Need to remove antenna at carwash?
Discussion in 'Prius v Main Forum' started by bulajap, May 20, 2012.
  1. bulajap
    bulajap Junior Member
    Niagara Flls
    Hi everyone....
    Just bought my first Prius about 3 weeks ago.
    If I bring my Prius through the carwash ( I use DeltaSonic....they do not use brushes) do I need to unscrew the antenna before going through the car wash?
    thanks
  2. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    If nothing in the car wash can bend the antennae you are probably OK. Probably OK even with regular car wash but they do insist on taking the antennae off.
    I got one of the shark fin antennae so I don't have to bother with it. Now if I can just get them to stop taping the rear windshield wiper, I could make a clean getaway.
  3. Mike500
    Mike500 Senior Member
    2,593
    763
    Another advantage of the "shark fin" is that it will not snag on a car cover.
    More importantly, the reception is equal to the OEM antenna.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I have never removed mine...
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    The seal on the antenna is supposed to keep moisture out of the connector. If it corrodes, it tends to mess with the reception. If it gets really corroded, you will have really poor reception!
    Leave it on, or insist the Car Wash blow compressed air in the antenna screw in socket, and get that moisture out of there!
  6. schinia
    schinia Member
    162
    25
    cape carteret,nc
    toyota also tells you to fold your side mirrors in too !
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Do you have a Prius v wagon? Your info says solar roof which which I didn't think was available on the v wagon.
  8. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    I believe he posted to the wrong forum.
