1. Offline
    Erikon Active Member
    Start a Conversation
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Rats, I had already ordered it before I knew about this. I suppose I can always download Primo, is it significantly better than the iGo8 software?
  2. Online
    ucsmfu Senior Member
    Sep 21, 2011
    1,462
    331
    canada
    Your Vehicle Year:
    its the latest one, I hope someone can figure out how to get garmin maps on the Ottonavi, that would be sweet :)
  3. Offline
    r3dl4b3l Junior Member
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    Thanks Bulle! That looks like a better place to place the antenna. Also the unit shipped with two of the skins you made and posted here the other thread. Looks great btw!
    Sent from my iPad using Tapatalk HD
  4. Offline
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    Not sure how much better it is but the Primo maps are downloadable from site such as gps underground.
    I will be trying the Garmin once I get a chance to play with the device a little more and get use to the menus and functions.
    Erikon likes this.
  5. Offline
    Bulle Member
    Nov 5, 2011
    256
    34
    Your Vehicle Year:
    OMG This is a case of plagiarism! He he.
    Can you tell me which skins exactly are shipped with the unit?
  6. Offline
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    LOL I'll have to check on my lunch break. I know there was 4 VW skins, turbo skin, blue ribbon skin, orange skin and something else. I'll post up the rest later this afternoon. You should have copyright those skins :)
  7. Offline
    Bulle Member
    Nov 5, 2011
    256
    34
    Your Vehicle Year:
    Nah... That was for the community.
    Just to improve everybody's life.
  8. Offline
    JohnCleary Junior Member
    Feb 12, 2012
    SoCal
    Your Vehicle Year:
    Installed my new Ottonaiv yesterday it works fine.
    Today I figured I should make a backup of the sd card, well the card came flying out and I just spent the past two hours looking for it with no luck.
    My question: is there a copy of the files I need in the HU or does anybody have an idea as to what files I need and if I can download them? ig08
    Thanks
    John
    Edit: I used a vacuum cleaner in all the tight spots and found it in a seam by the cup holder :):rolleyes:
  9. Offline
    offroader Junior Member
    May 8, 2011
    44
    Your Vehicle Year:
    I just picked up my unit today from the post office shipping to Canada was quick I ordered on June 25. Only disapointment is I can't find my mic, looks like my box may have been opened or some how the mic was missed. I was hoping to get the unit in this weekend but since I use my cell a lot and hate to loose my factory bluetooth does anyone know how to make the stock one work with this HU? Does anyone know if it's possible to connect a active mic to this HU?
  10. Offline
    samsonl New Member
    Apr 23, 2012
    Your Vehicle Year:
    I just installed Ottonavi HU in my Prius 2010 model but no GPS signal after ran for 15 minutes..I have to removed it again and call the company for RMA.
  11. Online
    Sep 21, 2011
    1,462
    331
    canada
    Your Vehicle Year:
    I had the same problem today, no gps signal :(
  12. Offline
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    Use this program to to get your gps port and band. You'll have to change it manually in the sys.txt file. Make sure you back up the file first. Save the program on your sd card.
    http://dl.dropbox.com/u/6599614/GPSScan_Debug.exe
    In order to run this program, go to apps, files, on the top go to other then choose your sd card on the bottom row. Find the program and run it. Write down the gps port and band#. Take your sd card out and put in your computer and change the sys.txt file's portion of gps port and band. In under 1 min you'll get a signal.
  13. Offline
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    Sorry for the delay! The preloaded skins that came with the HU are:
    Black orange
    BlueMRibbon
    Metal2
    Dark color
    Shallowbright
    TurboBulle
    Metro
    And 4 VW skins
  14. Offline
    Bulle Member
    Nov 5, 2011
    256
    34
    Your Vehicle Year:
    Wow. They put everything...
    Thanks for letting us know.
  15. Online
    Sep 21, 2011
    1,462
    331
    canada
    Your Vehicle Year:
    thanks, I got gps to work now
  16. Offline
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    I've been browsing the other Ottonavi thread about customizing and here are the current setting shipping with the HU.
    Shell version: 2.82.8
    Windows CE version: EN-Prima-V1.53-60Hz
    MCU version: D65TPRH7-BHT-V9.02
  17. Offline
    kknguyen1168 Member
    Jan 15, 2011
    235
    san diego
    Your Vehicle Year:
    ucsmfu
    So you got everything work like the way you want it?? or you still want to return it??
    V/r
    Khoi Nguyen
  18. Offline
    PaJa Senior member
    Sep 3, 2009
    642
    102
    Czech republic
    Your Vehicle Year:
    Maps are same for iGo/primo/primo2. Primo has a different UI, it is a development evolution. Some people like iGo. some Primo.
    Erikon likes this.
  19. Online
    Sep 21, 2011
    1,462
    331
    canada
    Your Vehicle Year:
    Im going to return it and go with the kenwood aftermarket nav. I barely get any reception for radio. The nav reception is flimsy. The voice guidance is really quiet. The music streaming quality over bluetooth is very bad. I think either the jbl harness they gave me is faulty or just need to get a sound adapter like pac.
  20. Offline
    kknguyen1168 Member
    Jan 15, 2011
    235
    san diego
    Your Vehicle Year:
    hi all
    any had a bad experience like USCmfc ? I going to call and cancel my order today but decide to wait and maybe when I got some more info before I return them? if it bad like he said I will not install it at all.
    Thanks all
    V/r
    Khoi Nguyen
Share This Page
