My Prius C Review [VIDEO]!
Discussion in 'Prius c Main Forum' started by Rosso_Corsa, Aug 21, 2013.
  1. Rosso_Corsa
    Rosso_Corsa New Member
    Hey guys,
    I recently had a chance to spend some time in a Prius C. I like it!
    From browsing the forums here, my 41mpg experience probably isn't reaching the car's full efficiency potential.
    But given that small petrol cars have gotten very efficient... what made you decide to still go with a hybrid? You do get a better mpg, but with the added cost, weight and complexity, did it still make a lot more sense than a roughly equivalent petrol car?
    Also, I did some quick research about long term maintenance. But in your experience, what is the typical replacement time frame for big items like battery and electric motor? Does it offset the fuel savings in the long run?
    Anyway, great forum you have here and below is my review!
    franathan, Sergiospl and afrowalking like this.
  2. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Nice, thanks for sharing. :)
    Just to comment - the ECO Mode does *not* sap power. It remaps the accelerator input. The range is still the same, but it makes the initial travel less sensitive (and therefore the final part of travel is more sensitive).
  3. Rosso_Corsa
    Thank Rob! That's good to know. Sounds like just a different throttle mapping. I see you're getting 53.9mpg average on yours. Nice job!
  4. Requiem
    Requiem Junior Member
    28
    So is it better to accelerate briskly or slowly when accelerating from a stop? If briskly, that means keeping the Eco Score banner as high as possible without getting into the red power section?
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Depends on the hills, but keeping it out of the red is always good. Even with finances. :)
    TatumRob likes this.
  6. Requiem
    28
    Great - thanks for the clarification!
  7. bisco
    48,945
    well done, thanks!(y)
  8. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Nice video. Thanks.
    Dan
