1. Online
    Start a Conversation
    12,390
    1,755
    Your Vehicle Year:
    it definitely regen's more aggresively. a hill i go down every workday used to get me up to 44-45 mph in my 08. in the pip i only hit 40-41. you can feel it holding back.
  2. Offline
    Rebound Senior Member
    Mar 11, 2010
    1,780
    504
    SF Bay Area, California
    Your Vehicle Year:
    In "regular" hybrid mode, the PiP will glide electrically almost forever. The ICE will still startup if torque or speed is high enough, but there's a lot more battery that it can glide with, IF you're driving on a road that's conducive to gliding at 30 to 40 MPH for twenty miles. In this case, although the ICE may still start, I bet a careful driver could hit 150 to 200 MPG.
  3. Online
    john1701a Prius Guru
    Jan 6, 2004
    6,769
    1,444
    Your Vehicle Year:
    Still one pip showing, but it was close enough to need a refill...
    DISPLAYED:
    848 miles total
    454 miles EV
    393 miles HV
    111 MPG
    92 kWh
    CALCULATED:
    104.9 MPG
    103.2 kWh
    MEASURED:
    33.3 recharges
    8.077 gallons
    That was a very exciting tank; though, waiting 2.5 weeks for the real-world data was an exercise in patience. It takes a long time to drive far enough to need to visit the gas station. :D
    4 people like this.
  4. Offline
    drinnovation EREV for EVER!
    Dec 10, 2011
    1,852
    496
    CO
    Your Vehicle Year:
    Interesting.. have seen discrepancies in gas/MPG before. Why do you think the kWh is so far off?
    Is one in the car and the other at the wall?
    I know the feeling of waiting.. to update fuelly I have to do full tanks with take months (my sig is just done with my electric bill so I can allocate costs). The PC PiP MPG spreadsheet is slowly rising as the more efficient divers take longer to add data, while those burning a lot of gas are on multiple tanks.
  5. Offline
    Mar 11, 2010
    1,780
    504
    Your Vehicle Year:
    It makes sense that the measured wattage -- what leaves the wall outlet -- will be higher than the wattage consumed by the car's electric motors. What confounds me is how the car reports its consumed wattage without mixing in the regenerated electricity.
  6. Online
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,344
    1,771
    Queens, NY
    Your Vehicle Year:
    Perhaps the charge goes into the battery when the unplugged gets ignored.
  7. Offline
    Dec 10, 2011
    1,852
    496
    CO
    Your Vehicle Year:
    Yes, it makes sense that the wall measurement would be higher.. (I expect that is the answer) but I wanted to be sure. Earlier measurements suggested the charger was 85% efficient. If this is wall measured (not just estimated) and car reported then it suggests
    only different losses and maybe the MPG spreadsheet should be updated.
    It could measuring its initial and final battery state and doing a computation based on that.. so its just the net energy. It would be interesting to see what happens if you reset EV2, with a partially depleted battery, at the top of a big hill.
  8. Offline
    matrix_uam New Member
    Apr 9, 2009
    Madrid, Spain
    Your Vehicle Year:
    I have one question: is there any information about how high charging cycles numbers will impact in battery life? I am reading experiences about three or four charging cycles a day what for me sounds a lot.. Thanks in advance
  9. Offline
    drees Senior Member
    Oct 31, 2007
    1,774
    239
    Your Vehicle Year:
    There are 4 major factors which affect lithium battery cycle life:
    1. Time (lithium batteries age just sitting there - they do have a shelf life)
    2. Temperature (more time spent at higher temps = faster degradation)
    3. State of charge (more time spent at high SOC = faster degradation)
    4. Cycles (more cycles = faster degradation)
    Increase any of these and your battery will degrade the fastest - combining multiple factors will be worse. For example, letting the car sit for a long period of time fully charged in the desert summer heat will quickly degrade the battery.
    How one can mitigate these factors:
    1. Time: Nothing you can do!
    2. Temp: Park in the shade, leave windows cracked when parked in sun.
    3. SOC: Use a charge timer so that the car doesn't finish charge until shortly before you leave. Don't store car with full battery.
    4. Don't charge the car as often.
    Obviously 4 isn't going to happen since you want to maximize EV miles - after all, that's why you bought the car!
    So it only makes sense to disregard #3 and do the opposite - you goal should be to put on as many cycles on the battery as possible to maximize your use of the battery in the shortest period of time since the clock is ticking anyway!
    Doing so maximizes your return on investment. If you wear out the battery from putting it through too many cycles, that's a good thing as it means you've effectively used the battery better than someone who lets the car sit for 10 years but rarely charges it.
    2 people like this.
  10. Online
    Jan 6, 2004
    6,769
    1,444
    Your Vehicle Year:
    Yup, that's it.
    Knowing the efficiency from the point-of-view of the vehicle itself is informative. But like you, I would also like to know how much I'm consuming overall (conversion losses) and what the electric bill will be.
    I always found that fascinating how regen is treated differently. It's outcome which matters. But for people like us, we like to know stuff like that.
    Toyota provides extra for us, to enhance the ownership experience. And it does!
    1 people like this.
  11. Offline
    Dec 10, 2011
    1,852
    496
    CO
    Your Vehicle Year:
    Thanks.. I had not see you post kWh stuff on the MPG sheet.
