1. Offline
    cproaudio Speedlock Overrider
    Start a Conversation
    Jul 7, 2010
    1,591
    345
    CA
    Your Vehicle Year:
    $100? Are you kidding me? That cost more than the bypass itself. The installation cost should reflect 1/2 hour to an hour of labor. If the shop is charging $100/hour, they're ripping off their customers. It's easier to install than a car stereo. Auto mechanics charge less than that. Install shop labor is less than repair shop labor. You should not pay more than $50 for the installation. I have installed about 5 of these and I never charged a dime for them. As for sporadic location point. It shouldn't happen while the bypass is on. When you switch on the bypass, the speed drops from whatever your current speed to 0-4km/h. All the bypass that I've installed have the position instantly stopped when the switch turned on. The only time the GPS position acts sporadic is when you turn off the bypass and the nav is updating the current position. The speed resumes then, with the help of GPS antenna, the position gets updated. The position would jump from the position were you initially turned on the bypass to your actual current position instantly, giving you the illusion of sporadic GPS position. It is the same way as the Prestigious society.
    Prestigious Society Navigation and Video Enhancement Module - YouTube
    Anyway, as I've said before, you shouldn't be in the map display when you're using the bypass. Also, when the bypass is off, it's a straight connection from the factory harness to the nav unit.
    I read the problem you're having on http://priuschat.com/forums/prius-v-audio-electronics/104080-entunes-1-8-4-a.html#post1561152 The general vicinity is tracked by the GPS antenna. The forward movement of the vehicle is tracked by the speed pulse on the VSS. The small blue dot you're referring to is the actual position of the vehicle via GPS. I get that sometimes on my nav. It has nothing to do with the nav bypass.
    My problem that I have once in a while is the nav speed is registering 10X the actual speed when the bypass is off. When I get into the service menu and to the vehicle status, it shows the speed at 500+km/h. This is when the bypass is off. Once I exit out of the service menu, the correct speed resumed and the GPS position is corrected. The bypass didn't cause this. I noticed this behavior shortly after I received the car.
  2. Offline
    Vamc555 Junior Member
    Feb 21, 2012
    38
    Indianapolis
    Your Vehicle Year:
    I know it is too much to pay, but i had no option. I found only a couple of good car audio shops and this was the cheapest option. They took a little over an hour to do the installation and i argued with them why it took them so much time and they said that its a new one and they never did this type of installation and since i am not from this country, i could not argue more with him, but i am happy i went with this and it would have costed me $400 if i went with prestigious society option...
    Thanks for the explanation on how the nav bypass works. It makes sense..
  3. Offline
    samyul Junior Member
    Apr 3, 2012
    60
    Your Vehicle Year:
    I had been using the voice command, but for certain addresses, it just doesn't seem to work. The past several times, I ended up just going with the nav on my phone. I'm debating whether to go with the Priuschat one for $80 or the Prestigious Society one for $309. I'm definitely not a handyman, so if I go with the Prisuchat one, I will for sure have to pay for labor. Let's say that costs about $100. That make the price difference about $130. At that point, I think I'd be more inclined to go with the Prestigious Society version as it is reversible and less intrusive. Am I missing something here?
  4. Offline
    Jul 7, 2010
    1,591
    345
    CA
    Your Vehicle Year:
    You can print out the installation instructions for the 2012 Prius v, go to the stereo shop and get a quote. It's about 30 minute to an hour of work. You can ask how much the shop charge per hour.
Share This Page
