Newbie Question - Fan
Discussion in 'Newbie Forum' started by Acre, Nov 7, 2009.
  1. Offline
    Acre New Member
    Nov 7, 2009
    Message Count:
    102
    Woodside, CA
    Your Vehicle Year:
    Picked up my Prius II Wendesday. This is my first car with AC (or power doors - or power windows).
    Not wanting to compromise gas mileage I proceeded to cool myself in my standard fasion today - by turning on the fan and aiming the vents at my forehead. After about 5 minutes, the fan turned itself off. I turned it on again, had to turn down the air flow to the low setting I had it on, and the same thing happened - about 5 minutes of fan, then it turned itself off again. Anyone know what the deal is?
    I tried dialing the set temp up and then down to see if that had anything to do with it. It didn't.
    Also, the fuel gauge registered no change for the first 60 miles, then dropped three "points" in the next 80. Is this typical? First tank and all but I'd hate to think I used a third of a tank to drive 140 miles. This is in "ECO" mode only and I drive very conservatively - in all my other cars I was within 2-3 mpg of the EPA estimate. Most of the 80 miles were highway, where I know the car doesn't do as well, but the difference should be pretty minimal. I realize my first tank means very little. Thanks.
    Oh and generally the car is nice. Rear visibity is not the greatest but not as bad as one often hears, although I will remove the rear headrests when no one is back there. I appreciate the oversized mirrors. Smooth running car; not a powerhouse but I wasn't expecting that. Adequate for all practical needs; enough merging power. The shifter is annoying with the reverse and drive - reversed.
  2. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,757
    2,806
    Northern Michigan
    Your Vehicle Year:
    If the climate control is set to auto, the fan will speed up and slow down based on the temperature of the cabin and the setpoint setting. If you insist on running the climate control manually, turn off auto.
    Tom
  3. Offline
    Acre New Member
    Nov 7, 2009
    Message Count:
    102
    Woodside, CA
    Your Vehicle Year:
    Thanks Tom!
  4. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    Congrats on the new care Acre.
    Not sure what is happening with your fuel gauge but see if it settles down on the next tank before taking it back to the dealer.
    Not sure what the story is with the fan except what Tom said.
    Can you tell me which automatic car you have driven where reverse is behind drive? All the ones I have driven park is right to the front, then reverse, then neutral, then drive going toward the rear. I think that is why Prius is like it is.
  5. Offline
    Jun 27, 2007
    Message Count:
    1,671
    87
    Out there, somewhere
    Your Vehicle Year:
    This is typical behavior for the "guess guage." It has to do with the fuel bladder being flexible, therefore not having a consistent shape or volume.
    Once you know your mileage, you can get a better idea by re-setting one of your odometers at each fillup. You're pretty safe assuming 400 miles per tank (i.e. 40 mpg), leaving you considerable reserve.
  6. Offline
    Acre New Member
    Nov 7, 2009
    Message Count:
    102
    Woodside, CA
    Your Vehicle Year:
    Thanks Doc and Pat. My Previuos cars ('81 Escort, '82 Corolla, '95 Tercel, 02 Civic HX (a lemon) also had "guess gauges"; I guess I expected the Prius with its high tech image would have overcome that.
    The awkwardness with the shifter, at least for me, is that others I've used didn't utilize an "over and up" or "over and down" motion so having reverse above drive didn't product that counter intuitive feel I get in the Prius.
  7. Offline
    Mar 2, 2006
    Message Count:
    17,757
    2,806
    Northern Michigan
    Your Vehicle Year:
    The OP reports having a 2010 Prius, therefor no bladder.
    Tom
  8. Offline
    Acre New Member
    Nov 7, 2009
    Message Count:
    102
    Woodside, CA
    Your Vehicle Year:
    Turning off "auto" didn't fix the fan problem; I was still fighting it with auto off and AC off but when I adjusted the temp down to where it displayed "Lo" rather that a temp everything was fine. I could set the fan at a low speed and it would just stay there, even after parking and re-starting the car.
    Guess people were right about the guess gauge. I fuel up at 319 miles. Tank took 7 gallons exactly; computer says I averaged 46.8 mpg. Weather is cool; this morning at start-up was 37 degrees F so for the first few hundred miles I seem to be doing pretty well.
  9. Online
    tumbleweed New Member
    Oct 3, 2005
    Message Count:
    3,801
    551
    Eastern Oregon
    Your Vehicle Year:
    Congratulations on the new Prius. There is quite a bit to learn but it's fun. I would submit that since you are already driving in the ECO mode you might be able to use the AC without hurting your mileage by very much. Your Prius has a very efficient AC system and in ECO mode it runs even more efficiently, give it a try.
    If you consider the shift pattern it is actually the same, as far as R and D are concerned, as a normal automatic. The main difference is that you need to hold the selector in N for 1 second to get it in neutral and P has a button. BTW when you are getting ready to shut the car off you don't need to select P first, it will go int P when you are stopped and push the Power button to shut the car off.
    Have fun!
Share This Page
