1. Offline
    PaJa Senior member
    Start a Conversation
    Sep 3, 2009
    639
    100
    Czech republic
    Your Vehicle Year:
    Looks to be a correct tapping of the reverse signal. Just try to measure the voltage at camera side to get more info - the voltage should be around 14V when the car is Ready mode.
  2. Offline
    Erikon Active Member
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Finished the install, everything works perfectly! But I'm going to get the Camry camera, this free thing is just too ugly!:sick: Wish I knew I could've requested it when I ordered, oh well!
    Sorry some of the pics are blurry, low light conditions.
    My camera install 5b.jpg My camera install 6.jpg My camera install 6b.jpg My camera install 7.jpg My camera install 8.jpg My camera install 9.jpg My camera install 10.jpg My camera install 11.jpg My camera install 12.jpg
  3. Offline
    Pequeajim Junior Member
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    You guys that have installed this HU with the JBL audio in your car, can you give me some details as to which harnesses you are using? The unit comes with four harnesses. I am having trouble trying to understand where everything plug in.
  4. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Here are some pictures of what [was shipped to me.
    Can anyone identify which cables are the JBL compatible ones?
    I've included pics of the back of both radios for reference.
  5. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    You'll use everything except one harness is for non JBL. Look at Dylan's photo instructions on page 3 of this thread, first pic shows the harnesses, you'll use the one for JBL equipped cars. Oh, and you'll find a few plugs that went into the old unit won't be used with the OttoNavi.
  6. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Ok, thanks. I will check them out. Don't know how I missed them. The one thing I do realize. This is snot a 30 minute install like I read on here somewhere.
    Ether way, everyone on here is helpful, and I am sure I will get the help I need, thanks.
  7. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Thanks dylanjones for the great information.
    I have the JBL audio and am wondering if anyone with JBL did the install? If so, did you use the supplied cable, cuz I noticed that Dylan did not?
  8. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Yes, I have JBL, you use the first cable in your picture, the one with a single connector at each end. The second cable that has two connectors on one end is for non JBL systems.
  9. Offline
    offroader Junior Member
    May 8, 2011
    44
    Your Vehicle Year:
    Use Cable E on your photos for JBL
  10. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Prius - Ottonavi Cables.jpg Prius - Prius Cables 2.jpg Prius - Cable Connected.jpg Prius - Ottonavi Cables.jpg Prius - Prius Cables 2.jpg Ok, I know I am being dumb, but with no install instructions at all for a JBL radio, I am a little befuddled with this? What makes me thing I am missing some instructions, or am a little stupid is that nobody else on here is wondering what to do with the couple of loose cables? Please be patient with me?
    I have included a couple of pics of the cables that I pulled from my JBL radio. If you look at the first and second pictures; if I use the JBL harness included (P1-E), plugged into cable (P2-A), and one of the cables included, (P1-F), plugged into cable (P2-C), plus the cable that has the RCA connectors, (only for my BU Cam), then where do cables P2-B and P2-D go?
    So did you JBL guys use the mystery connector?
    Also, I am still pondering over the blue connector, another audio connector, for bass maybe?
    Sorry about the picture goof up...
  11. Offline
    Judgeless Senior Member
    Jun 30, 2009
    1,831
    223
    Cleveland, OH
    Your Vehicle Year:
    I have a life time XM subscription on my current JBL unit. Is there any way I can connect this unit to the XM unit under the seat?
  12. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Can anyone answer my question?
  13. Offline
    Bulle Member
    Nov 5, 2011
    253
    34
    Your Vehicle Year:
    They go nowhere...
    If I remember correctly, D is the XM antenna; this version of Ottonavi doesn't support XM.
    B is the stock factory mike; cannot use it either because it's a dynamic one. You have to use the external mike from Ottonavi.
  14. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Thanks Bulle. So it appears that I will not use both B and D. I will stream Pandora and Tune Me In radio, no need for XM. I'll just hook it back up when I sell or trade the car in later.
    I thought maybe that it was for the mike, and maybe the steering wheel controls.
  15. Offline
    Bulle Member
    Nov 5, 2011
    253
    34
    Your Vehicle Year:
    Steering wheel controls are on C I believe. It will work. No stress.
  16. Offline
    PanzerFreak New Member
    Jul 18, 2012
    Your Vehicle Year:
    One question I do have about this unit is can music and videos be played directly off of an SD card? With the low prices of SD cards it would be great to always have my entire music collection in the car.
    Thanks!
  17. Offline
    JohnCleary Junior Member
    Feb 12, 2012
    SoCal
    Your Vehicle Year:
    I leave a iPod plugged in all the time for music and listen to audio books from my phone via Bluetooth. Haven't tried to listen to audio from SD card or USB drive but I'm sure you can.
  18. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    I have a large USB drive that I am going to try with the USB connectors. They'll end up in my bottom glove box. I would guess you could use a USB stick, or a portable drive. I don't know how large a drive will work since the larger/faster ones draw more power, and I am not sure the max that the port will support. Plus; since the SD Card needs to be formatted as FAT, is this also true for the USB ports? That would limit the amount of storage.
  19. Offline
    Dec 31, 2010
    23
    New Holland, Pa
    Your Vehicle Year:
    Got the unit installed. Took some advice from you guys on how to modify the fitment. Phone pairs easily, and my wife could hear me very clearly. Navigation works great, however, it took a while out in an open area for the satellites to lock. One BIG problem I have is there is no sound coming from the unit, radio, or nav unit? Believe I connected the JBL harness correctly, it plugged into the only pcable that it could possibly connect to. I checked the following:
    - Speaker wires
    - Mute is not on
    - Volume is up, in fact I turned it up quite high, like 50+ and zero sound. Turned it back down.
    Any suggestions?
    Edit: One thing I remember is that I did not take the screws out of the top. Someone said that the unit will not accept CDs if these are not removed. Would this also disable the sound somehow? I remembered it after I installed the unit, and since I am going to install the rear cam next weekend, I thought I would live with it for a week.
  20. Offline
    Bulle Member
    Nov 5, 2011
    253
    34
    Your Vehicle Year:
    For CDs,DVDs to work, yes, you needo remove these 2 screws.
    For JBL to work, you need to enable the External Amp in the DVD hidden menu.
    HIDDEN MENU
    There is a hidden menu at the DVD screen that will let you adjust some global parameters. Go to the DVD screen and press the Tune knob.
    There will be a scale at the bottom of the screen that says *BRIGHTNESS*.
    You can adjust the overall brightness of the unit by turning the Tune knob.
    If you press the Tune knob again, the next parameter will show up.
    This is for MCU version 9.02: other versions might have a different menu.
    So the parameters you can adjust are:
    BRIGHTNESS
    CONTRAST
    SATURATION
    EAMP (this is used to turn off or on an External Amp like JBL)
    DUALZONE
    (excerpt from from the FAQ: Ottonavi HU: How to customize (a bit) the UI | PriusChat )
Share This Page
