My wife is crazy. Help me convince her.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Rxmxsh, Jan 2, 2008.
  1. Rxmxsh
    Rxmxsh
    Expand Collapse
    Member
    339
    Fort Worth, Tx
    So here's my "problem". :cool: I was telling my wife that I'm going to get an EBH. After showing her the thread of the self install, she had some "concerns". :rolleyes:
    1. Will the EBH magically unhinge itself, fall to the ground, and set our garage on fire? :eek:
    2. If it doesn't unhinge will the engine catch on fire and blow the car up? :eek:
    3. Since we live in SoCal (Orange County) will it really benefit us that much?
    BTW - she's sitting next to me as I type this out...
  2. efusco
    efusco
    Expand Collapse
    Moderator Emeritus
    19,868
    1,100
    Nixa, MO
    No
    No
    Not a lot...but you'll still see some benefit for the early morning start ups.
  3. Rxmxsh
    Rxmxsh
    Expand Collapse
    Member
    339
    Fort Worth, Tx
    Those were pretty much my answers.
  4. apriusfan
    apriusfan
    Expand Collapse
    New Member
    6,050
    203
    S.F. Bay Area
    If the car is garage-kept, I doubt you will even see benefit in early morning start-ups.
  5. Rxmxsh
    Rxmxsh
    Expand Collapse
    Member
    339
    Fort Worth, Tx
    It is garaged kept, but when it's 40-55 degrees out in the AM, I'm getting between 18-22 mpg avg for the first bar. Oh - here's the vital info I forgot.
    My commute is only 1.9 miles each way. Roughly 10 minutes in the am, and 15 at night.
  6. Neicy
    Neicy
    Expand Collapse
    Member
    824
    Wakefield, MA.
    My opinion is you will see a benefit. I do, and also have a very short commute to work. You may not need to run it 3 hours to get the benefit though, since you are starting out at a higher temp than I am. (Tonight is supposed to get down into the single digits)
  7. Flying White Dutchman
    Expand Collapse
    Senior Member
    4,374
    300
    2012 Chevy Volt
  8. JimboK
    JimboK
    Expand Collapse
    One owner, low mileage
    2,817
    175
    49
    Chesterfield, VA
    Engine block heater.
    There will still be some benefit. The 140F that the EBH can potentially provide is considerably warmer than, say, 70F (which I assume is about the highest anyone would heat their garage to). I've seen improvement in the first five minutes of driving even in the summer.
    Rxmxsh, especially given your short commutes, I think it would serve you well. And if you need more ammunition to refute questions #1 and #2, I adamantly agree the answers are "No!"
  9. Rangerdavid
    Rangerdavid
    Expand Collapse
    Active Member
    1,324
    Boone, North Carolina
    I agree with Jim, had you included in your OP the fact that you have a very short commute, the initial answers may have been different. I think it will help you mileage if you only have a short commute. It should bump that first 5 min. bar up from 20-25 mpg to 40-50 mpg. Over the course of a tank, that can made a substantial difference, esp. with short commutes.
  10. efusco
    efusco
    Expand Collapse
    Moderator Emeritus
    19,868
    1,100
    Nixa, MO
    w/ a 1.9mile commute it would definately help. But not nearly as much as a bicycle would.
  11. Betelgeuse
    Betelgeuse
    Expand Collapse
    Active Member
    1,460
    New York, NY, USA
    Please! He's from Southern California! Any commute over 100 ft requires a car.
    Signed,
    A former Northern Californian :p
  12. Rxmxsh
    Rxmxsh
    Expand Collapse
    Member
    339
    Fort Worth, Tx
    LOL - I hear yea, but it gets cold enough to be annoying, and hot enough to be annoying. I can't show up as a sweat drenched accountant, can I? :)
  13. hyo silver
    hyo silver
    Expand Collapse
    Awaaaaay
    15,195
    1,436
    off into the sunset
    Hey, I resemble that remark. ;)
    Seriously, such a short commute is hardly worth breaking into a sweat for. By the time you've changed into and out of the lycra, you may as well walk.
  14. atroader
    atroader
    Expand Collapse
    Engineer
    39
    Atlanta, GA
    First of all, welcome to marriage :p.
    Secondly, I was crunching some numbers recently, and an engine block heater, with current gas prices, and an increase in the first 5 minutes of driving from 25 mpg to 40 mpg at an average distance of 3 miles, will only pay for the cost of the green energy it uses (if bought at $4.50 / 100 kWh) vs. the cost of the additional gas used at $3/gal for the first 3 miles.
    Additionally, the EBH, if plugged in for say 3 hours, and if a 1000W heater, will require twice the amount of energy be used than from the additional consumed gasoline for the first 3 miles- so you're really doing the environment worse as far as CO2 emissions.
    Sure, if it's green energy, you can argue that no CO2 was produced, but w/ our energy infrastructure currently limited, that green energy should be used elsewhere.
    JMHO as an engineer.
  15. JimboK
    JimboK
    Expand Collapse
    2,817
    175
    49
    Chesterfield, VA
    It's 400W.
  16. atroader
    atroader
    Expand Collapse
    Engineer
    39
    Atlanta, GA
    Thanks, I wasnt sure. I'll look at the numbers this evening on my spreadsheet- but it looks like cost- which was I think $0.14 per 3 hour heater run (or fuel cost) would decrease by the equivalent, or 2/5 of 14 cents. At that rate, energy use should be almost equivalent also, so pick your poison.
    ...Alternatively, It'd really be great to have a cat converter heater.
  17. Rxmxsh
    Rxmxsh
    Expand Collapse
    Member
    339
    Fort Worth, Tx
    Well, (this will sound kinda bad) I wouldn't be getting the EBH to be greener. I'm just looking for better mileage, which - IMO - I would recieve, especially in the AM.
    But I am interested in your numbers based on the 400w vs. the 1000w....
  18. Godiva
    Godiva
    Expand Collapse
    AmeriKan Citizen
    10,339
    Tell wife no, no and yes.
    I'm in So. Cal and almost exact as you. Garaged (but no insulation or even drywall) and commute almost the same. I drive 12 miles each way, about 10-15 min. I have seen an improvement in mpg since the install. I have my EBH on a timer to turn it on just 3 hours before I leave for work. BTW I'll be blocking my upper grill this week until the weather warms up. Just because we don't have extreme cold and snow doesn't mean we can't benefit from some of the cold weather tricks others use.
  19. Rxmxsh
    Rxmxsh
    Expand Collapse
    Member
    339
    Fort Worth, Tx
    Cool. How much of a benefit have you noticed? Worthwhile, in your opinion?
  20. atroader
    atroader
    Expand Collapse
    Engineer
    39
    Atlanta, GA
    Looks like:
    block heater nrg analysis
    127000000 J/gal gasoline
    without heater
    3miles for warmup
    25mpg for warmup
    0.12gal gas for warmup
    15240000 J fuel energy for warmup
    with heater
    3miles for warmup
    40mpg for warmup
    0.075gal gas for warmup
    9525000J fuel energy for warmup
    fuel nrg savings 5715000J
    Block heater nrg input
    3no hours
    400W block heater
    4320000block heater nrg
    xtra energy used by block heater-1395000
    ** a power plant at ~70% efficiency will also emit more CO2 than this energy lets on.j
    ...so, it looks like you could come out ahead.
