1. Offline
    Erikon Active Member
    Start a Conversation
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    I would leave the car on for an hour so the HV battery can continue charging the 12 volt.
  2. Offline
    VicVicVic New Member
    Jan 29, 2012
    48
    San Francisco, CA, USA
    Your Vehicle Year:
    By that, do you mean drive around for an hour, or actually just power on the car, leave it there for an hour, and then turn it off?
    There are some issues with the insurance company with adding this car and the driver, so I cannot really drive it around for the time being.
    Thanks,
    Vic
  3. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Just leave it on and running. The engine charges the HV battery which in turn charges the 12 volt.
  4. Offline
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Start it like your going to drive it, foot on the brake, push the power button!
  5. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,676
    1,669
    SF Bay Area, CA
    Your Vehicle Year:
    Yep. Doesn't matter if the Prius is moving or not. It has no effect on how quickly/slowly the 12 volt charges. Just leave it in READY mode (READY light ON).
  6. Offline
    guicide Junior Member
    May 21, 2012
    New Hampshire
    Your Vehicle Year:
    My 2012 turns on the interior lights as I approach.
  7. Offline
    spiderman wretched
    Jul 5, 2009
    6,750
    1,174
    Alaska
    Your Vehicle Year:
    I would press the dealer to replace the 12v battery. Tell them, once dead the battery will likely fail again. You shouldn't have to worry about that with a brand new car.
  8. Offline
    tach18k Member
    Feb 21, 2012
    268
    SoCal Beach Area
    Your Vehicle Year:
    When you go and get your 1000, 5000 mile checkup make sure they test and charge the battery. Also my 2012, the interior lights do come on when I approach the car. Keep calling toyota care when ever it breaks down, do that first.
  9. Offline
    macman408 Devil's Advocate General
    Mar 21, 2010
    762
    169
    Your Vehicle Year:
    What's the date of manufacture on your car? Perhaps it was sitting on the dealer's lot for too long, and the battery died because they never had it on long enough to charge the battery? Especially if you can give them that scenario, you might be able to convince them that the 12V battery needs to be replaced.
    Otherwise, if I were a dealer, I probably wouldn't replace a 12V battery after needing one jump start, unless I was feeling particularly generous. From their point of view, it's just not the most likely problem (more likely would be the customer accidentally leaving a light on), and normal use might fix it anyway.
    In any case, if you can't get a free replacement, I wouldn't worry too much about it. I killed mine absolutely stone dead about 2 months after getting the car; it's been over 2 years since then, and I haven't had a single problem. This weekend, my wife even left the interior lights on (she doesn't know how - she doesn't remember turning them on, and it was mid-day when she was driving so she had no reason to use them) for about 5 or 6 hours until our neighbor knocked to let us know. The car still started just fine, though the battery was obviously low (the lights were dim and brake pump ran slowly until I went to Ready mode).
  10. Offline
    WE0H My 1st Prius & my 17th anniversary present
    Mar 25, 2010
    2,409
    341
    Your Vehicle Year:
    I wonder if that is a programmable feature? Mine doesn't turn on the interior lights as I approach it. Many rental Prii have turned on the interior lights when I got close to the drivers door.
    Mike
  11. Offline
    jabecker driver of Prii since 2005
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    Both my 2005 and my 2012 turn on the interior lights when I approach the drivers door. It's a nice parlor trick to show my friends.
  12. Offline
    Mar 25, 2010
    2,409
    341
    Your Vehicle Year:
    Wonder what the Xgauge codes are to toggle that option?
    Mike
  13. Online
    Sep 4, 2005
    11,676
    1,669
    SF Bay Area, CA
    Your Vehicle Year:
    On the '10 and '11s, it was a dealer customization via Techstream. See Things that can be customized | PriusChat. Some of those can now be set on the '12s via LCD.
  14. Offline
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    I glanced at the Owner's Manual customization list, but I didn't see it there.
    WE0H likes this.
  15. Offline
    jim256 Member
    Jun 18, 2009
    317
    69
    Eastern NC
    Your Vehicle Year:
    On the 2010, the car has to be locked for the lights to activate on approach. Was it locked?
    jabecker likes this.
  16. Offline
    Mar 25, 2010
    2,409
    341
    Your Vehicle Year:
    Nope, I'll try the locked approach today. I always leave my car unlocked in my garage where it sits mostly ;)
    Mike
  17. Offline
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    Oh, good catch! My car is always locked, and the 2005 was also. Didn't even think of that.
  18. Offline
    Mar 21, 2010
    762
    169
    Your Vehicle Year:
    It also depends how good your ninja-fu is. I usually sneak up on my car fast enough that the lights don't start coming on until right about when I grab the handle - to an outside observer, it would look like the lights came on because I unlocked it, not just because I was nearby.
  19. Offline
    Mar 25, 2010
    2,409
    341
    Your Vehicle Year:
    Just tested mine today and the lights do come on when I snuck up on my car with locked doors.
    Mike [IMG]
  20. Offline
    5,570
    1,163
    Your Vehicle Year:
    I erred by not waiting long enough in my earlier test.
    Immediately after locking the car, the interior lights go out and don't respond to the key's proximity. Wait a bit and retest, and the lights do come on.
Share This Page
