1. Offline
    anthofang New Member
    Start a Conversation
    Apr 9, 2009
    56
    Los Angeles
    Your Vehicle Year:
    So the situtation is that i have owned an 09 prius for about 1 week and a half. When i left the dealership, the gas tank was full. Now at a week and a half later i m down to 4 bars. This seems odd considering my consumption tracks my average mpg at 45 mpg so it shouldnt be going down that fast? What is going on? Have a been duped?
  2. Offline
    5,566
    1,154
    Your Vehicle Year:
    I have yet to own any car where the gas gauge was sufficiently linear to accurately estimate fuel usage, without the knowledge gained from actually refilling it.
    Your Prius will be even worse. The tank bladder introduces considerable variability, and will require more refills before you get a feel for the pattern.
    -- Dean, not yet a Prius owner.
  3. Offline
    nooaah New Member
    May 8, 2008
    381
    Philadelphia
    Your Vehicle Year:
    You could have driven 275 miles in a week and a half. The time doesn't tell us anything. How many miles have you driven and was the tank definitely full when you got it?
  4. Offline
    Apr 9, 2009
    56
    Los Angeles
    Your Vehicle Year:
    yes the tank was definitely full and as of now i believe its a little over 200 miles i have driven.
  5. Offline
    Kds45 New Member
    Mar 26, 2008
    South Bend, IN
    Your Vehicle Year:
    I've been driving an '08 for over a year now. The gauge is not the best judge of mileage. I've had a couple of times I thought things were way off, but when I filled up and calculated, I always run very close to what the on-board calculator shows. I'm at 52.5 now that it's warmed up. I was down in the mid 40's during the cold weather. Just drove to Florida and back and got 53 for the trip. Relax and enjoy the ride.
  6. Offline
    JimboK One owner, low mileage
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    How do you know it was full? If you didn't see the dealership top it off, you can't be sure. It's not unheard of for newly purchased cars to be driven off the lot with less than a full tank. The gauge will indicate full even if it's not quite there; the first pip on the fuel gauge could take anywhere from 50 to 200 miles to disappear.
    Meanwhile, just be patient and trust the display. Some of us have tracked the difference between displayed and actual fuel economy over many tanks, and the difference is within 2-3%.
  7. Online
    bwilson4web 03 and 10 Prius
    9,723
    2,461
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Fill up the tank and you'll have a measure of the amount of fuel burned. Then compare the pump calculated value to the display. But save the data somewhere.
    There is considerable variability in fill-up values for partial tanks. But I was able to use this data to tweak and tune different aspects of my 2003 Prius. Having a mileage record is the first step to figuring out how well the car is performing as well as learning how to optimize performance. This first set were recorded in a spreadsheet and plotted to give:
    [IMG]
    The dealer I bought the car from had put in the extra oil. Two months after buying the car, the temperature dropped.
    One caution, unexpected running out of gas can happen when the gas gauge (often called 'guess gauge') gets near the bottom. I've gone as little as 25 miles and as far as 130 miles with the bottom pip flashing. The average has been closer to 65-75 miles. In my case, running out of gas has been planned so I carried a 1 gal. spare can.
    Running out of gas lets the car continue on battery at a slow speed but I've only used the limited battery capacity to find a safe place to park and add my spare gas. There have been reports of folks going a mile but this is really pushing it. Repeated attempts to start the engine after running out of gas can set a code that has to be cleared by towing the car to a dealer ... not a good thing.
    GOOD LUCK!
  8. Offline
    Apr 9, 2007
    1,531
    70
    Virginia
    Your Vehicle Year:
    Unless you KNOW you put X gallons in the tank, you don't know how full it is.
  9. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    I would unload that gas guzzler as fast as you can. I'll give you 10K for it, which isn't bad considering that your Prius is defective.
    Tom
  10. Offline
    thelankyyankee New Member
    Mar 31, 2009
    Massachusetts
    Your Vehicle Year:
    I am in almost exactly the same situation right now (just bought an 09, first tank is going much faster than expected, etc.) but I am comforting myself with the advice given here. All of it seems sensible. I think the last post about how far you might be able to drive on the last bar is really important. If I could go 80 miles on the last bar, all my concerns are gone; if only 20, different story, but I'll have no idea until I see how much goes in the tank and even then, who knows if the dealer topped off as I would? That first bar went fast!
    I'll report back, but this is a helpful thread.
  11. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Don't chance it on the last pip. If you are down to one pip, you should have already refueled. The built-in inaccuracies of the gas gauge mean you should never push it at the bottom of the tank.
    Rest assured that the mileage shown on the MFD is very accurate. Depending on tires, most posters find it is somewhere between dead on and 2% optimistic.
    Tom
  12. Offline
    Apr 9, 2009
    56
    Los Angeles
    Your Vehicle Year:
    eh..i think i will pass because people are probably right. I didn't actually see how much gas was put into my prius when i bought it. So after refueling a few times, i will probably get better indication of how defected my prius may be. Thanks everyone!
  13. Offline
    boppo Active Member
    Mar 11, 2009
    688
    94
    Owego, NY
    Your Vehicle Year:
    I bought a used 2006 and the tank said it was full but I put 5.06 gallons in it and have driven 420 miles and it is on the 1/2 make. the fool gauge is not that good of a indicator of what it says and what it has. I would love to get 420 miles on the second 1/2 but I know it will never happen.
  14. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Five gallons fill at half full is pretty normal.
    Tom
  15. Offline
    boppo Active Member
    Mar 11, 2009
    688
    94
    Owego, NY
    Your Vehicle Year:
    No, it said it was full and I still put 5 gallons in it.
  16. Offline
    Frayadjacent Resident Conservative
    Mar 22, 2009
    375
    Austin, TX
    Your Vehicle Year:
    You know, my first tank dropped pretty quick. Dropped to 3 bars with about 270 miles. Filling it up took about 7.5 gallons. The second tank got close to 400 miles before it hit three bars.
    Don't freak out on your first tank. You won't know what your fuel economy really is until you run a few tanks. I use mymilemarker.com to track my usage.
  17. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Gotcha. I misread your post.
    Tom
  18. Offline
    boppo Active Member
    Mar 11, 2009
    688
    94
    Owego, NY
    Your Vehicle Year:
  19. Offline
    elcorazon New Member
    Sep 4, 2007
    74
    chicagoland
    Your Vehicle Year:
    You people are all crazy. I have a 2007 and routinely have half a tank at 200 miles, sometimes sooner. I rarely can hit 400 miles in a tank.
    This is all normal. Plus, first tank is likely messed up due to new vehicle - more playing - unusual stopping, driving and generally not knowing exactly how full it was.
    whole thread is silly from the OP on down.
  20. Offline
    Aug 14, 2006
    18,154
    3,451
    Sacramento, CA.
    Your Vehicle Year:
    Did anyone remember to tell the OP that he doesn't "really" have an 11.9ga tank?
Share This Page
