New 12 volt battery alternatives to OEM
Discussion in 'Gen 2 Prius Technical Discussion' started by Agape, Jul 19, 2011.
  1. Agape
    Agape Member
    378
    Ireland/Eire
    Hi All,
    This thread is to look for alternatives to OEM batteries. Currently no batteries in my links below are available in US. They are available in UK and in some European countries.
    I looked a few alternatives to OEM 12 Volt auxiliary Prius batteries and found alternative for less than $100/€80:
    It appear that VARTA sells replacement batteries for both I and II Gen Toyota Prius
    US site(specifications and technical data):
    ProductFinder - VARTA Automotive
    http://us.varta.com/
    http://www.johnsoncontrols.com/publish/us/en/products/power_solutions/Brands/VARTA.html
    Not sure where you can purchase them in US (could someone confirm they are available in US) Battery Code: Varta B33 or Varta 157
    Edited: ( :(this battery is currently not available in US )
    for US please see this thread (post number #6 by jtrosario):
    http://priuschat.com/forums/gen-ii-prius-main-forum/9271-replacement-12-volt-auxiliary-battery.html
    UK/(European) reseller:
    B33 Varta Blue Dynamic Car Battery 45Ah
    I would need to check with BOSCH Europe as 2nd alternative for European Prius owners , however their online part finder is quite poor.
    Regarding 12 V battery. In US company ''Johnson Controls'' are listed as company with agreement with VARTA. It would be worth asking about their stock or even new type of Start-Stop batteries.
    Interesting article below:
    http://www.prnewswire.com/news-rele...-edison-best-new-product-award-119606704.html
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    The battery does not seem to be available in the US.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    At least your country is listed. Canada isn't! Impressive myopia!
  4. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    Bonus if the battery is a sealed battery that can be shipped. I think that's what makes the Optima Yellow-top so popular - you can order it online.
    I imagine that the challenge for getting a different 12V battery would be how to get it shipped for a reasonable price.
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    With minor adaptations, approximate size, approximate AH rating, almost any battery will do. One important point that is not well known is: It is recommended that every car/truck battery be charged about every 6 months. I will probably get all sorts of flak on this, however if ones interested in trouble free driving, it makes sense to me!
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    The prius is the ultimate case of an automobile that requires a deep cell battery, leave a prius in ALT mode (12v systems running, ice unable to spin) and the 12v dies in a half hour, once a battery dies it's dead unless it's a deep cell battery, The optima is an excellent deep cell battery that's got the bonus of being a Jell battery, it can be installed inside the cabin of the car and it doesn't emit noxious gases.
    Installing a battery that requires periodic topping off with distilled water would be detrimental to the passengers of the vehicle and possible to other users of the road.
    IMHO,YMMV
  7. El Dobro
    El Dobro A Member
    6,972
    3,209
    On another forum, a fellow that worked for a battery manufacturer recommended that giving a battery a good charge around every three months would increase its life. It was something about how the car's charging system doesn't bring it up all the way, unless you're always driving about 8 hours.
  8. andyprius
    2,212
    188
    Good point, I and others feel the charging system is insufficient, perhaps current limiting. Could be the Engineers designed it so to protect something. The HV ?
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Humans? If a lead acid battery overcharges, hydrogen gas is created. (which is why you only want an externally vented battery in a Prius, the battery is in the passenger compartment with you) If the battery expands too rapidly due to overcharging, you have sulfuric acid in the passenger compartment. (Which is why you only want AGM batteries in a Prius)
    Someone at Toyota may have decided overcharging was bad for their customers.
  10. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Excellent point. Another reason to use ONLY AGM batteries is that in a crash, you don't want all that acid splattered all over the passenger compartment...ouch!
  11. andyprius
    2,212
    188
    The VW Bug had a battery under the seat, a wet cell, not vented. Never did any H2SO4 splash all over me, nor did the car explode because of a overabundance of Hydrogen gas. I owned it for 10 years. But continue to worry, as FEAR drives the market. Pardon my English, but I think the fear ramblings are total BS. :cheer2:
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    My Aunt drove a 1969 VW Bug...and one day she called my parents distressed because it wouldn't start. My father asked her if she had checked the battery. "What Battery?" was her response...she had driven it a decade without even knowing a battery was in the back under the seat.
    So you are quite correct about VW bugs and their respective batteries. BUT...I don't think this discussion is based so much on fear but simply honest possibility and chemical reality.
    I also remember a story from a High School teacher of mine that talked about being in a wreck in a VW Bug and being injured by the battery that somehow was released within the cabin.
    So just because something hasn't happened to you, doesn't mean it can't happen.
    The Battery under the seat of the VW Bug, was not the greatest aspect of the vehicle. In 40+ years, we've come a long way in automobile and battery design and technology.
    You can do what you want, but I'd recommend a sealed, deep cell, gell battery in a Prius. Why not? It's kinda one of those things you hope you never need to benefit from, but IF you do? You'll be glad you made that choice.
    2 people like this.
  13. eestlane
    eestlane Member
    110
    Space Coast, FL
    Talking about a VW Bug, I installed a second battery under the other side of the rear, connected in parallel to the OEM battery, to help start the car in the cold St. Louis winters. Worked well, started every time, no gas discernible and no explosions! Much of this stuff has to do with lawyers getting overly involved.
  14. Mendel Leisk
    38,247
    Regarding periodic charging: there a number of chargers available that taper the charging rate down as the battery approaches full charge, can even be left on indefinitely. They will also run a "desulphating" cycle (no clue what that is, just reporting ;)), as part of the charging. I hook up a CTEK 3300 periodically, especially if something's happened, like a door left ajar, map light left on, etc.
  15. El Dobro
    El Dobro A Member
    6,972
    3,209
  16. andyprius
    2,212
    188
    Good practice, I have 4 different chargers and all of them will eventually equalize to the battery voltage and charging will diminish to almost nothing, if left on long enough.
  17. andyprius
    2,212
    188
    Good article, TY
  18. andyprius
    2,212
    188
    The Electric Me: I agree with all aspects of your post, TY :D
  19. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    There are still cars in production or in use where the battery is inside the car, three that come to mind are Mercedes A class (under driver feet) Renault Scenic Megan (under front seat) the original Mini van and pickup (behind drivers seat) and there are probably many more.
  20. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I enjoy my frugality as much as the next person, but not at the expense of personal safety, and most definitely not for -- at most -- $50 savings every 4 years or so.
    Think about it -- people are talking about risking sulfuric acid burns to save one dollar a month. 'Ouch' does not even begin to describe it. Try being skinned alive.
