New EV tickers on this site: http://www.chevrolet.com/volt-electric-car/
Discussion in 'Chevrolet Volt' started by scottf200, Apr 24, 2012.
  1. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    New EV tickers on this site: 2012 Chevy Volt | Electric Car | Chevrolet
    * Heads up via FB and Matt S
    Incrementing tickers of "Data Provided by OnStar":
    - Total EV miles driven (32,000,000 and VoltStats.NET at 4,000,000)
    - Total miles driven (54,000,000 and VoltStats.NET at 5,600,000)
    - Total gallons of fuel saved
  2. john1701a
    john1701a Prius Guru
    9,445
    2,581
    Anyone know what that “Official MPG for US passenger cars†value is?
    PHV uses a different approach. Rather than comparing to other vehicles, it compares to its own efficiency when not plugged in... which gives a clear representation of what the plug-supplied electricity accomplishes.
    dbcassidy likes this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,915
    Fort Lee, NJ
    How many kWh of electricity were actually consumed?
    Using the EPA figure, all the Volts should have consumed 11,854,363 kWh.
  4. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    Pretty awesome using all that USA/domestic fuel.
  5. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    If we do the math backward, it came out to 18.38 MPG.
    32,166,123 EV miles driven / 1,749,963 gallons saved = 18.38 MPG
    If we use Volt's 37 MPG EPA figure, it should be 869,355 gallons saved. So Volt would use 11,854,363 kWh to substitute 869,355 gallons.
    If we hold Volt to Prius PHV 50 MPG standard, Volt would save 643,323 gallons.
  6. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    Using domestic fuel (mostly coal) can be good or bad depending on what you are trying to achieve.
    Remember, about a third of gasoline is also domestic.
  7. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Not user if that math is backwards, but its definitely wrong.
    The computation is in a footnote.. its not just EV miles.. since the volt gas is also above average you need to consider all miles vs all gas..
    Comparison to the US average is,however, meaningless. Comparison should be to what car they had or what they considered. Consider to a Prius is like considered to moped.. both get better mileage than the average car but neither is what I am willing to drive. I compare mine to a BMW 3 series.
  8. john1701a
    9,445
    2,581
    Notice how GM claims to be transparent but detail is always missing and we have to dig for it?
    Of course, the data itself actually makes for a compelling argument in favor of Cruze.
    It's really unfortunate games like this continue to be played, especially with sales still way under a profitable level and the stock value so far below IPO price.
  9. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    Why not compare it to Volt's hybrid mode MPG?
    The catch with that is, a plugin hybrid with crappy gas engine would look better because it'll show more gallons "saved" vs. plugin with a 50 MPG gas engine.
    What was your previous car before Volt?
  10. austingreen
    austingreen Senior Member
    11,732
    2,716
    Austin, TX, USA
    GM is using the same trick toyota uses with the prius. They don't say how much gas the prius saves compared to a prius, they compare it to a different car. In England Toyota was even sued and lost for false advertising, picking a much worse than comparable car. Perhaps the Prius should be compared to a matrix and the volt to a cruze:D
    Hey that is your crappy method, and as you see its not legitamate. How about my method of similar non-hybrid:D
    Many of those miles were saved just because the volt is also a hybrid a plug in hybrid. One number was disapointing though, only 59% of those miles were electric. I was hoping self selection would push this into the 60s.
  11. john1701a
    9,445
    2,581
    No, that's not true for PHV...
  12. austingreen
    11,732
    2,716
    Austin, TX, USA
    Check out the mfd on the prius c, or toyota advertising claims. These talk about hybrid gas savings versus not a prius but a normal car, and as I pointed out toyota was sued and lost for picking a normal car that was much worse than normal in England.
    That site is not saying gas savings by using electricity, it is talking about gas savings using the volt versus a "normal car". But I think they should be comparing it to a cruze:D
  13. finman
    finman Senior Member
    1,281
    104
    Albany, OR
    2014 Nissan LEAF
    any link to the above lawsuit claim? curious...is it similar to the Civic Hybrid owner that won the low MPG lawsuit/small claim?
  14. austingreen
    11,732
    2,716
    Austin, TX, USA
    No quite different.
    Toyota gets hand slapped for false hybrid advertising in UK
    Watch the commercial, its quite over the top. The prius will give you bluer skies. The truth about prius gas mileage and ghg release, and volt gas and electricity consumption is good.
    3 people like this.
  15. john1701a
    9,445
    2,581
    GM continues to send mixed messages and be vague about references.
  16. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    Yea, it is disappointing. The EV mile percentage is much lower than the partial data (70%) from Voltstats.net. Looking at the total miles driven, Voltstats has about 10% of the total miles.
    That means 41% of Volt miles were driven with premium gas at 37 MPG. That ought to drag the overall composite MPGe down.
  17. austingreen
    11,732
    2,716
    Austin, TX, USA
    Using EPA combined mileage it would be 58 MPGe versus 64 if it was 70%. MPGe didn't drop all that much but they may have used 37% more oil:mad: I do not know if the numbers are significantly different than EPA though.
  18. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    Volt's EPA composite figure is 60 MPGe so 58 MPGe is pretty close.
    Most of the vocal Volt owners do get much higher MPGe but the average of all Volt is really disappointing. That means there must be a chunk of owners that never plug the Volt in? Perhaps, they have a very long commute?
    Prius PHV owner's spreadsheet shows the average of 67 MPGe. It is not a full year data so it is not comparable but it'll be interesting!
  19. drinnovation
    2,027
    586
    65
    CO
    Yep.. and as AustinGreen just cited, Toyota just misrepresent data in its ads.. Guess what they are in business and some suits somewhere feel they can drive marketing/messaging don't always care.
  20. drinnovation
    2,027
    586
    65
    CO
    There is no way to use the posted data to make a meaningful statement about the MPGe.. EPA uses highway and city in a mix and that mix may not be at all what volt drivers did. Without breakdowns one cannot tell.
    Also cannot tell what milage people actually obtained.
