1. Offline
    prius2go New Member
    Start a Conversation
    Aug 30, 2006
    308
    why?
    I thought it was supposed to be 34mph
    Is there a way of raising it to about 38mph B)
    I know about the MG1 rev issue
  2. Offline
    hybrid taxi New Member
    Aug 4, 2007
    <div class='quotetop'>QUOTE(prius2go @ Aug 21 2007, 06:27 PM) [snapback]500001[/snapback]</div>
    the issue is what ?
  3. Offline
    prius2go New Member
    Aug 30, 2006
    308
    or was it MG2 :p
    Due to the epicyclic gearbox the engine (ICE) has to start up to prevent one of the electric motors over revving above a certain speed
    which I thought was higher than 30mph
    I think its in the useful sticky stuff at the top of this forum
  4. Offline
    geodosch New Member
    Jun 23, 2007
    173
    New Jersey, USA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(prius2go @ Aug 21 2007, 07:27 PM) [snapback]500001[/snapback]</div>
    It's not just the MPH. If you accelerate too quickly, or if your SOC drops too low, it will exit EV mode.
  5. Offline
    philmcneal Taxi!
    Jan 16, 2006
    315
    Simcoe Ontario
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(GeoDosch @ Aug 21 2007, 05:32 PM) [snapback]500032[/snapback]</div>
    54 km/h is the max ev mode speed, you can engage ev at 55km/h but i find it sometimes kick me out so i use 54km/h as a safe bet.
    soc below 50% EV mode will not engage, lowest i've seen in ev mode is 48% (two pink bars).
    coolant must be above 40 degrees C and engine must be finished with "enrichment fuel mode" when starting the engine for the first time (anyone know how to bypass this stupid step please let me know since i use an engine block heater)
  6. Offline
    ken1784 SuperMID designer
    Dec 18, 2003
    2,894
    1,184
    Yokohama, JAPAN
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(prius2go @ Aug 22 2007, 08:27 AM) [snapback]500001[/snapback]</div>
    Because UK Prius manual says the EV mode is canceled at 28 mph.
    Japaanese Prius manual says it is 55 km/h (34 mph).
    Ken@Japan
  7. Offline
    Wayne New Member
    Aug 11, 2005
    684
    Fort Wayne, IN
    You have to be reasonably gentle to get to 34 MPH. I typically exit in the high 20's... Acceleration matters.
  8. Offline
    prius2go New Member
    Aug 30, 2006
    308
    <div class='quotetop'>QUOTE(ken1784 @ Aug 22 2007, 03:30 AM) [snapback]500084[/snapback]</div>
    Ken that looks like the reason
    Is there different software for different markets?
    Or a config setting somehwere?
  9. Offline
    Dec 18, 2003
    2,894
    1,184
    Yokohama, JAPAN
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(prius2go @ Aug 22 2007, 04:30 PM) [snapback]500167[/snapback]</div>
    I believe so.
    I'm curious how they are wrriten on other EU/AU/NZ Prius manuals.
    I don't think the setting is configurable.
    Ken@Japan
  10. Offline
    T-spirit New Member
    Jul 13, 2007
    Bristol, UK
    Your Vehicle Year:
    Mine drops out at between 30mph and 32mph. UK Spec T-Spirit.
    Was quite surprised as the manual says 28mph (which is a bit annoying if that is the case)
  11. Offline
    prius2go New Member
    Aug 30, 2006
    308
    I seem to drive in quite a bit of traffic which moves at around 30mph - dropping to 20-25mph - rising to 35mph.
    Before getting the car I thought it was all within the EV mode.
    Do you think they found excessive UK initial battery failures so backed off the setting?
  12. Offline
    hobbit New Member
    Mar 23, 2005
    4,083
    406
    Bahstahn
    Your Vehicle Year:
    If you start accelerating gently in EV and just lock your foot at
    that position, you're demanding a steady amount of torque but over
    an increasing range of RPM. *Power* is torque * RPM. Power is also
    volts * amps. So even with your foot steady, battery current tends
    to climb since its voltage is essentially constant. Once you're
    asking for 10 kilowatts, poof, that's the engine turn-on threshold
    [at nominal six-bars SOC]. To stay EV-only right up to 40 mph,
    you'd have to keep feathering your foot back and back and accelerate
    less hard as you approached it, which generally doesn't work mixed
    up in today's traffic -- you'd also be using a lot of battery, which
    hurts overall MPG.
    So don't worry about it...
    _H*
  13. Offline
    Dec 18, 2003
    2,894
    1,184
    Yokohama, JAPAN
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(T-Spirit @ Aug 23 2007, 08:00 PM) [snapback]500900[/snapback]</div>
    The speedometer dispaly is intentionally biased to meet "UN-ECE Regulation No. 39".
    http://priuschat.com/index.php?showtopic=37586&st=1
    Japanese manual says it is 55 km/h, but my speedometer reading is 61 km/h when the EV mode is canceled. :rolleyes:
    Ken@Japan
  14. Offline
    prius2go New Member
    Aug 30, 2006
    308
    that spec only says the speed should read fast
    i.e between 0% fast
    and 10% +4kph fast
    it doesnt say it should be that fast!
    I thought manufacturers aimed at 3% fast to allow for tyre wear
    are you really saying the Prius is set to be 10% fast :unsure:
    if so that would mean choosing tyre size with a 10% bigger rolling radius to bring it back into line
    If I have that the right way around
  15. Offline
    Dec 18, 2003
    2,894
    1,184
    Yokohama, JAPAN
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(prius2go @ Aug 24 2007, 02:39 AM) [snapback]501079[/snapback]</div>
    I believe our passenger cars are categories M, so the upper limit is 10% +6km/h fast.
    IMHO, it says the speed should not read below actual.
    Yes, my 2004 Japanese Prius tells me +6 km/h fast.
    The later Japanese model tells us +3 km/h fast.
    Ken@Japan
  16. Offline
    Jun 27, 2007
    1,682
    97
    Out there, somewhere
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(prius2go @ Aug 23 2007, 01:39 PM) [snapback]501079[/snapback]</div>
    My ScanGauge reading is presently half fast.
    Still working on the calibration.
  17. Offline
    prius2go New Member
    Aug 30, 2006
    308
    If I buy a US ECU will that set it back to 34mph?
  18. Offline
    wiiprii New Member
    May 25, 2007
    148
    Our 2007 Prius can drive in EV mode up to 40mph. Once it turns to 41mph the engine will turn on no matter what.
    I drive 35-40mph with the engine off all the time. I don't think 34mph is the limit.
  19. Offline
    prius2go New Member
    Aug 30, 2006
    308
    Does it say 34mph in US manual? - anyone?
    Checking realtionship between value in manual and actual :huh:
  20. Offline
    Dec 18, 2003
    2,894
    1,184
    Yokohama, JAPAN
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(wiiprii @ Sep 18 2007, 05:55 AM) [snapback]513892[/snapback]</div>
    We are talking about EV switch cancel speed, not pure EV drive mode up to 40 mph.
    <div class='quotetop'>QUOTE(prius2go @ Sep 18 2007, 06:06 AM) [snapback]513895[/snapback]</div>
    No description because the US Prius does not have the EV switch.
    Ken@Japan
Share This Page
