New 12 volt battery improved MPG
Discussion in 'Gen II Prius Fuel Economy' started by aolm, Apr 15, 2011.
  1. aolm
    aolm Junior Member
    78
    New Jersey
    My 05 battery was showing 9 volts on the MFD... and we got the red triangle a couple of times on start up. I have read on the site that my MPG might go up with a new battery and I have picked up 4-5 MPG's. I thought my low MPG"S were due to aftermarket tires. The battery was $250 (you have to use the dealer)... a lot for a car battery but it will pay back a little every fill up. I'm gently driving to about 51mpg.
  2. F8L
    19,149
    4,010
    Sacramento, CA.
    2013 Chevy Volt
    That is great news. :)
    YouCan also purchase and install an Optima D51 yellow top battery. They are cheaper, higher cranking amps and a deep cycle battery. Installation is a little more complex than the stock battery but instructions included with the purchase make it simple.
    Elearnaid.com sells the optima kit for $180.
  3. aolm
    aolm Junior Member
    78
    New Jersey
    Can you post the instructions?
    Tks
  4. JimboPalmer
    JimboPalmer Tsar of all the Rushers, Nadir of Wrongness
    8,238
    2,539
    Greenwood MS USA
  5. F8L
    19,149
    4,010
    Sacramento, CA.
    2013 Chevy Volt
  6. richard schumacher
    7,652
    884
    United States
    $250 is a bit steep for an OEM battery with dealer installation. MSRP is about $140. Five years from now when it needs replacing again look for a dealer who will do the job for $200 or so.
  7. mlbumiller
    mlbumiller Junior Member
    sage cali (near temecula)
    I was just quoted $367 for the aux 12v battery plus $99 install @ Temecula Toyota CA
    Told the high price is due Prius is only vehicle to use that size battery.
  8. MJFrog
    MJFrog Active Member
    779
    252
    SE Michigan
    2011 Nissan LEAF
    Find a more reputable stealership if they're going to charge that much.
  9. ystasino
    ystasino Active Member
    784
    44
    Honolulu, HI
    First, 9V is so low, I am wondering whether it is an erroneous reading. Is 9V sufficient to power up the car?
    I got mine for ~ $178.37, changed at 11.9V w/o charge and got quoted as high as $320 and $240. Shop around.
  10. cwerdna
    cwerdna Senior Member
    12,373
    1,951
    SF Bay Area, CA
    As I answered in another thread. Run away! That's a TOTAL ripoff.
    I changed it myself to Toyota Prius 12 Volt Auxiliary Battery with install kit for 2004 - 10. There is no cost savings going w/the Optima battery but there are claims that it's superior to the OEM one.
  11. Oldwolf
    Oldwolf Prius Enthusiast
    670
    63
    NC
  12. mlbumiller
    thanks !! i am taking this quote to my dealer ship and getting the parts manager and general manager to explain the dealerships rip off price
  13. striker308
    striker308 Three time Prius owner
    293
    38
    Evans, NY (USA) / South Williamsport, PA (USA)
    i just had to get one last night. North town Toyota in williamsville NY had the Blck one(the one used in the pri w/nav and smart start) for $138.97 after NYS got the taxes it cost me $157.62 there was no core charge and that confused me as EVERY other battery I have ever gotten for one of my cars had a core charge. The guys there also told me to swing by Sears hardware and pick up a 12V lawnmower starter battery ($12.93 w/tax) and hook it to the Jump start connection and ground under the hood so I could keep all the memory and settings when changing the Aux Battery. They even asked me if I had brought the car in for the inverter coolant pump swap yet. Good crew over there...... Much better than at Fuccillo Toyota where I bought the car.
  14. 05azprius
    05azprius New Member
    83
    phoenix
    out of curiosity, why would anyone pay to replace a battery???
    oh and my MPG has sucked...i've had the car for a month, the 12v was dead from sitting after the accident (unknown timeframe sitting), i ran my "special" battery charger on it (brings them back to life by desulfating) and it has been holding charge ever since, however i started with around...42-45mpg, and it has been slowly decreasing, down to 36mpg average. also there are no other signs of issue except i noticed my mpg screen keeps resetting.
    i went in to the battery voltage display and it says 9.8V. going to go grab my battery tester and load it down, and see what happens (if it kills it...it kills it, autozone says they have the optima d51 in stock for $166 here, toyota dealer quoted me $99 for oem, i claimed i was a shop and they told me $72)
  15. 05azprius
    83
    phoenix
    battery failed the load test...
  16. richard schumacher
    7,652
    884
    United States
    And that's why people pay to replace them.
  17. 05azprius
    83
    phoenix
    i understand why you PURCHASE a new battery, i don't understand why you would pay someone $50-100 to INSTALL something that takes 10 minutes and a pair of pliers.
  18. richard schumacher
    7,652
    884
    United States
    Ah! Thanks for the clarification.
  19. Solar1953
    Solar1953 Junior Member
    17
    Arlington, TX
    After reading all this, and the fact that my 07' mileage is down from the usual 42 MPG or so that I usually get to around 40 or even less, I am looking into replacing teh 12V battery; My question is: are there any tricks to replacing it, or any step-by-step procedures that must be followed? Or is it as simple as, was stated above, using a pair of pliers (actually wrench) and about 15 minutes work?
  20. richard schumacher
    7,652
    884
    United States
    I lean pretty hard to the follow-the-steps side. How to remove the ventilation covers and the multiple attached cables safely may not be obvious, and it is annoyingly easy to lose a particular bolt and screw into certain dark deep body spaces. Maybe I'm slow, but it took me a good hour to install an Optima using eLearnaid's very good kit, their instructions and every one of the tools they call out (and I wish I'd had a bench vise also, to help get that dang positive clamp loose). Swapping in an identical Toyota battery should be a bit easier but if you've never swapped a battery before think carefully about making this your first.
