1. Offline
    orange4boy New Member
    Oct 20, 2009
    Message Count:
    218
    23
    Vancouver BC
    Your Vehicle Year:
    2003 Prius
    Was looking at PC based diagnostic tools and found this one:
    EScan - Automotive Test Solutions
    They also offer the following:
    Not cheap at $1095 but there it is.
  2. Offline
    jk450 New Member
    Message Count:
    596
    46
    I'd steer clear of EScan's "solution". The only PC-to-vehicle connection approved for use with Techstream Lite software is the DrewTech Mongoose USB cable, as you can see here:
    https://techinfo.toyota.com:443/tec...nfo/html/prelogin/docs/tslfaqtinfo.pdf#page=7
    The cable and communication software run $495. Less than half of the cost of the EScan setup.
    In both cases, you still have to buy the Techstream software.
  3. Offline
    statultra uber-Senior Member
    Dec 6, 2005
    Message Count:
    784
    16
    cape coral, FL
    Your Vehicle Year:
    just to let you guys know i purchased a Tactrix Openport 2.0 and it works with techstream lite perfectly, also noting it also works with Honda HDS
  4. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Could you record the generator/MG1 metrics and report them here?
    The reason I ask is Auto Enginuity is reporting some data values, MG1 in particular that make no sense. If you could, record:
    • ICE rpm
    • MG1/generator values - all that are avaliable
    Just a 10-20 minute drive recording the data values would be enough. It would be especially useful if you could record the data from an NHW11 Prius.
    Thanks,
  5. Offline
    NortTexSalv04Prius New Member
    Nov 14, 2009
    Message Count:
    275
    Your Vehicle Year:
    Explain please
    I understand this a software pkg. However if your looking quality factory OBD 2 diagonostic tester where do you go. I have seen prices for Denso Toyota Tester 2 for about $1700.
  6. Offline
    Dec 6, 2005
    Message Count:
    784
    16
    cape coral, FL
    Your Vehicle Year:
    The tactrix cable costs 170 bucks and a friend of mine works at a Toyota dealer where I obtained techstream v5 evaluation and it has all the functionality of the mongoose cable or the denso tester.
    the only issue is im figuring out how to export the CSV files, specifically the data mr wilson requested.
Share This Page
