1. Offline
    playcool-7 New Member
    Start a Conversation
    May 8, 2011
    Raleigh nc
    Your Vehicle Year:
    hi I am installing ,2 new 4kwh battery and2, 5kw conv. parallel in my 09 prius need to know from where I can get rear springs update. let know my progress.
  2. Offline
    Sep 6, 2005
    1,850
    280
    N.Babylon, Long Island, NY
    Your Vehicle Year:
    you're adding serious weight there
  3. Offline
    May 8, 2011
    Raleigh nc
    Your Vehicle Year:
    I have place order for springs. POHL SPRING WORKS, tele # 800 777 1284 or Call MIKE 509 535 3649 .. It is 2 springs for rear 500 lb for $325. I got my second kit and working on it.
  4. Offline
    ericbecky Active Member
    Mar 12, 2004
    843
    237
    Madison, Wisconsin
    Your Vehicle Year:
    Be very careful running two converters. Test it out on a fairly deserted road before taking it into traffic. There are times with a Gen II Prius where you will put too much current into the Prius and the car will shut down. You will not be able to accelerate and will need to immediately pull over, stop the car, and turn it off and on again before it will work properly. I am speaking from experience. You do not want this to happen to you at freeway speed in traffic! It is dangerous to you and everyone around you.
    2 people like this.
  5. Offline
    banshee08 Member
    Aug 7, 2009
    279
    70
    El Monte, CA USA
    Your Vehicle Year:
    I have a Gen3 (2010 model year) Prius purchase in 2009. Is the two converters going into a Gen3 or Gen2 prius??? Make sure to have the voltages in both converters set to the proper voltages for your prius else you can easily over charge the battery stopped at a long red light.
    1 people like this.
  6. Offline
    May 8, 2011
    Raleigh nc
    Your Vehicle Year:
    thanks It is for 2009 Gen 2 prius, it looks u have 8kwh , how is the set up, i am still working over it. thanks
  7. Offline
    stefano5777 New Member
    Mar 15, 2011
    380
    46
    St. Petersburg Florida
    Your Vehicle Year:
    You should be asking ericbecky that question since he is a installer of these systems with vast knowledge and experience.
  8. Offline
    Sep 6, 2005
    1,850
    280
    Your Vehicle Year:
    Do they have an specialized part number for this type of Prius rear springs? Is it a custom made part or an adapted generic one?
  9. Offline
    May 8, 2011
    Raleigh nc
    Your Vehicle Year:
    hi, It is a custom made, for prius. thanks
Share This Page
