a warning sticker labeled that it was inflated to maximum tire pressure(I just assumed they may have done it knowing that it was going on a prius but not sure as I never asked them about it). I would say inflate to at least 45 psi or more as it is still cool weather wise & I don't see any harm other than maybe a little more firmer ride. FYI, my stock Bridgestones came at 35-36 psi from the dealership. About a month after driving it, I couldn't get to 50 MPG. Than, I found & read up on some tips(inflation) on improved mileage on this forum. So, I proceeded to inflate to 38 psi than 40 psi(40 is max psi recommended by mfg.) & saw my mileage go up to 50 & beyond on every tank thereafter despite still being a fairly new prius owner & gauging it in winter time although I am in socal;).
  11. SoCalBPrius
    563
    118
    SoCal
    I may have to copy your system;) if I decide to go on long trips or for whatever other reasons as I have a 3 ton jack & it's quite easy changing out tire/wheels.
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Don't do it man. Just sell the OEMs so you are no longer seduced by the allure of 55mpg tanks! She will get you in the end and you'll be back to boring old OEM styling........
    LOL
    I love the look of my big wheels but it's so much more fun to achieve big mpg numbers.
  13. SoCalBPrius
    563
    118
    SoCal
    I agree, it is very satisfying & rewarding to my pocketbook getting high MPG, not to mention the fun(almost like a video game) trying to beat your past high mileage(MPG's):D
  14. NineScorpions
    375
    64
    I bumped my pressures from 42/40 to 47/45. The weather is all over the place right now...so not sure when I can get some reliable results. However so far on this tank I am flirting with 47mpg.
  15. SoCalBPrius
    563
    118
    SoCal
    I think you'll see some gradual increase in mpg in time. I know there are so many variables such as climate, traffic, mood & even luck(w/ traffic lights & type of people that are driving around u because if they're aggressive u have to accomodate some).
    My last 2 updated fillups have been 47.9 & 49.1 calculated. I'm trying to get to 50 on my current setup:).
  16. SoCalBPrius
    563
    118
    SoCal
    My last 2 fillup update. 49.6 & 48.1 calculated.
  17. NineScorpions
    375
    64
    not sure I can ever get there
  18. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Summer is just around the corner.... Better fuel is coming. :D
  19. SoCalBPrius
    563
    118
    SoCal
    Haha, I was driving kinda conservative to try get to 50 & on 2nd tank I said f@@k it & drove more normal. You probably drive more aggressive than me;). If I drove aggressive I would have a hard time getting 46:D.
