New owner questions
Discussion in 'Newbie Forum' started by pr4424, Feb 17, 2008.
  1. Offline
    pr4424 New Member
    Jan 27, 2008
    Message Count:
    53
    Hershey, Pa
    Your Vehicle Year:
    Hello, I'm a new owner of a 2008 spectra blue pkg 5....wishing I got the touring model but couldn't find one.
    I have two questions:
    1. Is there a way to unlocked the driver and passenger side door by having the smart key in my pocket and just pushing the button in the door handle?
    2. Does CT's auto door lock mod also unlock the doors when the car is put in park/powered off?
    Thanks for your help!
    Patrick
  2. Offline
    billarb New Member
    Jan 7, 2008
    Message Count:
    114
    Long Island, NY
    Your Vehicle Year:
    Welcome! As for your first question, all doors unlock when you press the button on the passenger side of the vehicle, not on the driver's side. I'm not sure what you mean in your second question.
  3. Offline
    blazer_5154 Heh, you said "member"
    Dec 9, 2007
    Message Count:
    106
    Maryland
    Your Vehicle Year:
    If you look in the manual, there is a section about door locking / unlocking options, I believe the procedure requires that you hold the lock and panic buttons on the fob simultaneously for ~ 3-5 sec. until the car replies w/ a code that you can look up in the manual (series of beeps / honks or something). I was able to do it in mine with very little effort, now grasping the driver's side door handle unlocks all doors and the hatch. Hope this helps.
  4. Offline
    jayman New Member
    Oct 21, 2004
    Message Count:
    13,430
    581
    Winnipeg Manitoba
    Your Vehicle Year:
    If you push the black button on the door handle, all the doors lock. If you touch the inside of the door handle, where the sensor is, the door unlocks
    The way the Prius comes from the factory, if you touch the inside of the driver door, only the driver door unlocks. If you touch the inside of the passenger door handle, all unlock
    The dealer can use the scantool - a Panasonic ToughBook - to change the behavior. I had my dealer change the unlock so if I touch my driver door handle, all doors unlock. My dealer didn't charge me for that, hopefully yours won't either
    I also had the door lock/unlock beep volume increased. I couldn't hear it in traffic
  5. Offline
    edthefox5 New Member
    Jul 25, 2007
    Message Count:
    1,513
    198
    Clearwater, Florida
    Your Vehicle Year:
    Thanks again Jayman! Thats very cool. Half the time I can't hear the "you have locked the door" beep either. Will give the dealer a shot but I got a feeling I'll be getting a blank stare about a Panasonic Toughbook scantool.
  6. Offline
    EJFB1029 New Member
    Jan 16, 2008
    Message Count:
    4,726
    204
    Corpus Christi, Republic of Texas
    Your Vehicle Year:
    You have to have your car locked and be standing within range for the following, with Smart Key:
    You hold down the lock button on your remote, and while doing that, hold down the Panic button for at least 5 seconds you'll hear it beep about 3 times and then the mode is changed on the car, all doors will unlock with the drivers door.
  7. Offline
    N3FOL New Member
    Dec 2, 2007
    Message Count:
    873
    Stewartstown, PA.
    Your Vehicle Year:
    Thanks for Jayman's post. I will also give my dealer a call so I can have all my doors unlock from the driver's side.
  8. Offline
    morpheusx Professor Chaos
    Mar 6, 2007
    Message Count:
    1,514
    Akron, OH
    Your Vehicle Year:
    No need to waste your time at the dealer, the method described above works
    There is a section in the owners manual that describes the behavior of all three possible settings. I think they were
    FACTORY (DEFAULT) - Drivers door unlocks just drivers side
    Passenger and Trunk unlocks all doors
    Setting two - Drivers, passenger, and Hatch unlocks all doors
    Setting three - Drivers, passenger, and Hatch only unlocks the door opened
  9. Offline
    jayman New Member
    Oct 21, 2004
    Message Count:
    13,430
    581
    Winnipeg Manitoba
    Your Vehicle Year:
    I have a 2004, that doesn't work for my car. The dealer was happy to adjust settings free of charge, so I let them worry about it
Share This Page
