1. Offline
    Agnu New Member
    Jul 15, 2009
    Message Count:
    Los Angeles
    Your Vehicle Year:
    I know you can turn off the Multi-Information Display (MID) via the "Display" button on the steering wheel. However, after you turn the car off, the default setting is for the MID to turn back on when the car is started. Is there a way to have the default setting for the MID to be "off" when the car is started? I find the display annoying and would rather have it off all the time.
  2. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    You'd think that if you set it to off it would stay that way until you went back into settings and turned in back on.
  3. Offline
    dmvp New Member
    Jun 16, 2009
    Message Count:
    337
    43
    Outskirts of Chicago
    Your Vehicle Year:
    Check the "settings" menu to see if you can actually set it to "off".
  4. Offline
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    Page 203 of the manual says you can turn it off, and appears to describe that as off until you adjust the setting again, but that appears not to be the case.
Share This Page
