1. Offline
    JohnCleary Junior Member
    Start a Conversation
    Feb 12, 2012
    SoCal
    Your Vehicle Year:
    Yes I have synced my phone to the ottonavi, now how do I get rid of the phone numbers that I don't want on the ottonavi?
  2. Offline
    ucsmfu Senior Member
    Sep 21, 2011
    1,406
    301
    canada
    Your Vehicle Year:
    you can edit and delete directly on the navigation system
  3. Offline
    Feb 12, 2012
    SoCal
    Your Vehicle Year:
    Forgive me but I cant find an edit button
    Edit: Looks like the problem was the skin i was using. I've changed to the default skin and now can edit the phonebook :)
  4. Offline
    Erikon Active Member
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Installed the Ottonavi head unit, pretty painless thanks to Dylan's pics and instructions! My Prius has JBL so I used that harness. Couldn't get a good GPS signal with Dylan's suggestion for antenna placement, but there's a wide open space between the Ottonavi and the side of the glovebox so I wrapped a paper towel around the antenna (to avoid rattles!) and stuffed it there, which seems to work fine! Picks up four sattelites in my garage. Radio works, haven't had time to play with much, that's for tomorrow! I installed the wireless receiver for the camera on the head unit, but of course I won't know how it works till I do the camera install. Anyways, so far so good!
  5. Offline
    kknguyen1168 Member
    Jan 15, 2011
    215
    san diego
    Your Vehicle Year:
    Erikon
    please tell us how you install wireless receiver for you back up camera, I am very interest, can you tell me where did you get it, how much is it? because I do not want to go all kind trouble just install back up camera. I have same model Prius like yours, hope to hear from you soon.
    V/r
    Khoi nguyen
  6. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
  7. Offline
    kknguyen1168 Member
    Jan 15, 2011
    215
    san diego
    Your Vehicle Year:
    Erikon
    wow, I did not know they have that, I maybe order 1 too, I have not install my unit yet, it came Monday but did not have time yet, can you tell me how the sound quality, what map did you ordered, I ordered Primo, I just want everything Plug and Play and as good Rosen unit came with Prius III with/nav, maybe I am asking too much, but I heard a lot of good and bad so I am very confuse. Please let me know.
    V/r
    Khoi nguyen
  8. Offline
    Sep 21, 2011
    1,406
    301
    canada
    Your Vehicle Year:
    apparently there's a new update for the Prius Ottonavi HU, I called Ottonavi and spoke with their customer service, they told me that the update can fix all the problems I have been having.
  9. Offline
    kknguyen1168 Member
    Jan 15, 2011
    215
    san diego
    Your Vehicle Year:
    uscmfu
    really?, how do I know my unit already have an update or not? my came last Monday, when are you going received your replacement?
    V/r
    Khoi nguyen
  10. Offline
    Sep 21, 2011
    1,406
    301
    canada
    Your Vehicle Year:
    I will let you guys know once I hear back from Ottonavi, they're customer support is very slow by email, by phone they never pick up. They want me to update it first to see if it fix the reception problem before sending it back for a replacement.
  11. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Well, so far the unit seems to be working fine! I'm not an audiophile, but the sound is at least as good as the original unit. It picks up the same radio stations, don't notice any more static or issues that the original radio didn't have. The GPS performs very well, came with iGo8. Bluetooth synched my HTC quickly, streams audio perfectly. Haven't tried calls yet because I still need to decide how I want to mount the microphone. DVD is sweet, iPod works, finally I can use it! Car just came with that audio jack in the armrest, not the USB later ones shipped with. Only issue I have is how to set the clock to Eastern standard! The time zone screen doesn't scroll!
    So I'm very happy with the OttoNavi, will try installing the camera next week!
  12. Offline
    Bulle Member
    Nov 5, 2011
    253
    34
    Your Vehicle Year:
    Setting the clock...
    You may need to calibrate the touchscreen first; go Apps->Options->System->Calibration
    Erikon likes this.
  13. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    I will try that tomorrow, thanks! Annoying being on Vladivostok time! Lol!
  14. Offline
    PaJa Senior member
    Sep 3, 2009
    639
    101
    Czech republic
    Your Vehicle Year:
    Just consider the backup camera, it is valuable equipment when the rear view is limited, mostly always. The install is not so hard....
  15. Offline
    r3dl4b3l Junior Member
    May 16, 2012
    76
    Houston, TX
    Your Vehicle Year:
    Not hard just very time consuming
  16. Offline
    kknguyen1168 Member
    Jan 15, 2011
    215
    san diego
    Your Vehicle Year:
    hi all
    Just wait for Erikon to install the wireless backup camera to see how it work, I always looking for easy way:), and better do not tear anything off if not needed :)
    V/r
    Khoi Nguyen
  17. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Khoi, believe me, as simple as possible is my goal! Since I got the generic free camera I'll use the blank covering the camera hole as a mount. Cut a notch in it for the camera cable, ditch the camera bracket (too big, and I'm not drilling holes in the car!) and use strong mounting tape to attach the camera to the blank. Follow up with some silicone sealant around the gap the tape creates and the notch I make for the cable. Plug in the transmitter and use the tape to secure it to the hatch, then run the two wires to a tail light and tap into the reverse light wires. Shouldn't have to do much disassembly and the panels pop off easily with the pry tools. Anyway, that's the plan, just need a couple hours and a day that isn't in the 90's!
  18. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Did a test hookup, wired the transmitter to the backup light, lights up when the car is in reverse as does the camera IR LEDs, so that part works fine. But I don't seem to be getting enough power from the reverse wire on the HU! The led on the receiver doesn't light up, also tried hooking the camera directly up to the reverse wire in case the receiver was bad, but no power there either. Is the reverse wire 12 volt?
  19. Offline
    PaJa Senior member
    Sep 3, 2009
    639
    101
    Czech republic
    Your Vehicle Year:
    Do you mean the wire from T-tapped underdash connector LR1, pin29, thick red wire? If yes, there is a full +12V.
    If your HU switchs to the reverse view mode, there is +12V present. You can also measure the voltage level at camera to prove the wire continuity. Consult your work with the post
    My Ottonavi experience... | Page 4 | PriusChat
    Erikon likes this.
  20. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Thanks PaJa! I was talking about the blue reverse wire on the HU harness, but it's obviously a switch wire that triggers the HU to show the camera view when voltage is detected. Guess I should have studied all the camera install pics!;)
    So I connected the red receiver wire, blue reverse wire and a wire for 12 volt power together, ran the 12 volt wire down to that tight wire bundle behind the kick panel and tapped the reverse power wire. All works fine now! Mounting the camera is next!
    Some pics, not elegant but it works!
    My camera install 1.jpg My camera install 2.jpg My camera install 3.jpg My camera install 4.jpg
Share This Page
