1. Offline
    GaryD1 Junior Member
    Start a Conversation
    Feb 7, 2011
    56
    Seagrove, NC
    Your Vehicle Year:
    I got the smaller us version mudguards with 6 self tap screws and 6 spring clips for 2011 Prius.
    Is the metal where the mudguards fasten soft enough to screw into with hand pressure using the self tapping screws or do I need to predrill small holes?
  2. Offline
    • Moderator
    Sep 22, 2005
    6,975
    1,741
    N.Y.
    Your Vehicle Year:
  3. Offline
    ct89 New Member
    Dec 31, 2010
    33
    New England
    Your Vehicle Year:
    I did not need to pre-drill, just used a hand screwdriver and a little pressure.
    Removing the tire before installing is a must.
    Also, I decided to add an extra screw towards the inner edge of the rear flaps as they just didn't seem to be held secure enough with just the two outer screws.
    1 people like this.
  4. Offline
    spiderman wretched
    Jul 5, 2009
    6,750
    1,173
    Alaska
    Your Vehicle Year:
    My Euro version didn't require any drilling into metal, only two into plastic.
    1 people like this.
  5. Offline
    Feb 7, 2011
    56
    Seagrove, NC
    Your Vehicle Year:
    While on the note of removing the back tire, can floor jack be used on rear of car? noticed it can in the center front
  6. Offline
    2,724
    395
    Greater Vancouver, BC, Canada
    Your Vehicle Year:
    Not sure if gen II is the same, but looking at the wheel well liners on our gen III, there are push-in style fasteners securing it at most locations, but near the bottom are different fastener style: having flat plastic face with a hole. Could be these are located to match mudflap self-tap screw locations?
    Off-topic: this second type of fastener look to be a royal pain to remove, if you ever want to take off the wheel well covers, to see what mud/grit might have accumulated behind. It might be possible to get them out, playing with a pin to get the tangs to release, but it is very tedious. I like to remove wheel well covers periodically, and there's invariably a lot of debris accumulated behind.
    Addendum: ignore the bit about gen II vs III, see now the OP has gen III.
  7. Offline
    Teakwood New Member
    Jun 23, 2010
    489
    67
    New Mexico
    Your Vehicle Year:
    I did some pre-drilling for some of the screws. The front is easy, since one can turn the wheels. On the rear, it probably would have been easier if I had jacked up the car and removed the rear wheels.
  8. Offline
    unkprius New Member
    Oct 20, 2010
    152
    16
    Your Vehicle Year:
    ^ Ditto here. I used an small electric drill with very small bit to pre-drill all needed holes as the plastic was really tough. Didn't remove rear wheels, in hindsight would have made it far easier/neater but took more time and work. I was putting in fog lights same day.
  9. Offline
    Feb 7, 2011
    56
    Seagrove, NC
    Your Vehicle Year:
    removed rear wheels, marked holes, used small bit. It was a breeze putting mudguards on. It took about 30 min to do all four.
  10. Offline
    cproaudio Speedlock Overrider
    Jul 7, 2010
    1,590
    344
    CA
    Your Vehicle Year:
    1 people like this.
  11. Offline
    ct89 New Member
    Dec 31, 2010
    33
    New England
    Your Vehicle Year:
    Here's a couple of pictures from my installation...If you look closely, in the second photo you can see the extra screw I added in the inside.
  12. Offline
    unkprius New Member
    Oct 20, 2010
    152
    16
    Your Vehicle Year:
    ^ I used a piece of aluminum duct tape to hold down that part, but when it finally gives out I'll put in a screw, should have done that in beginning.
  13. Offline
    mario24601 New Member
    Apr 27, 2012
    Los Angeles
    Your Vehicle Year:
    I see the extra screw you put on the rears...but maybe the 2012 flaps are different, the plastic section you put the screw on does not extend that far in the ones I just got in the mail...I wonder if they redesigned them somehow for 2012 models?
    Edit: I just noticed yours are US model, I got the Euros guess thats why they are different. Anyone with the Euro version put in extra screws?
  14. Offline
    SoCalBPrius Active Member
    Jan 8, 2012
    557
    125
    SoCal
    Your Vehicle Year:
    This is a very good idea & one that should have been thought of & included by the manufacturer.
  15. Offline
    AZGeek Semi-informed Member
    Feb 5, 2012
    669
    139
    Arizona
    Your Vehicle Year:
    Nice looking car. :) Thanks for posting pics after the install. Where did you purchase the mudguards?
  16. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,418
    1,300
    Northern California
    Your Vehicle Year:
    You don't need to take the tire off if you use a small right angle ratcheting screwdriver.
    I like the extra screw idea, I used some high quality double sided tape and if that gives out I will take the extra screw approach
Share This Page
