New/ used 2005 prius
Discussion in 'Newbie Forum' started by wek, Jul 17, 2012.
  1. Offline
    wek New Member
    Start a Conversation
    Jul 17, 2012
    Durango, Colo
    Your Vehicle Year:
    Hey all
    I just bought a 2005 w/ 100000 miles on it. within 2 weeks the starter battery needed replacing $320 from my local dealer. yikes!!
    Now I believe (from the forum) that I did damage to the fuel tank system by over filling it. I didn't know the "don't ##** overfill these gastanks or else" mantra. Now everytime I try to fill it, it bubbles back up and overflows when anywhere near full. The check engine light is on
    DID I CAUSE GREAT DAMAGE? I'm afraid to go back to the dealer after the last repair a few weeks ago. Advice please
    What other "Don't ever do this" advice do you guys have for me?
    Thanks
  2. Offline
    12,309
    1,730
    Your Vehicle Year:
    welcome! sorry for your troubles. how many times have you filled it since the overfill? if it's running all right you proly didn't do any damage. does it bubble out before the gas pump shuts off?
  3. Offline
    Apr 14, 2009
    5,761
    1,587
    Greenwood MS USA
    Your Vehicle Year:
    Without a location, how can we advise anyone BUT the dealer? Give us a hint! ( The 12 volt battery lists for $136, so I understand the reluctance to go back to that dealer)
  4. Offline
    wek New Member
    Jul 17, 2012
    Durango, Colo
    Your Vehicle Year:
    Hi
    No it doesn't bubble over until the filling is over. What are the bad damage signs I should look for?
  5. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,648
    1,658
    SF Bay Area, CA
    Your Vehicle Year:
    If only the location field were mandatory...
    OP, w/o the codes, we're flying totally blind and thus don't know what's causing the check engine light.
  6. Offline
    wjtracy Senior Member
    Sep 19, 2006
    2,511
    311
    NOVA
    Your Vehicle Year:
    ....I had the fuel bubble over once and I blamed it on faulty pump cutoff.
    Also hot weather allows more flex in the bladder tank.
    Normally takes 8.5 to 9 gallons in summer to fill...how about stick with 6-7 gals until the problem subsides.
    Try different station. Not sure what the manual says about check engine light, but my VW says give it a chance to reset itself, and it did on the VW.
  7. Offline
    wek New Member
    Jul 17, 2012
    Durango, Colo
    Your Vehicle Year:
    Thanks
    The check engine light has gone off and I will fill slowly and vent ahead of paying when I get gas. Hopefully all is well
  8. Offline
    Mar 27, 2004
    7,634
    836
    United States
    Your Vehicle Year:
    And don't try to "top it off".
Share This Page
