nearly 21,000 miles on OEM filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Former Member 68813, May 3, 2015.
  1. Former Member 68813
    3,524
    981
    US
    finally got that sucker off with a tool from ebay. 20,933 miles to be exact, mostly highway, took about 6 months. not plugged, but small amounts of semisolid dirty deposits on media. Magnetic drain plug showed very small traces of wear metal fuzz (very minimal for 10,000 mile oil OCI). 0W20 penzoil platinum was used for slightly over 10,000 miles, before that dealer's oil, supposedly mobil 1. Oil dark brown with no particles in the drain pan. Next OCI, I'll start doing 15,000 mobil 1EP OCI. sorry for the phone picture quality.
    Robert Holt likes this.
  2. Gary Kanakis
    Gary Kanakis Junior Member
    United States
    I'm curious why you waited "nearly 21,000 miles on OEM filter"??
  3. Former Member 68813
    3,524
    981
    US
    because when i tried to remove it after 10,000 miles, my plastic filter tool was too flimsy to deal with this filter tightened as hard as possible by the dealership grease monkeys. i replaced just oil and left filter for another 10,000 miles.
    #3 Former Member 68813, May 3, 2015
    48,862
    is this the worst oil filter ever designed?my old mercedes had a canister. unscrew the wing nut, take the cover of, lift out the element, and reverse. clean and easy, no tools required.(y)i'm thinking of going to every other or third year, i only do 2,800 miles a year in hv, and how much of that is the ice running?
  5. Gary Kanakis
    United States
    Understandable, yes buying that tool makes it much easier.
    I bought mine after the second oil change.
    27 oil changes latter, I think its paid for itself for me!
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Two wrongs don't make a right.
    Letting the filter go that long was WRONG.....as evidenced by the sludge it accumulated.
    Going another 15K miles before changing oil and filter again will also be WRONG no matter what materials you use.
    I would suggest that your next change should be a short interval.......like 5K maybe and then you should follow the 10K recommendation.
    In my book, LONG extended oil change intervals is just asking for trouble and not worth the few pennies saved.
    DoubleDAZ likes this.
  7. Mendel Leisk
    38,101
    Good to see you finally got that off. I use a very solid 1/2" drive breaker bar with ratchet mechanism (with 1/2" to 3/8" adapter), extension, and a Honda filter socket that's a spot-on fit at 64.0 mm face-to-face. The socket doesn't (obviously) have extensions to fit around the housing stiffener, but never any problems.
    OTOH, the only time the filter housing was installed by anyone else was at the factory.
    In this pic The other socket is the old size Honda used to use, but not for decades. The smaller size used to be for bikes only, that's why I got it. Now 64.0 mm is the norm for both companies.
    I checked the face-to-face dimension of my (Honda) socket, it's actually around 64.5 mm. The battery on my digital caliper has died, this is just reading the decent physical increments. I'd think it would be referred to as a 64 mm socket though, since socket size usually references the piece it's for, not the socket with it's additional tolerance. Probably the same size as those sold with the 64.5 spec. Latest part number for this item is 07AAA-PLCA100. Quite solid: wall thickness slightly over 2.0 mm thick, measured at the center of a face.
    #7 Mendel Leisk, May 3, 2015
  8. Former Member 68813
    3,524
    981
    US
    they say penzoil oils should have cleaning action. maybe they do indeed. this OCI will be short at 10,000 since i used PP again, and the next after that will be 15,000 with M1EP. my friend is shopping for a honda civic and from i understand their oil minder indicates 12,000 mile when 100% hwy driving and oil filter every other oil change. so, toyotas limits are conservative considering there is no oil minder.
    now, extended intervals are for lots of hwy driving, not applicable for someone who short trips or drives in city.
  9. Mendel Leisk
    38,101
    With our last, 06 Civic Hybrid, the Maintenance Minder would get down to 15% remaining anywhere between 8500 and 9000 kms. I always changed then, but I'd guestimate 0% would happen around 10000~11000 kilometres. What does that translate to, 7000~8000 miles.
    Mind you, that's with a real mix, good number of short trips. Honda's MM is not directly monitoring oil condition. I'd hazard a guess it's counting start ups, mean coolant temp, mean speed, as well as distance travelled.
  10. Patrick Wong
    18,198
    6,461
    I do not think that is a good idea. If the car is only driven 2,800 miles/year, change the oil annually to get accumulated moisture out of the engine crankcase.
  11. bisco
    48,862
    thanks patrick, thats what i was afraid of. seems like a waste of oil, too bad there isn't a way to separate the water.
  12. Patrick Wong
    18,198
    6,461
    In your case, use of 5W-20 mineral oil (instead of full synthetic 0W-20) would be reasonable, to keep the cost of oil changes down and considering the very low miles logged between oil changes.
  13. bisco
    48,862
    that's a good point, what about the frequent cold starts in low temps sometimes at high speed? doesn't the syn coat the walls better?
  14. Patrick Wong
    18,198
    6,461
    Probably, but at the rate you are driving the car, the lithium-ion battery will probably be dead due to age way before the engine displays any wear symptoms...
  15. bisco
    48,862
    you're right again, as usual. i'm way overthinking this. i would be better off if the ice was a range extender. and no, i don't want a volt, too small, but the concept is interesting for my driving habits.:)
  16. Mendel Leisk
    38,101
    That's what honda says, in a way. They have the in dash maintenance minder, says when to do what. But in the owner's manual there's a proviso: if you're low enough mileage that the MM doesn't tell you to change, change it yearly.
  17. hlunde
    hlunde Member
    419
    74
    Given the diminutive size of the Prius oil filter, I think that the wise choice would have been to have a dealer change the oil.
  18. Former Member 68813
    3,524
    981
    US
    wise? some other people would argue it was not wise let them do the maintenance in the first place. these are the same people who over torqued the filter in the first place. same thing happened in my RAV4, the metal filter cartridge (different design than prius) is all jammed and can't be taken apart like it's supposed to be.
  19. hlunde
    hlunde Member
    419
    74
    Can you estimate how much torque was required to unscrew the filter -- just length of moment arm and force applied?
  20. Mendel Leisk
    38,101
    One of the torque wrenches with needle pointer might help, to measure effort needed to break loose a fastener.