    I considered it, but the implied charging efficiency seemed a tad high. For comparison I just checked the MPG sheet and I see a wide range. (And crewdog's data is just crazy.. probably a typo)
    Code:
    Member    Miles    Gallon  "Wall kWh" HSI kWh  Efficency  Raw MPG"  "HSI MPG"
    ukr2     254.60    4.46    10.32       8        78%       57.06      59
    crewdog  557.60    7.94    29.09       24       83%       70.24      76
    crewdog  733.40    7.57    71.29       61       86%       96.80      99
    ukr2    1045.00    8.88    187.90      161      86%       117.75     123
    ukr2     725.20    8.69    79.59       70       88%       83.50      85
    JOHN171a 848.00    8.08    103.20      92       89%       104.90     111
    jjbradley711.00    6.78    82.50       76       92%       104.94     108
    crewdog 1022.20    8.56    110.00      138      125%      119.40     122
    1 people like this.
  12. Offline
    iRun26.2 New Member
    Jun 26, 2011
    683
    110
    United States
    Your Vehicle Year:
    This morning, as an experiment, I decided to see how far I could drive in pure EV mode before the ICE turned on. My only self imposed restriction (driving slow was OK as long as I didn't annoy other drivers) was that I must begin and end in my garage so that altitude changes and wind direction would not bias my test. Unfortunately, I forgot to begin going home soon enough and the engine fired up 0.6 miles from my house. I had slowly driven 22.1 miles on one full EV charge.
    It is interesting to note that the final mpg after the ICE finished the warm up cycle was 927 mpg. I had driven a total of 22.7 miles (outside temperature = 70F). Since the ICE had finished it's warm up cycle, I could have driven farther without using any more gas but I chose not to (meaning my final mpg could easily have been higher, one must not look at the ICE warm up cycle merely as a waste of gas).
    This equates to 0.0245 gallons of gas for ICE warm up.
    (40 ICE warm up cycles / gallon of gas)
    Not bad!
    2 people like this.
  13. Offline
    9G-man Active Member
    Jul 2, 2005
    1,230
    142
    Atlanta, GA
    Your Vehicle Year:
    Here's my best so far.
    Calculated and indicated are spot on. I even did three clicks after the pump stopped.
    This car is far MORE than I had hoped.
    I'm on vacation next week and hope to break 100MPG.
    [IMG]
    [IMG]
    1 people like this.
  14. Offline
    CharlesH CA HOV Decal #0005
    Nov 27, 2005
    842
    182
    San Jose, CA
    Your Vehicle Year:
    $3.539/gal. Sigh. I just filled up at Costco for $4.199, which is about as cheap as one can get around here. The scam they run here in California is saying that that state emission rules require a special blend that is only produced in California, and there always seems to be several of the refineries in the state down for "maintenance".
  15. Offline
    Dec 10, 2011
    1,852
    496
    CO
    Your Vehicle Year:
    Well there is an actual difference in Cali blend (both winter and summer blend). if you've not seen it there is interest read on the issue and why it costs more..
    http://www.fuelingcalifornia.org/wp.../Fueling-California-Exec-Summary-Only-HQP.pdf
    But most of the cost is speculation and supply issues, though one might wonder how many of the maintenance issues are some caused to to help maintain the profits.
    But there is some hope for you yet.. prices are expected to drop finally
    California-Blend Gasoline Tumbles to Two-Week Low on Unit Starts- Bloomberg
    @9Gman.. your getting so close to 100, but fair no wasting fuel and taking pointless slow drives on vacation just to get there. But maybe you can get in more mid-day recharges, and take someone shopping to stores that have chargers ;-)
  16. Offline
    Jul 2, 2005
    1,230
    142
    Atlanta, GA
    Your Vehicle Year:
    That was over a week ago.....Today, gas is $3.39. :D
    Not me. I don't do anything artificial for bigger MPG numbers. It's just that next week I won't be making my 96 mile r/t drive to work, which can keep me in the 80's. Just more short trips and more charging.
  17. Offline
    Andyprius # 1 Member since 2005
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    Some truly incredible numbers John, I don't think that can be beat. Congradulations.
  18. Offline
    janie Precious Prius Plug In
    Aug 31, 2010
    163
    36
    Your Vehicle Year:
    My first fill up since purchase on April 30th:
    Miles Driven: 1040
    Gallons purchased: 7.112
    Cons 146
    EV 61% - 642 miles
    HV 39% - 397 miles
    Kwh - 163
    Fuel Saved by charge Approximately 13.6 g
    My simple divide miles by gallons = 146 MPGe
    I put data into fuelly and it gave me 0 because it says it doesn't have enough data for me.
    Very pleased with the initial data. But I did work extra hard to get as many charges as possible. Next tank I will ease up a little so as to not stress so much about charging :)
    Tracksyde and usbseawolf2000 like this.
  19. Online
    Sep 22, 2004
    11,344
    1,771
    Queens, NY
    Your Vehicle Year:
    Over a thousand miles tank. That's awesome.
    The important part is... you used 163 kWh of electricity to save 13.6 gallon of gas.
    That's a worthy trade that no other plugin hybrid can top.
    janie likes this.
  20. Offline
    crewdog AARPrius User
    Jul 23, 2009
    280
    88
    Woodstock, GA
    Your Vehicle Year:
    Howdy all:
    just refueled and here's the data:
    637.1 mi
    7.75 gal at first click
    82.2 mpg calculated
    85 mpg indicated, 31 mph avg
    EV 30% 195 mi / HV 70% 436 mi
    38 kwh indicated / 7g used
    fuel saved 3.2g
    Kill-a-watt shows 46.47 kwh
    Tracksyde likes this.
Share This Page
