1. Offline
    zeddex New Member
    Jul 16, 2009
    Message Count:
    Pacifica, CA
    Your Vehicle Year:
    I know that this has been touched on before - but I just want to chime in with photos in case this can benefit someone else. I opted to go with the permanent rails and Yakima towers/racks. I could not be happier. Yes, I was a little nervous having racks installed permanently....but its really the way to go. The cross bars/towers pop off in seconds and I have no noticeable loss in MPG with only the rails. I shopped around for a good storage pod as well and settled on the Yakima Skybox 16. It fits the Prius perfectly - no interference with the hatchback or antennae and zero visible overhang from the front seats! I had the rails installed at Rack Attack in Portland, OR.
  2. Offline
    RL Prius New Member
    Sep 14, 2009
    Message Count:
    37
    Bay area
    Your Vehicle Year:
    May I asked how much does it cost you total? It looks very good !
    Are holes need to be drilled thru the roof?
  3. Offline
    ramdulari New Member
    Sep 3, 2009
    Message Count:
    148
    Your Vehicle Year:
    Looks good and I bet saves some hassle compared to the removable solutions!
    I had sent a question to Toyota and haven't heard from yet - but do you know what's the roof load carrying capacity of the Prius?
    Thanks,
    Mihir
  4. Offline
    bighouse New Member
    Sep 7, 2009
    Message Count:
    798
    121
    Guerneville, CA
    Your Vehicle Year:
    Guess that's not a good option for anyone with a Solar Roof!
  5. Offline
    jonshu New Member
    Nov 26, 2009
    Message Count:
    NY
    Your Vehicle Year:
    This looks great. I intend to buy a Prius 2010 soon and to have a similar setup.
    Bumping this issue a little bit. Can someone confirm the solar roof really does prevent installing the rails?
    I saw on a different thread ("Thule vs. Yakima Roof Rack for 2010 Prius") that it is possible to install some roof racks with the solar roof while closed, but I am hoping for this permanent solution for a no-hassle install/removal.
  6. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    0kg
    Do your own conversion if you use a mass measurement which is not SI compliant.
  7. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Your Vehicle Year:
    I don't think drilling holes in the glass sliding roof or solar panels will be very good for either.
Share This Page
